ORACLE12CR2 RAC安装部署(REDHAT7.6)一、环境配置
Lucifer三思而后行 发表于 2021/10/25 17:52:06 2021/10/25
【摘要】 搭配官方文档和mos文档食用更佳。Oracle Database (RDBMS) on Unix AIX,HP-UX,Linux,Solaris and MS Windows Operating Systems Installation and Configuration Requirements Quick Reference (12.1/12.2/18c/19c) (Doc ID 158...
搭配官方文档和mos文档食用更佳。
Oracle Database (RDBMS) on Unix AIX,HP-UX,Linux,Solaris and MS Windows Operating Systems Installation and Configuration Requirements Quick Reference (12.1/12.2/18c/19c) (Doc ID 1587357.1)
https://docs.oracle.com/en/database/oracle/oracle-database/12.2/cwlin/grid-infrastructure-installation-and-upgrade-guide-linux.pdf
Patch Set Updates for Oracle Products (Doc ID 854428.1)
Database 12.2.0.1 Proactive Patch Information (Doc ID 2285557.1)
How to Apply a Grid Infrastructure Patch Before Grid Infrastructure Configuration (before root.sh or rootupgrade.sh or gridsetup.bat) is Executed (Doc ID 1410202.1)
##以下是遇到的坑,以及MOS文章解决方案:
1、ASM device sharedness check
Shared Storage Accessibility:/dev/asm_ocr ...FAILED (PRVG-11506)
可参照MOS文档:
12.2: PRVG-0802 : Storage type for path "/dev/mapper/asm011p1" could not be determined (Doc ID 2251322.1)
2、CLSRSC-400: A system reboot is required to continue installing.
可参照MOS文档:
ALERT: root.sh Fails With "CLSRSC-400" While Installing GI 12.2.0.1 on RHEL or OL with RedHat Compatible Kernel (RHCK) 7.3 (Doc ID 2284463.1)
3、kgfnGetConnDetails requires 4 parameters at/u01/app/12.2.0/grid/lib/asmcmdbase.pm line 5704.
可参照MOS文档:
install.sh Hung And root.sh Is Failing At asmcmd lsdg --suppressheader While Installing A Zone With Clusterware (Doc ID 2414241.1)
ASMCMD Failing With "KGFNGETCONNDETAILS Requires 4 Parameters at <GI_HOME>/lib/asmcmdbase.pm (Doc ID 2748316.1)
0、参数准备
1、HostName、ClusterName、ScanName
2、IP(Public,Private,Virtual,Scan)
3、ASMDISK(OCR,ARCH,DATA;Redundancy)
4、ORACLE_SID
5、User Password(root,oracle,grid)
6、CharacterSet(CharacterSet,NationalCharacterSet)
7、Software(ORACLE,GRID,REDHAT)
8、ISCDB
一、环境检查
1、Release Info
dmidecode | grep "Product Name"
more /etc/system-release
2、Kernel Info
uname -r
3、CPU Info
grep "model name" /proc/cpuinfo
grep "model name" /proc/cpuinfo | wc -l
4、Memory Info
##查看内存条数、大小
dmidecode|grep -P -A5 "Memory\s+Device"|grep Size|grep -v Range
grep MemTotal /proc/meminfo | awk '{print $2}'
5、Swap Info
grep SwapTotal /proc/meminfo | awk '{print $2}'
6、ZONE
timedatectl | grep zone
7、tmp Info
df -h /tmp
8、Disk Info
df -h
lsblk
9、Network Info
nmcli connection show
ip addr
##查看网卡驱动的速率
iplink=`cat /proc/net/dev | awk '{i++; if(i>2){print $1}}' | sed 's/^[\t]*//g' | sed 's/[:]*$//g'`
for i in $iplink
do
printf "%s %s\n" "$i :"
ethtool -i $i
10、Transparent HugePages
cat /sys/kernel/mm/transparent_hugepage/enabled
cat /sys/kernel/mm/transparent_hugepage/defrag
11、vm.min_free_kbytes
cat /proc/sys/vm/min_free_kbytes
12、vm.swappiness
cat /proc/sys/vm/swappiness
13、SELINUX
grep ^SELINUX= /etc/selinux/config
14、Firewalld
systemctl status firewalld | grep Active
15、avahi-daemon
systemctl status avahi-daemon | grep Active
16、NUMA
grep NUMA /proc/cmdline
二、环境配置
1、RPM PACKAGE
关于oracle-database-server-12cR2-preinstall
yum install oracle-database-server-12cR2-preinstall-1.0-5.el7.src.rpm
oracle-database-server-12cR2-preinstall为我们做了什么
(1)自动安装oracle所需的RPM包
(2)自动创建oracle用户和dba、oinstall组
(3)自动配置/etc/sysctl.conf内核参数
(4)自动配置/etc/security/limits.conf参数
(5)关闭NUMA=OFF   (关闭非一致内存访问)
(6)关闭NOZEROCONF=yes
(7)修改系统启动版本信息
摘自官方MOS文档:
_**Oracle Database (RDBMS) on Unix AIX,HP-UX,Linux,Solaris and MS Windows Operating Systems Installation and Configuration Requirements Quick Reference (12.1/12.2/18c/19c) (Doc ID 1587357.1)    **_Oracle Linux 7 / RHEL 7
Oracle Linux 7/RHEL 7
OS Version
Patches/Packages
Kernel settings
Oracle Linux 7 with the Unbreakable Enterprise Kernel 3: 3.8.13-35.3.1.el7uek.x86_64 or later
Oracle Linux 7.2 with the Unbreakable Enterprise Kernel 4: 4.1.12-32.2.3.el7uek.x86_64 or later
Oracle Linux 7 with the Red Hat Compatible kernel: 3.10.0-123.el7.x86_64 or later
Red Hat Enterprise Linux 7: 3.10.0-123.el7.x86_64 or later
Reference :
Note 1961997.1
binutils-2.23.52.0.1-12.el7 (x86_64)
compat-libcap1-1.10-3.el7 (x86_64)
compat-libstdc++-33-3.2.3-71.el7 (i686)
compat-libstdc++-33-3.2.3-71.el7 (x86_64)
glibc-2.17-36.el7 (i686)
glibc-2.17-36.el7 (x86_64)
glibc-devel-2.17-36.el7 (i686)
glibc-devel-2.17-36.el7 (x86_64)
ksh
libaio-0.3.109-9.el7 (i686)
libaio-0.3.109-9.el7 (x86_64)
libaio-devel-0.3.109-9.el7 (i686)
libaio-devel-0.3.109-9.el7 (x86_64)
libX11-1.6.0-2.1.el7 (i686)
libX11-1.6.0-2.1.el7 (x86_64)
libXau-1.0.8-2.1.el7 (i686)
libXau-1.0.8-2.1.el7 (x86_64)
libXi-1.7.2-1.el7 (i686)
libXi-1.7.2-1.el7 (x86_64)
libXtst-1.2.2-1.el7 (i686)
libXtst-1.2.2-1.el7 (x86_64)
libgcc-4.8.2-3.el7 (i686)
libgcc-4.8.2-3.el7 (x86_64)
libstdc++-4.8.2-3.el7 (i686)
libstdc++-4.8.2-3.el7 (x86_64)
libstdc++-devel-4.8.2-3.el7 (i686)
libstdc++-devel-4.8.2-3.el7 (x86_64)
libxcb-1.9-5.el7 (i686)
libxcb-1.9-5.el7 (x86_64)
make-3.82-19.el7 (x86_64)
nfs-utils-1.3.0-0.21.el7.x86_64 (for Oracle ACFS)
net-tools-2.0-0.17.20131004git.el7 (x86_64) (for Oracle RAC and Oracle Clusterware)
smartmontools-6.2-4.el7 (x86_64)
sysstat-10.1.5-1.el7 (x86_64)
Ensure that OpenSSH is installed on your servers. OpenSSH is the required SSH software.
semmsl    250
semmns    32000
semopm    100
semmni    128
shmall     40 percent of the size of physical memory in pages
shmmax     Half the size of physical memory in bytes
shmmni     4096
panic_on_oops     1
file-max     6815744
aio-max-nr     1048576
ip_local_port_range     Minimum: 9000
                                Maximum: 65500
rmem_default     262144
rmem_max     4194304
wmem_default     262144
wmem_max     1048576
ip_local_port_range 32768 61000
oracle   soft    nproc    2047 (at least)
oracle   hard   nproc   16384 (at least)
oracle   soft    nofile    1024 (at least)
oracle   hard   nofile    65536 (at least)
oracle   soft    stack    10240 KB (at least)
oracle   hard   stack    32768 KB (at most)
memlock
Soft: at least 90 percent of the current RAM when HugePages memory is enabled and at least 3145728 KB (3 GB) when HugePages memory is disabled
hard: at least 90 percent of the current RAM when HugePages memory is enabled and at least 3145728 KB (3 GB) when HugePages memory is disabled
以下摘自官方文档:
Operating System Requirements for x86-64 Linux Platforms
Red Hat Enterprise Linux 7 Distributions for x86-64:
1、SSH Requirement Ensure that OpenSSH is installed on your servers.
2、Red Hat Enterprise Linux 7: 3.10.0-123.el7.x86_64 or later
3、he following packages (or later versions) must be installed:
bc
ksh
libXrender (i686)
libXrender (x86_64)
libXrender-devel (i686)
libXrender-devel (x86_64)
--redhat内核支持
--镜像挂载
mount /dev/cdrom /mnt
mv /etc/yum.repos.d/* /tmp/
echo "[local]" >> /etc/yum.repos.d/local.repo
echo "name = local" >> /etc/yum.repos.d/local.repo
echo "baseurl = file:///mnt/" >> /etc/yum.repos.d/local.repo
echo "enabled = 1" >> /etc/yum.repos.d/local.repo
echo "gpgcheck = 0" >> /etc/yum.repos.d/local.repo
yum clean all
yum repolist all
--安装图形化界面
yum groupinstall -y "Server with GUI"
--安装oracle所需依赖包
yum install -y bc binutils compat-libcap1 compat-libstdc++ glibc glibc-devel ksh libaio libaio-devel libgcc libstdc++ libstdc++-devel libxcb libX11 libXau libXi libXtst libXrender libXrender-devel make net-tools nfs-utils smartmontools sysstat openssh-clients
--检查是否安装成功
rpm -q --qf '%{NAME}-%{VERSION}-%{RELEASE} (%{ARCH})\n' bc binutils compat-libcap1 compat-libstdc++ glibc glibc-devel ksh libaio libaio-devel libgcc libstdc++ libstdc++-devel libxcb libX11 libXau libXi libXtst libXrender libXrender-devel make net-tools nfs-utils smartmontools sysstat openssh-clients
--需要额外安装compat-libstdc++-33-3.2.3-72.el7.x86_64.rpm包
rpm -ivh compat-libstdc++-33-3.2.3-72.el7.x86_64.rpm
2、Configuring Kernel Parameters for Linux
The /etc/sysctl.conf file has been deprecated
/etc/sysctl.conf文件在OL7和RHEL7中已被弃用
cat <<EOF >> /etc/sysctl.d/97-oracledatabase-sysctl.conf
fs.aio-max-nr = 1048576
fs.file-max = 6815744
kernel.shmall = 2097152 ##equal SGA,mininum is 2097152,advise 40 percent of the size ofphysical memory in pages
kernel.shmmax = 4294967295 ##advise Half the size of physical memory in bytes
kernel.shmmni = 4096
kernel.sem = 250 32000 100 128
net.ipv4.ip_local_port_range = 9000 65500
net.core.rmem_default = 262144
net.core.rmem_max = 4194304
net.core.wmem_default = 262144
net.core.wmem_max = 1048576
net.ipv4.conf.eno5.rp_filter = 2
net.ipv4.conf.eno6.rp_filter = 2
EOF
3、Resource Limits
memlock
cat <<EOF >>/etc/security/limits.conf
grid soft nofile 1024
grid hard nofile 65536
grid soft stack 10240
grid hard stack 32768
grid soft nproc 2047
grid hard nproc 16384
###如果内存小于8G,下面大内存页配置可忽略
grid hard memlock 3145728
grid soft memlock 3145728
oracle hard memlock 3145728
oracle soft memlock 3145728
EOF
cat <<EOF >>/etc/pam.d/login
session required pam_limits.so
session required /lib64/security/pam_limits.so
EOF
4、USER CREATE
Creating the OSASM Group
# groupadd -g 54329 asmadmin
Creating the OSDBA for ASM Group
# /usr/sbin/groupadd -g 54327 asmdba
Creating the OSOPER for ASM Group
# /usr/sbin/groupadd -g 54328 asmoper
Creating the OSDBA Group for Database Installations
# /usr/sbin/groupadd -g 54322 dba
Creating an OSOPER Group for Database Installations
# groupadd -g 54323 oper
Creating the OSBACKUPDBA Group for Database Installations
# /usr/sbin/groupadd -g 54324 backupdba
Creating the OSDGDBA Group for Database Installations
# /usr/sbin/groupadd -g 54325 dgdba
Creating the OSKMDBA Group for Database Installations
# /usr/sbin/groupadd -g 54326 kmdba
Creating the OSRACDBA Group for Database Installations
# /usr/sbin/groupadd -g 54330 racdba
$ id oracle
uid=54321(oracle) gid=54321(oinstall) groups=54321(oinstall),54322(dba),54323(oper),54324(backupdba),54325(dgdba),54326(kmdba),54327(asmdba),54330(racdba)
$ id grid
uid=54331(grid) gid=54321(oinstall) groups=54321(oinstall),54322(dba),54327(asmdba),54328(asmoper),54329(asmadmin),54330(racdba)
##创建用户组
/usr/sbin/groupadd -g 54321 oinstall
/usr/sbin/groupadd -g 54323 oper
/usr/sbin/groupadd -g 54329 asmadmin
##创建用户
/usr/sbin/useradd -u 54321 -g oinstall -G dba,asmdba,backupdba,dgdba,kmdba,racdba oracle
/usr/sbin/useradd -u 54331 -g oinstall -G asmadmin,asmdba,asmoper,oper,dba grid
#修改密码,这边密码均设置为oracle,密码可以按自己需要修改
echo "oracle" |passwd grid --stdin
echo "oracle" |passwd oracle --stdin
5、Oracle Home and Oracle Base Directory CREATE
mkdir -p /u01/app/grid
mkdir -p /u01/app/12.2.0/grid
mkdir -p /u01/app/oracle/product/12.2.0/db
mkdir -p /u01/app/oraInventory
chown -R grid:oinstall /u01/app/grid
chown -R grid:oinstall /u01/app/12.2.0
chown -R grid:oinstall /u01/app/oraInventory
chown -R oracle:oinstall /u01/app/oracle
chmod -R 775 /u01
6、Disable Firewalld and SELLINUX
--关闭防火墙
systemctl stop firewalld
systemctl disable firewalld
--关闭selinux
sed -i 's/SELINUX=enforcing/SELINUX=disabled/g' /etc/selinux/config
7、HOSTS
cat >> /etc/hosts <<EOF
#Public IP
192.168.31.100	p12c01
192.168.31.101	p12c02
#Private IP
1.1.1.1	p12c01-priv1
1.1.1.2	p12c02-priv1
2.2.2.1	p12c01-priv2
2.2.2.2	p12c02-priv2
#Virtual IP
192.168.31.200	p12c01-vip
192.168.31.201	p12c02-vip
#SCAN IP
192.168.31.50	p12c-scan
EOF
8、Disable Transparent Hugepages & NUMA
For example, for Oracle Linux 7.3, the procedure to disable Transparent HugePages involves editing the /etc/default/grub file and then running the command grub2-mkconfig
sed -i 's/quiet/quiet transparent_hugepage=never numa=off/' /etc/default/grub
##重建grub 配置文件:
##fdisk -l可以查看主分区的Disk label type: gpt
##MBR 分区表
##grub2-mkconfig -o /etc/grub2.cfg\
##efi 引导模式,efi+GPT分区表
grub2-mkconfig -o /etc/grub2-efi.cfg
##reboot之后查看是否生效
numactl --hardware
dmesg|grep -i numa
cat /proc/cmdline
##临时生效
echo never >/sys/kernel/mm/transparent_hugepage/enabled
echo never >/sys/kernel/mm/transparent_hugepage/defrag
9、Disable NOZEROCONF
echo "NOZEROCONF=yes" >> /etc/sysconfig/network
10、Disable NetworkManager
systemctl stop NetworkManager.service
systemctl disable NetworkManager.service
11、Disable avahi-daemon
systemctl stop avahi-daemon.socket
systemctl stop avahi-daemon.service
systemctl disable avahi-daemon.service
ps -ef|grep avahi-daemon
12、Disable chronyd
By default, the NTP service available on Oracle Linux 7 and Red Hat Linux 7 is chronyd and the NTP service available on Oracle Linux 6 and Red Hat Linux 6 or lower is ntpd.
systemctl stop chronyd
systemctl disable chronyd
mv /etc/resolv.conf /etc/resolv.conf.bak
mv /etc/chrony.conf /etc/chrony.conf.bak
13、配置/dev/shm
cat <<EOF >> /etc/fstab
tmpfs /dev/shm tmpfs size=4G 0 0
EOF
mount -o remount /dev/shm
14、UDEV+MULTIPATH
##安装multipath
yum install -y device-mapper*
mpathconf --enable --with_multipathd y
##查看磁盘wwid
/usr/lib/udev/scsi_id -g -u /dev/sdb
--配置multipath.confc
cat <<EOF >> /etc/multipath.conf
defaults {
    user_friendly_names yes
blacklist {
  devnode "^sda"
multipaths {
  multipath {
  wwid "36000c299c61a189afae17172197fd20e"
  alias asm_OCR
  multipath {
  wwid "36000c29511ad8bc6c69c3d63a8f4e6c8"
  alias asm_DATA
EOF
--获取ENV{DM_UUID}
cd /dev/mapper
>udev_info
for i in `ls asm*`;
do
printf "%s %s\n" "$i" "$(udevadm info --query=all --name=/dev/mapper/$i |grep -i dm_uuid)">>udev_info;
done
--配置udev规则文件、99-oracle-asmdevices.rules文件(复制到节点二)
cat /dev/mapper/udev_info |while read line
do
dm_uuid=`echo $line |awk -F'=' '{print $2}'`;
disk_name=`echo $line|awk '{print $1}'`;
echo "KERNEL==\"dm-*\",ENV{DM_UUID}==\"${dm_uuid}\",SYMLINK+=\"asmdisks/${disk_name}\",OWNER=\"grid\",GROUP=\"asmadmin\",MODE=\"0660\"">>/etc/udev/rules.d/99-oracle-asmdevices.rules
done
--启动udev服务
udevadm control --reload-rules
udevadm trigger
--查看udev绑盘是否成功
ls -l /dev/asmdisks/*
15、环境变量设置
ROOT:
 cat >>/etc/profile <<"EOF"
################# Root Rrofile Add ############################
if [ $USER = "oracle" ] || [ $USER = "grid" ] || [ $USER = "root" ]; then
        if  [ $SHELL = "/bin/ksh" ];  then
              ulimit -p 16384
              ulimit -n 65536
        else
              ulimit -u 16384 -n 65536
        fi
fi
alias so='su - oracle'
alias sg='su - grid'
alias crsctl='/u01/app/11.2.0/grid/bin/crsctl'
################# Root Rrofile End ############################
EOF
GRID:
cat <<EOF >> /home/grid/.bash_profile
################ Grid Profile Add #########################
umask 022
export TMP=/tmp
export TMPDIR=\$TMP
export NLS_LANG=AMERICAN_AMERICA.$CharacterSet
export ORACLE_BASE=/u01/app/grid
export ORACLE_HOME=/u01/app/12.2.0/grid
export TNS_ADMIN=\$ORACLE_HOME/network/admin
export LD_LIBRARY_PATH=\$ORACLE_HOME/lib:/lib:/usr/lib
export ORACLE_SID=$GRID_SIDTemp
export PATH=/usr/sbin:\$PATH
export PATH=\$ORACLE_HOME/bin:\$ORACLE_HOME/OPatch:\$PATH
#alias sqlplus='rlwrap sqlplus'
#alias rman='rlwrap rman'
#alias lsnrctl='rlwrap lsnrctl'
#alias asmcmd='rlwrap asmcmd'
#alias adrci='rlwrap adrci'
alias sas='sqlplus / as sysasm'
################ Grid Profile End #########################
EOF
ORALCE:
  cat <<EOF >>/home/oracle/.bash_profile
################ Oracle Profile Add #########################
umask 022
export TMP=/tmp
export TMPDIR=\$TMP
export ORACLE_BASE=/u01/app/oracle
export ORACLE_HOME=\$ORACLE_BASE/product/12.2.0/db
export ORACLE_SID=orcl
alias sas='sqlplus / as sysdba'
#alias ggsci='rlwrap ggsci'
alias alert='tail -500f \$ORACLE_BASE/diag/rdbms/$ORACLE_SIDTemp/$ORACLE_SIDTemp/trace/alert_$ORACLE_SIDTemp.log|more'
################ Oracle Profile End #########################
EOF
Notes:安装前执行reboot。
