关于PDB的几种启动方式
Lucifer三思而后行 发表于 2021/10/28 10:02:01 2021/10/28
【摘要】 自从12C开始支持pdb以来,我们多多少少的接触或是使用了ORACLE的CDB+PDB的模式,对于数据库实例开启后,PDB为mount状态,需要再次开启,我想大家应该也觉得不是很方便。下面就来聊聊关于PDB启动的几种方式: 一、手动启动打开数据库实例时,默认PDB是mounted状态,需要手动执行命令打开PDB:SQL> show pdbs CON_ID CON_NAME OP...
下面就来聊聊关于PDB启动的几种方式:
一、手动启动
SQL> show pdbs
    CON_ID CON_NAME			  OPEN MODE  RESTRICTED
	 2 PDB$SEED			  READ ONLY  NO
	 3 ORCL 			  MOUNTED
--启动所有PDB
SQL> alter pluggable database all open;
Pluggable database altered.
SQL> show pdbs
	 3 ORCL 			  READ WRITE NO
这个方法,最为常见,但是每次开库都要去手动执行,在当今自动化运维的社会,显得很不自动化,如果为RAC数据库,需要每个实例都手动去开启。
二、触发器启动
--创建触发器,cdb启动时,open所有的pdb
CREATE TRIGGER open_all_pdbs
   AFTER STARTUP
   ON DATABASE
BEGIN
   EXECUTE IMMEDIATE 'alter pluggable database all open';
END open_all_pdbs;
  7  /
Trigger created.
--查看触发器
SQL> select owner,TRIGGER_NAME,TRIGGER_TYPE from dba_triggers where owner='SYS' and TRIGGER_NAME='OPEN_ALL_PDBS';
OWNER		     TRIGGER_NAME	  TRIGGER_TYPE
SYS		     OPEN_ALL_PDBS	  AFTER EVENT
SQL> select text from all_source where type='TRIGGER' AND name='OPEN_ALL_PDBS';
TEXT
   AFTER STARTUP
   ON DATABASE
BEGIN
END open_all_pdbs;
6 rows selected.
--测试触发器是否生效
SQL> show pdbs
--关闭所有pdb
SQL> alter pluggable database all close;
--查看pdb是否全部关闭
SQL> show pdbs
	 3 ORCL 			  MOUNTED
--关闭数据库实例
SQL> shutdown immediate
Database closed.
Database dismounted.
ORACLE instance shut down.
--启动数据库实例
SQL> startup
ORACLE instance started.
Total System Global Area 3355441944 bytes
Fixed Size		    9141016 bytes
Variable Size		  704643072 bytes
Database Buffers	 2634022912 bytes
Redo Buffers		    7634944 bytes
Database mounted.
Database opened.
--pdb已自动启动
SQL> show pdbs
三、SAVE STATE
通过设置视图DBA_PDB_SAVED_STATES来控制PDB的启动模式:
--这里我们先DROP触发器
SQL> drop trigger OPEN_ALL_PDBS;
Trigger dropped.
SQL>
no rows selected
no rows selected
--设置state为open
SQL> show pdbs
SQL>
--记录当前所有pdb的启动状态
SQL> alter pluggable database all save state;
SQL> set line222
SQL> col con_name for a20
SQL> col instance_name for a20
SQL> select * from dba_pdb_saved_states;
    CON_ID CON_NAME		INSTANCE_NAME		CON_UID GUID				 STATE		RES
	 3 ORCL 		lucifer 	      251291369 BF269544BE8B17F9E053AC01A8C0447F OPEN		NO
--重启数据库实例
Database closed.
SQL> startup
Database mounted.
Database opened.
--PDB已自动启动
SQL> show pdbs
--如何取消自动启动
--先关闭pdb
SQL> alter pluggable database ORCL close;
SQL> show pdbs
	 3 ORCL 			  MOUNTED
--记录当前关闭状态
SQL> alter pluggable database ORCL save state;
no rows selected
--重启数据库实例
Database closed.
SQL> startup
Database mounted.
Database opened.
--pdb为mounted状态
SQL> show pdbs
	 3 ORCL 			  MOUNTED
总结:
三种方式都可以打开PDB,孰优孰劣大家自可斟酌。
个人建议是第三种方式,从12C开始就可以支持,设置简单,方便快捷,缺点是基于实例的,如果是RAC需要实例都需要去保存一下。不像触发器是基于数据库的,当然触发器可以是万能的。
