ORACLE分区表转换之在线重定义(DBMS_REDEFINITION)
Lucifer三思而后行 发表于 2021/10/28 10:07:51 2021/10/28
【摘要】 一、DBMS_REDEFINITION(在线重定义)参考MOS文档:_How To Partition Existing Table Using DBMS_REDEFINITION (Doc ID 472449.1)  _支持的数据库版本:Oracle Database - Enterprise Edition - Version 9.2.0.4 and later在线重定义是通过 物化视...
在线重定义是通过 物化视图 实现的。
使用在线重定义的一些限制条件:
1、必须有足够的表空间来容纳表的两倍数据量。
2、主键列不能被修改。
3、表必须有主键。
4、必须在同一个用户下进行在线重定义。
5、SYS和SYSTEM用户下的表无法进行在线重定义。
6、在线重定义无法采用nologging。
7、如果中间表有新增列,则不能有NOT NULL约束
DBMS_REDEFINITION包:
  1. ABSORT_REDEF_TABLE:清理重定义的错误和中止重定义;
  2. CAN_REDEF_TABLE:检查表是否可以进行重定义,存储过程执行成功代表可以进行重定义;
  3. COPY_TABLE_DEPENDENTS:同步索引和依赖的对象(包括索引、约束、触发器、权限等);
  4. FINISH_REDEF_TABLE:完成在线重定义;
  5. REGISTER_DEPENDENTS_OBJECTS:注册依赖的对象,如索引、约束、触发器等;
  6. START_REDEF_TABLE:开始在线重定义;
  7. SYNC_INTERIM_TABLE:增量同步数据;
  8. UNREGISTER_DEPENDENT_OBJECT:不注册依赖的对象,如索引、约束、触发器等;
Subprogram Description
ABORT_REDEF_TABLE Procedure
Cleans up errors that occur during the redefinition process and removes all temporary objects created by the reorganization process
ABORT_ROLLBACK Procedure
Aborts rollback
ABORT_UPDATE Procedure
Aborts an update started with the EXECUTE_UPDATE procedure
CAN_REDEF_TABLE Procedure
Determines if a given table can be redefined online
COPY_TABLE_DEPENDENTS Procedure
Copies the dependent objects of the original table onto the interim table
EXECUTE_UPDATE Procedure
Optimizes the performance of bulk updates to a table
FINISH_REDEF_TABLE Procedure
Completes the redefinition process
Provides a single push-button interface that integrates several redefinition steps
REGISTER_DEPENDENT_OBJECT Procedure
Registers a dependent object (index, trigger, constraint or materialized view log) on the table being redefined and the corresponding dependent object on the interim table
ROLLBACK Procedure
Performs rollback
SET_PARAM Procedure
Sets a new value for a specified parameter used by the redefinition process identified by a redefinition ID
START_REDEF_TABLE Procedure
Initiates the redefinition process
SYNC_INTERIM_TABLE Procedure
Keeps the interim table synchronized with the original table
UNREGISTER_DEPENDENT_OBJECT Procedure
Unregisters a dependent object (index, trigger, constraint or materialized view log) on the table being redefined and the corresponding dependent object on the interim table
CREATE OR REPLACE PACKAGE SYS.dbms_redefinition AUTHID CURRENT_USER IS
  --  OVERVIEW
  -- This package provides the API to perform an online, out-of-place
  -- redefinition of a table
  --- CONSTANTS
  -- Constants for the options_flag parameter of start_redef_table
  cons_use_pk    CONSTANT PLS_INTEGER := 1;
  cons_use_rowid CONSTANT PLS_INTEGER := 2;
  -- Constants used for the object types in the register_dependent_object
  cons_index      CONSTANT PLS_INTEGER := 2;
  cons_constraint CONSTANT PLS_INTEGER := 3;
  cons_trigger    CONSTANT PLS_INTEGER := 4;
  cons_mvlog      CONSTANT PLS_INTEGER := 10;
  -- constants used to specify the method of copying indexes
  cons_orig_params CONSTANT PLS_INTEGER := 1;
  PRAGMA SUPPLEMENTAL_LOG_DATA(default, AUTO_WITH_COMMIT);
  -- NAME:     can_redef_table - check if given table can be re-defined
  -- INPUTS:   uname        - table owner name
  --           tname        - table name
  --           options_flag - flag indicating user options to use
  --           part_name    - partition name
  PROCEDURE can_redef_table(uname        IN VARCHAR2,
                            tname        IN VARCHAR2,
                            options_flag IN PLS_INTEGER := 1,
                            part_name    IN VARCHAR2 := NULL);
  PRAGMA SUPPLEMENTAL_LOG_DATA(can_redef_table, NONE);
  -- NAME:     start_redef_table - start the online re-organization
  -- INPUTS:   uname        - schema name
  --           orig_table   - name of table to be re-organized
  --           int_table    - name of interim table
  --           col_mapping  - select list col mapping
  --           orderby_cols - comma separated list of order by columns
  --                          followed by the optional ascending/descending
  --                          keyword
  --           part_name    - name of the partition to be redefined
  PROCEDURE start_redef_table(uname        IN VARCHAR2,
                              orig_table   IN VARCHAR2,
                              int_table    IN VARCHAR2,
                              col_mapping  IN VARCHAR2 := NULL,
                              options_flag IN BINARY_INTEGER := 1,
                              orderby_cols IN VARCHAR2 := NULL,
  -- NAME:     finish_redef_table - complete the online re-organization
  --           part_name    - name of the partition being redefined
  PROCEDURE finish_redef_table(uname          IN VARCHAR2,
  -- NAME:     abort_redef_table - clean up after errors or abort the
  --                               online re-organization
  PROCEDURE abort_redef_table(uname        IN VARCHAR2,
  -- NAME:     sync_interim_table - synchronize interim table with the original
  --                                table
  PROCEDURE sync_interim_table(uname       IN VARCHAR2,
  -- NAME:     register_dependent_object - register dependent object
  --           dep_type     - type of the dependent object
  --           dep_owner    - name of the dependent object owner
  --           dep_orig_name- name of the dependent object defined on table
  --                          being re-organized
  --           dep_int_name - name of the corressponding dependent object on
  --                          the interim table
  PROCEDURE register_dependent_object(uname         IN VARCHAR2,
                                      dep_type      IN PLS_INTEGER,
                                      dep_owner     IN VARCHAR2,
                                      dep_orig_name IN VARCHAR2,
                                      dep_int_name  IN VARCHAR2);
  -- NAME:     unregister_dependent_object - unregister dependent object
  PROCEDURE unregister_dependent_object(uname         IN VARCHAR2,
  --  NAME:     copy_table_dependents
  --           copy_indexes      - integer value indicating whether to
  --                               copy indexes
  --                               0 - don't copy
  --                               1 - copy using storage params/tablespace
  --                                   of original index
  --           copy_triggers      - TRUE implies copy triggers, FALSE otherwise
  --           copy_constraints   - TRUE implies copy constraints, FALSE
  --                                otherwise
  --           copy_privileges    - TRUE implies copy privileges, FALSE
  --                                otherwise
  --           ignore errors      - TRUE implies continue after errors, FALSE
  --                                otherwise
  --           num_errors         - number of errors that occurred while
  --                                cloning ddl
  --           copy_statistics    - TRUE implies copy table statistics, FALSE
  --                                otherwise.
  --                                If copy_indexes is 1, copy index
  --                                related statistics, 0 otherwise.
  --           copy_mvlog         - TRUE implies copy table's MV log, FALSE
  --                                otherwise.
  PROCEDURE copy_table_dependents(uname              IN  VARCHAR2,
                                  copy_indexes       IN  PLS_INTEGER := 1,
                                  copy_triggers      IN  BOOLEAN := TRUE,
                                  copy_constraints   IN  BOOLEAN := TRUE,
                                  copy_privileges    IN  BOOLEAN := TRUE,
                                  ignore_errors      IN  BOOLEAN := FALSE,
                                  num_errors         OUT PLS_INTEGER,
                                  copy_statistics    IN  BOOLEAN := FALSE,
                                  copy_mvlog         IN  BOOLEAN := FALSE);
END;
二、在线重定义表的步骤
**1.**创建未分区的表,如果存在,就不需要操作。
--前置准备:创建用户,表空间,授权用户。
SQL> create tablespace PARTITION;
SQL> create user par identified by par;
SQL> grant dba to par;
--创建表,索引,授权,同义词
SQL> conn par/par
Connected.
-- Create table
create table student(
s_id number(8) PRIMARY KEY,
s_name varchar2(20) not null,
s_sex varchar2(8),
s_birdate date,
constraint u_1 unique(s_name),
constraint c_1 check (s_sex in ('MALE','FEMALE')))
-- Add comments to the table
comment on table STUDENT is '学生表';
-- Add comments to the columns
comment on column STUDENT.s_name is '姓名';
comment on column STUDENT.s_sex is '性别';
comment on column STUDENT.s_birdate is '出生日期';
-- Create/Recreate indexes
create index S_NAME_IDX on STUDENT (S_NAME, S_SEX) tablespace PARTITION;
-- Create SYNONYM
CREATE SYNONYM stu FOR student;
-- Grant/Revoke object privileges
grant select, insert, delete on STUDENT to SCOTT;
--查看表结构
SQL> desc stu
 Name					   Null?    Type
 S_ID					   NOT NULL NUMBER(8)
 S_NAME 				   NOT NULL VARCHAR2(20)
 S_SEX						    VARCHAR2(8)
 S_BIRDATE					    DATE
--插入数据
begin
  for i in 0 .. 24 loop
    insert into student values
      (i,
       'student_' || i,
       decode(mod(i, 2), 0, 'MALE', 'FEMALE'),
       add_months(to_date('2019-1-1', 'yyyy-mm-dd'), i));
  end loop;
  commit;
end;
2.确认表是否存在主键,表空间是否足够,收集表统计信息。
--查看表主键
SQL> select cu.* from user_cons_columns cu, user_constraints au where cu.constraint_name = au.constraint_name and au.constraint_type = 'P' and au.table_name = 'STUDENT';
--查看表大小和表空间
--查看表空间
SQL> select tablespace_name from dba_segments where segment_type= 'TABLE' and segment_name='STUDENT' and owner='PAR';
--查看表大小
SQL> select sum(bytes/1024/1024) from dba_segments where segment_type= 'TABLE' and segment_name='STUDENT' and owner='PAR';
--查看表空间
select tbs_used_info.tablespace_name,
       tbs_used_info.alloc_mb,
       tbs_used_info.used_mb,
       tbs_used_info.max_mb,
       tbs_used_info.free_of_max_mb,
       tbs_used_info.used_of_max || '%' used_of_max_pct
  from (select a.tablespace_name,
               round(a.bytes_alloc / 1024 / 1024) alloc_mb,
               round((a.bytes_alloc - nvl(b.bytes_free,
                                          0)) / 1024 / 1024) used_mb,
                                          0)) * 100 / a.maxbytes) used_of_max,
               round((a.maxbytes - a.bytes_alloc + nvl(b.bytes_free,
                                                       0)) / 1048576) free_of_max_mb,
               round(a.maxbytes / 1048576) max_mb
          from (select f.tablespace_name,
                       sum(f.bytes) bytes_alloc,
                       sum(decode(f.autoextensible,
                                  'YES',
                                  f.maxbytes,
                                  'NO',
                                  f.bytes)) maxbytes
                  from dba_data_files f
                 group by tablespace_name) a,
                       sum(f.bytes) bytes_free
                  from dba_free_space f
                 group by tablespace_name) b
         where a.tablespace_name = b.tablespace_name(+)) tbs_used_info
 order by tbs_used_info.used_of_max desc;
--如果表空间不够,提前增加表空间大小
alter tablespace PARTITION add datafile;
--收集统计信息(可忽略)
EXEC DBMS_STATS.gather_table_stats('PAR', 'STUDENT', cascade => TRUE);
3.调用DBMS_REDEFINITION.CAN_REDEF_TABLE()过程,确认表是否满足重定义的条件。
SQL> EXEC Dbms_Redefinition.can_redef_table('PAR', 'STUDENT');
PL/SQL procedure successfully completed.
4.在用一个用户中建立一个空的中间表,根据重定义后你期望得到的结构建立中间表。比如:采用分区表(间隔分区),增加了COLUMN等。
在中间表上建立触发器、索引和约束,并进行相应的授权。任何包含中间表的完整性约束应将状态置为disabled。(此步骤也可以放在同步数据后操作)
--创建间隔分区(增加列s_phone)
create table STUDENT_PAR
  s_id      NUMBER(8) not null,
  s_name    VARCHAR2(20) not null,
  s_sex     VARCHAR2(8),
  s_birdate DATE,
  s_phone   number
PARTITION BY RANGE(s_birdate)
INTERVAL (NUMTOYMINTERVAL(1,'MONTH')) STORE IN (partition)
(PARTITION STUDENT_201901 VALUES LESS THAN (TO_DATE('2019-02-01 00:00:00', 'SYYYY-MM-DD HH24:MI:SS', 'NLS_CALENDAR=GREGORIAN')));
--临时中间表上创建如下:
--创建主键约束
alter table STUDENT_PAR add primary key (S_ID) using index tablespace PARTITION;
--创建唯一索引约束
alter table STUDENT_PAR add constraint U_1_PAR unique (S_NAME) using index tablespace PARTITION;
--创建check约束
alter table STUDENT_PAR add constraint C_1_PAR check (s_sex in ('MALE','FEMALE'));
--创建索引
CREATE INDEX S_NAME_IDX_PAR ON STUDENT_PAR (S_NAME,S_SEX) tablespace PARTITION;
--创建同义词
CREATE SYNONYM stu_par FOR STUDENT_PAR;
--添加描述
COMMENT ON TABLE  STUDENT_PAR IS '学生表';
COMMENT ON COLUMN STUDENT_PAR.s_name IS '姓名';
COMMENT ON COLUMN STUDENT_PAR.s_sex IS '性别';
COMMENT ON COLUMN STUDENT_PAR.s_birdate IS '出生日期';
--授权
GRANT SELECT,INSERT,DELETE ON STUDENT_PAR TO scott;
5.调用DBMS_REDEFINITION.START_REDEF_TABLE()过程,并提供下列参数:被重定义的表的名称、中间表的名称、列的映射规则、重定义方法。
如果映射方法没有提供,则认为所有包括在中间表中的列用于表的重定义。如果给出了映射方法,则只考虑映射方法中给出的列。如果没有给出重定义方法,则默认使用主键方式。
SQL> BEGIN
DBMS_REDEFINITION.start_redef_table(
uname => 'PAR',
orig_table => 'STUDENT',
int_table => 'STUDENT_PAR');
END;
6.(可选)在创建索引之前将新表与临时名称同步。
Notes:如果在执行DBMS_REDEFINITION.START_REDEF_TABLE()过程和执行DBMS_REDEFINITION.FINISH_REDEF_TABLE()过程直接在重定义表上执行了大量的DML操作,那么可以选择执行一次或多次的SYNC_INTERIM_TABLE()过程,此操作可以减少最后一步执行FINISH_REDEF_TABLE()过程时的锁定时间。
--模拟业务不停,DML表数据写入
insert into STUDENT values(25,'student_25','MALE',to_date('2020-8-1', 'yyyy-mm-dd'));
update student set s_sex='FEMALE' where s_id = 20;
commit;
--比对student和student_par数据
select s_id,s_name,s_sex,s_birdate from student
minus
select s_id,s_name,s_sex,s_birdate from student_par;
      S_ID S_NAME		S_SEX	 S_BIRDATE
	20 student_20		FEMALE	 01-SEP-20
	25 student_25		MALE	 01-AUG-20
--同步数据到临时表
BEGIN
dbms_redefinition.sync_interim_table(
uname => 'PAR',
END;
--数据已全部同步到临时表
minus
no rows selected
7.执行DBMS_REDEFINITION.FINISH_REDEF_TABLE()过程完成表的重定义。这个过程中,原始表会被独占模式锁定一小段时间,具体时间和表的数据量有关。
执行完FINISH_REDEF_TABLE()过程后,原始表重定义后具有了中间表的属性、索引、约束、授权和触发器。中间表上disabled的约束在原始表上处于enabled状态。
--收集par table的统计信息
EXEC DBMS_STATS.gather_table_stats('PAR', 'STUDENT_PAR', cascade => TRUE);
--结束在线重定义过程
BEGIN
dbms_redefinition.finish_redef_table(
uname => 'PAR',
END;
SQL> select table_name,PARTITION_NAME from user_tab_partitions where table_name in ('STUDENT','STUDENT_PAR');
SQL> select table_name,index_name from user_indexes where table_name in ('STUDENT','STUDENT_PAR');
此时,临时表(及其索引)已成为“真实”表,并且它们的名称已在名称词典中切换。
8.重命名所有约束和索引以匹配原始名称
--drop中间表或者rename原来的约束
a.drop table STUDENT_PAR;
b.
ALTER TABLE STUDENT_PAR RENAME CONSTRAINT U_1 TO U_1_20210411;
ALTER TABLE STUDENT_PAR RENAME CONSTRAINT C_1 TO C_1_20210411;
ALTER INDEX S_NAME_IDX RENAME TO S_NAME_IDX_20210411;
ALTER INDEX U_1 RENAME TO U_1_20210411;
--rename 新分区表的约束和索引
ALTER TABLE STUDENT RENAME CONSTRAINT U_1_PAR TO U_1;
ALTER TABLE STUDENT RENAME CONSTRAINT C_1_PAR TO C_1;
ALTER INDEX S_NAME_IDX_PAR RENAME TO S_NAME_IDX;
ALTER INDEX U_1_PAR RENAME TO U_1;
--查看索引,约束名称是否正确
select table_name,index_name from user_indexes where table_name in ('STUDENT','STUDENT_PAR') order by table_name;
TABLE_NAME		       INDEX_NAME
STUDENT 		       S_NAME_IDX
STUDENT 		       SYS_C0011401
STUDENT 		       U_1
STUDENT_PAR		       S_NAME_IDX_20210411
STUDENT_PAR		       U_1_20210411
STUDENT_PAR		       SYS_C0011395
SQL> desc stu
 Name					   Null?    Type
 S_SEX						    VARCHAR2(8)
 S_BIRDATE					    DATE
 S_PHONE					    NUMBER
