Oracle在线重定义之COPY_TABLE_DEPENDENTS
Lucifer三思而后行 发表于 2021/10/28 10:09:53 2021/10/28
【摘要】 当使用在线重定义功能进行非分区表转换时,过程中需要对中间表进行索引,约束等依赖进行重建,Oracle提供了两种方式:本文参考:https://oracle-base.com/articles/misc/partitioning-an-existing-table 一、COPY_TABLE_DEPENDENTS使用DBMS_REDEFINITION包自带的procedure:DBMS_REDE...
使用DBMS_REDEFINITION包自带的procedure:DBMS_REDEFINITION.copy_table_dependents来实现:
SET SERVEROUTPUT ON
DECLARE
  l_errors  NUMBER;
BEGIN
  DBMS_REDEFINITION.copy_table_dependents(
    uname            => USER,
    orig_table       => 'BIG_TABLE',
    int_table        => 'BIG_TABLE2',
    copy_indexes     => DBMS_REDEFINITION.cons_orig_params,
    copy_triggers    => TRUE,
    copy_constraints => TRUE,
    copy_privileges  => TRUE,
    ignore_errors    => FALSE,
    num_errors       => l_errors,
    copy_statistics  => FALSE,
    copy_mvlog       => FALSE);
  DBMS_OUTPUT.put_line('Errors=' || l_errors);
END;
用法可参考官方文档:https://docs.oracle.com/en/database/oracle/oracle-database/19/arpls/DBMS_REDEFINITION.html#GUID-406BDCBD-5EC9-4C27-BA92-AEDFE7853CE7
Table 134-7 COPY_TABLE_DEPENDENTS Procedure Parameters
Parameter Description
uname
Schema name of the tables
orig_table
Name of the table being redefined
int_table
Name of the interim table
copy_indexes
Flag indicating whether to copy the indexes
  • 0 - do not copy any index
  • dbms_redefinition.cons_orig_params – copy the indexes using the physical parameters of the source indexes
copy_triggers
TRUE = clone triggers, FALSE = do nothing
copy_constraints
TRUE = clone constraints, FALSE = do nothing. If compatibility setting is 10.2 or higher, then clone CHECK and NOT NULL constraints
copy_privileges
TRUE = clone privileges, FALSE = do nothing
ignore_errors
TRUE = if an error occurs while cloning a particular dependent object, then skip that object and continue cloning other dependent objects. FALSE = that the cloning process should stop upon encountering an error.
num_errors
Number of errors that occurred while cloning dependent objects
copy_statistics
TRUE = copy statistics, FALSE = do nothing
copy_mvlog
TRUE = copy materialized view log, FALSE = do nothing
DBMS_REDEFINITION.COPY_TABLE_DEPENDENTS(
   uname                    IN  VARCHAR2,
   orig_table               IN  VARCHAR2,
   int_table                IN  VARCHAR2,
   copy_indexes             IN  PLS_INTEGER := 1,
   copy_triggers            IN  BOOLEAN     := TRUE,
   copy_constraints         IN  BOOLEAN     := TRUE,
   copy_privileges          IN  BOOLEAN     := TRUE,
   ignore_errors            IN  BOOLEAN     := FALSE,
   num_errors               OUT PLS_INTEGER,
   copy_statistics          IN  BOOLEAN     := FALSE,
   copy_mvlog               IN  BOOLEAN     := FALSE);
此方式的优缺点:
优点:可以根据你传入的参数,选择需要复制的依赖,有索引,触发器,约束,权限,统计信息。当重定义dbms_redefinition.finish_redef_table之后,会自动切换这些依赖到分区表中,不需要人为rename操作。
缺点:使用此方式复制的索引,会保留非分区表的索引类型,依然是GLOBAL的全局索引,并不会根据分区自动转换为LOCAL本地索引。
Notes:如果不考虑将索引建为LOCAL本地索引,可以使用如上方式进行复制。
二、手动创建
通过手动创建索引,指定LOCAL本地索引方式创建,但是需要在重定义dbms_redefinition.finish_redef_table之后,手动重新rename。
-- Add new keys, FKs and triggers.
ALTER TABLE big_table2 ADD (
  CONSTRAINT big_table_pk2 PRIMARY KEY (id)
CREATE INDEX bita_created_date_i2 ON big_table2(created_date) LOCAL;
CREATE INDEX bita_look_fk_i2 ON big_table2(lookup_id) LOCAL;
  CONSTRAINT bita_look_fk2
  FOREIGN KEY (lookup_id)
  REFERENCES lookup(id)
-- Gather statistics on the new table.
EXEC DBMS_STATS.gather_table_stats(USER, 'BIG_TABLE2', cascade => TRUE);
-- Remove original table which now has the name of the interim table.
DROP TABLE big_table2;
-- Rename all the constraints and indexes to match the original names.
ALTER TABLE big_table RENAME CONSTRAINT big_table_pk2 TO big_table_pk;
ALTER TABLE big_table RENAME CONSTRAINT bita_look_fk2 TO bita_look_fk;
ALTER INDEX big_table_pk2 RENAME TO big_table_pk;
ALTER INDEX bita_look_fk_i2 RENAME TO bita_look_fk_i;
ALTER INDEX bita_created_date_i2 RENAME TO bita_created_date_i;
优点:可以根据用户的需求,以适当的方式来创建索引等依赖。
缺点:由于是用户自己创建并且切换,所以需要有一定的基础,不能漏掉任何依赖,需要考虑完全。
三、COPY_TABLE_DEPENDENTS + 手动创建索引
也可以通过组合使用,通过COPY_TABLE_DEPENDENTS来复制其他依赖,索引手动创建。
--排除索引
SET SERVEROUTPUT ON
DECLARE
  l_errors  NUMBER;
BEGIN
    uname            => USER,
    copy_indexes     => 0,
END;
--创建索引LOCAL(主键索引无法创建LOCAL本地索引)
CREATE INDEX bita_created_date_i2 ON big_table2(created_date) tablespace USERS LOCAL;
CREATE INDEX bita_look_fk_i2 ON big_table2(lookup_id) tablespace USERS LOCAL;
--重定义完成后,rename索引名称
优点:综合上述两种方式,此方式只需要关注索引是否遗漏,无需关注触发器,权限,约束等依赖。
