ORACLE 12C物理备库archive log list 显示为0
Lucifer三思而后行 发表于 2021/10/28 10:23:39 2021/10/28
【摘要】 12C 物理Standby的 archive log list 情况如下:ADG是可以正常同步的,但是备库执行 archive log list 时显示都为 0,因此比较好奇,于是查询mos发现:**参考MOS文档:Archive Log List Showing 0 At Standby, But Standby Is Completely In Sync With Primary! (D...
**参考MOS文档:Archive Log List Showing 0 At Standby, But Standby Is Completely In Sync With Primary! (Doc ID 2041137.1)    **
12C针对物理备库redo log做出了调整,可以通过以下SQL查看:
select GROUP#,STATUS from v$log;
12C:
11G:
解决方案:
** Do not use  ARCHIVE LOG LIST on standby side.**
可以使用以下命令查看:
Primary: SQL> select thread#, max(sequence#) "Last Primary Seq Generated"
from v$archived_log val, v$database vdb
where val.resetlogs_change# = vdb.resetlogs_change#
group by thread# order by 1;
PhyStdby:SQL> select thread#, max(sequence#) "Last Standby Seq Received"
PhyStdby:SQL>select thread#, max(sequence#) "Last Standby Seq Applied"
and val.applied in ('YES','IN-MEMORY')
