ORACLE12CR2 RAC安装部署(REDHAT7.6)二、Grid软件安装
Lucifer三思而后行 发表于 2021/10/25 17:57:48 2021/10/25
【摘要】 安装GRID软件 1、解压缩Grid软件chown -R grid:oinstall /softsu - grid -c "unzip /soft/linuxx64_12201_grid_home.zip -d /u01/app/12.2.0/grid" 2、RPM CVU 安装rpm -ivh /soft/compat-libstdc++-33-3.2.3-72.el7.x86_64.r...
安装GRID软件
1、解压缩Grid软件
2、RPM CVU 安装
rpm -ivh /soft/compat-libstdc++-33-3.2.3-72.el7.x86_64.rpm
rpm -ivh /soft/cvuqdisk-1.0.10-1.rpm
3、配置ssh互信
#SSH配置 (自root用户下执行)
/u01/app/12.2.0/grid/oui/prov/resources/scripts/sshUserSetup.sh -user oracle -hosts "fdcdb01 fdcdb02 fdcdb01-priv1 fdcdb01-priv2 fdcdb02-priv1 fdcdb02-priv2" -advanced -noPromptPassphrase -exverify -confirm
/u01/app/12.2.0/grid/oui/prov/resources/scripts/sshUserSetup.sh -user grid -hosts "fdcdb01 fdcdb02 fdcdb01-priv1 fdcdb01-priv2 fdcdb02-priv1 fdcdb02-priv2" -advanced -noPromptPassphrase -exverify -confirm
4、安装前runcluvfy检查
su - grid -c "/u01/app/12.2.0/grid/runcluvfy.sh stage -pre crsinst -n fdcdb01,fdcdb02 -fixup -verbose"
Pre-check for cluster services setup was unsuccessful on all the nodes.
Failures were encountered during execution of CVU verification request "stage -pre crsinst".
Verifying Network Time Protocol (NTP) ...FAILED
CVU operation performed:      stage -pre crsinst
Date:                         Apr 2, 2021 5:27:37 AM
CVU home:                     /u01/app/12.2.0/grid/
User:                         grid
5、安装GRID软件
Notes:提前剧透下,一定要看:如果安装命令是执行./gridSetup.sh,执行root.sh时,__必然报错:CLSRSC-400: A system reboot is required to continue installing.需要卸载重新安装。
解决方案:通过12C新特性 -applyPSU 提前打上最新PSU补丁修复该BUG,前提是需要更换OPatch包:
**How to Apply a Grid Infrastructure Patch Before Grid Infrastructure Configuration (before root.sh or rootupgrade.sh or gridsetup.bat) is Executed (Doc ID 1410202.1)    **
./gridSetup.sh -applyPSU /soft/32226491
以下是完整的安装以及填坑步骤:
**12.2: PRVG-0802 : Storage type for path “/dev/mapper/asm011p1” could not be determined (Doc ID 2251322.1)    **
[root@fdcdb02 dev]# ll /etc/multipath.conf
-rw------- 1 root root 3209 Apr  1 14:22 /etc/multipath.conf
[root@fdcdb02 dev]# chmod 644 /etc/multipath.conf
-rw-r--r-- 1 root root 3209 Apr  1 14:22 /etc/multipath.conf
