ORACLE12CR2 RAC安装部署(REDHAT7.6)六、建库以及收尾工作
Lucifer三思而后行 发表于 2021/10/28 09:50:54 2021/10/28
【摘要】 建库dbca报错:[BasicStep.handleNonIgnorableError:510]  ORA-01031: insufficient privileges##怀疑可能是oracle用户缺少asmadmin组,授予组之后,点击ignoreusermod -a -G asmadmin oracleCDB实例创建完成。 创建PDB:SQL> create pluggable dat...
建库
dbca
CDB实例创建完成。
创建PDB:
SQL> create pluggable database fdcdb admin user admin identified by oracle;
Pluggable database created.
SQL> show pdbs
    CON_ID CON_NAME                       OPEN MODE  RESTRICTED
         2 PDB$SEED                       READ ONLY  NO
         4 FDCDB                          MOUNTED
SQL> alter pluggable database all open;
Pluggable database altered.
SQL> show pdbs
         4 FDCDB                          READ WRITE NO
SQL> alter session set container=fdcdb;
Session altered.
SQL> show user
USER is "SYS"
SQL> show con_name
CON_NAME
FDCDB
SQL> grant dba to admin;
Grant succeeded.
启动PDB的几种方式:
--1.手动登录每个节点去启动pdb
--节点一启动pdb
sqlplus / as sysdba
show pdbs
--启动单个pdb
alter pluggable database fdcdb open;
--启动所有pdb
--此时节点二的pdb仍然是mount状态
--需要再次手动启动
--2.创建触发器PDB随CDB启动
--使用SYS用户创建如下触发器即可:
CREATE TRIGGER open_all_pdbs
   AFTER STARTUP
   ON DATABASE
BEGIN
   EXECUTE IMMEDIATE 'alter pluggable database all open';
END open_all_pdbs;
添加TNS:
cat <<EOF >> /u01/app/oracle/product/12.2.0/db/network/admin/tnsnames.ora
FDCDB =
  (DESCRIPTION =
    (ADDRESS = (PROTOCOL = TCP)(HOST = fdcdb01)(PORT = 1521))
    (CONNECT_DATA =
      (SERVER = DEDICATED)
      (SERVICE_NAME = fdcdb)
EOF
测试连接:
[oracle@fdcdb02 ~]$ sqlplus admin/oracle@fdcdb
SQL*Plus: Release 12.2.0.1.0 Production on Fri Apr 2 12:29:54 2021
Copyright (c) 1982, 2016, Oracle.  All rights reserved.
Connected to:
Oracle Database 12c Enterprise Edition Release 12.2.0.1.0 - 64bit Production
SQL>
SQL>
SQL> show con_name
CON_NAME
FDCDB
SQL> show user
USER is "ADMIN"
七、检查集群、数据库、监听运行情况
1、集群运行情况检查:
[root@fdcdb01 ~]# crsctl check crs
CRS-4638: Oracle High Availability Services is online
CRS-4537: Cluster Ready Services is online
CRS-4529: Cluster Synchronization Services is online
CRS-4533: Event Manager is online
[root@fdcdb01 ~]# crsctl stat res -t
Name           Target  State        Server                   State details
Local Resources
ora.ASMNET1LSNR_ASM.lsnr
               ONLINE  ONLINE       fdcdb01                  STABLE
               ONLINE  ONLINE       fdcdb02                  STABLE
ora.ASMNET2LSNR_ASM.lsnr
ora.DATA.dg
ora.LISTENER.lsnr
ora.OCR.dg
ora.net1.network
ora.ons
ora.proxy_advm
               OFFLINE OFFLINE      fdcdb01                  STABLE
               OFFLINE OFFLINE      fdcdb02                  STABLE
Cluster Resources
ora.LISTENER_SCAN1.lsnr
      1        ONLINE  ONLINE       fdcdb02                  STABLE
ora.MGMTLSNR
      1        OFFLINE OFFLINE                               STABLE
ora.asm
      1        ONLINE  ONLINE       fdcdb01                  Started,STABLE
      2        ONLINE  ONLINE       fdcdb02                  Started,STABLE
      3        OFFLINE OFFLINE                               STABLE
ora.cvu
ora.fdcdb01.vip
      1        ONLINE  ONLINE       fdcdb01                  STABLE
ora.fdcdb02.vip
ora.fdcinst.db
      1        ONLINE  ONLINE       fdcdb01                  Open,HOME=/u01/app/o
                                                             /db,STABLE
      2        ONLINE  ONLINE       fdcdb02                  Open,HOME=/u01/app/o
                                                             /db,STABLE
ora.qosmserver
ora.scan1.vip
2、数据库运行情况
[oracle@fdcdb01 ~]$ srvctl status database -d fdcinst
Instance fdcinst1 is running on node fdcdb01
Instance fdcinst2 is running on node fdcdb02
SQL> select inst_id,instance_name,status from gv$instance;
   INST_ID INSTANCE_NAME    STATUS
         1 fdcinst1         OPEN
         2 fdcinst2         OPEN
col name for a30
SQL> select con_id,name,open_mode from gv$pdbs;
    CON_ID NAME                           OPEN_MODE
         4 FDCDB                          READ WRITE
         4 FDCDB                          READ WRITE
3、监听运行情况
[oracle@fdcdb01 ~]$ ps -ef|grep tns
root       332     2  0 Apr01 ?        00:00:00 [netns]
oracle   20413 16511  0 13:57 pts/2    00:00:00 grep --color=auto tns
grid     23865     1  0 Apr01 ?        00:00:11 /u01/app/12.2.0/grid/bin/tnslsnr ASMNET2LSNR_ASM -no_crs_notify -inherit
grid     23869     1  0 Apr01 ?        00:00:11 /u01/app/12.2.0/grid/bin/tnslsnr ASMNET1LSNR_ASM -no_crs_notify -inherit
grid     24594     1  0 Apr01 ?        00:00:01 /u01/app/12.2.0/grid/bin/tnslsnr LISTENER -no_crs_notify -inherit
[oracle@fdcdb01 ~]$ srvctl status listener
Listener LISTENER is enabled
Listener LISTENER is running on node(s): fdcdb01,fdcdb02
[oracle@fdcdb01 ~]$ srvctl status listener -l ASMNET1LSNR_ASM
Listener ASMNET1LSNR_ASM is enabled
Listener ASMNET1LSNR_ASM is running on node(s): fdcdb01,fdcdb02
[oracle@fdcdb01 ~]$ srvctl status listener -l ASMNET2LSNR_ASM
Listener ASMNET2LSNR_ASM is enabled
Listener ASMNET2LSNR_ASM is running on node(s): fdcdb01,fdcdb02
[grid@fdcdb02 ~]$ srvctl status scan_listener
SCAN Listener LISTENER_SCAN1 is enabled
SCAN listener LISTENER_SCAN1 is running on node fdcdb02
八、配置ORACLE参数
1、用户名密码永久生效
--查看用户天数限制
set line222
col profile for a20
col RESOURCE_NAME for a20
col LIMIT for a20
SELECT * FROM dba_profiles WHERE profile ='DEFAULT' AND resource_name = 'PASSWORD_LIFE_TIME';
PROFILE              RESOURCE_NAME        RESOURCE LIMIT                COM INH IMP
DEFAULT              PASSWORD_LIFE_TIME   PASSWORD 180                  NO  NO  NO
--更改为无限制
ALTER PROFILE DEFAULT LIMIT PASSWORD_LIFE_TIME UNLIMITED;
SQL> ALTER PROFILE DEFAULT LIMIT PASSWORD_LIFE_TIME UNLIMITED;
Profile altered.
--已修改为无限制
SQL> SELECT * FROM dba_profiles WHERE profile ='DEFAULT' AND resource_name = 'PASSWORD_LIFE_TIME';
DEFAULT              PASSWORD_LIFE_TIME   PASSWORD UNLIMITED            NO  NO  NO
--修改PDB的用户密码天数限制
Profile altered.
2、sqlnet.ora配置允许低版本client连接
cat <<EOF >>$ORACLE_HOME/network/admin/sqlnet.ora
SQLNET.ALLOWED_LOGON_VERSION_CLIENT=8
SQLNET.ALLOWED_LOGON_VERSION_SERVER=8
EOF
3、开启归档、配置删除归档脚本
--设置归档路径
SQL> alter system set log_archive_dest_1='location=+DATA' sid='*';
System altered.
SQL> show parameter log_archive_dest_1
NAME                                 TYPE        VALUE
log_archive_dest_1                   string      location=+DATA
log_archive_dest_10                  string
log_archive_dest_11                  string
log_archive_dest_12                  string
log_archive_dest_13                  string
log_archive_dest_14                  string
log_archive_dest_15                  string
log_archive_dest_16                  string
log_archive_dest_17                  string
log_archive_dest_18                  string
log_archive_dest_19                  string
SQL> archive log list
Database log mode              No Archive Mode
Automatic archival             Disabled
Archive destination            +DATA
Oldest online log sequence     8
Current log sequence           9
--查看pdbs启动状态
SQL> show pdbs
SQL>
--关闭一节点所有pdb
SQL> alter pluggable database all close;
SQL> show pdbs
         4 FDCDB                          MOUNTED
--查询节点2的pdbs状态
SQL> select inst_id,con_id,name,open_mode from gv$pdbs;
   INST_ID     CON_ID NAME        OPEN_MODE
         1          2 PDB$SEED        READ ONLY
         1          4 FDCDB        MOUNTED
         2          2 PDB$SEED        READ ONLY
         2          4 FDCDB        READ WRITE
--关闭节点2的pdbs
--关闭数据库实例fdcinst
[oracle@fdcdb02 ~]$ srvctl stop database -d fdcinst -o immediate
--开启到mount状态
[oracle@fdcdb02 ~]$ srvctl start database -d fdcinst -o mount
--开启归档模式
SQL> select open_mode from v$database;
OPEN_MODE
MOUNTED
Database log mode              Archive Mode
Automatic archival             Enabled
Oldest online log sequence     1
Next log sequence to archive   1
Current log sequence           1
--两节点开启到open状态
alter database open;
--布置归档删除脚本
mkdir -p /home/oracle/script/log
vi /home/oracle/script/del_arch.sh
#!/bin/bash
. ~/.bash_profile
DAY_TAG=`date +"%Y-%m-%d"`
rman target / nocatalog msglog /home/oracle/pst/script/log/del_arch_$DAY_TAG.log<<EOF
crosscheck archivelog all;
delete noprompt archivelog until time '(sysdate-7)';
delete noprompt force archivelog until time 'SYSDATE-10';
EOF
--写入crontab
chmod +x /home/oracle/script/del_arch.sh
echo "00 00 * * * /home/oracle/script/del_arch.sh" >> /var/spool/cron/oracle
4、配置ORACLE数据库随主机启动自动启动
--查看当前数据库是否随主机启动
[root@fdcdb01 ~]# crsctl stat res ora.fdcinst.db -p|grep AUTO_START
AUTO_START=restore
--设置随主机启动
[root@fdcdb01 ~]# crsctl modify res ora.fdcinst.db -attr AUTO_START=always -unsupported
AUTO_START=always
