如何让部署到云平台上的 web 应用使用 Destination 服务
汪子熙 发表于 2021/10/24 22:03:55 2021/10/24
【摘要】 首先在SAP云平台里创建一个destination,维护service的end point:然后打开SAP云平台的WebIDE,创建一个新的文件夹和新的HTML5 Application Descriptor:将下列内容粘贴到neo-app.json去:{ "welcomeFile": "index.html", "routes": [ { "path": "/resou...
  "routes": [
      "path": "/resources",
      "target": {
        "type": "service",
        "name": "sapui5",
        "entryPath": "/resources"
      "description": "SAPUI5 Resources"
      "path": "/test-resources",
      "target": {
        "type": "service",
        "name": "sapui5",
        "entryPath": "/test-resources"
      "description": "SAPUI5 Test Resources"
      "path": "/distance",
      "target": {
        "type": "destination",
        "name": "google_map"
      "description": "Google map"
新建一个index.html, 输入以下内容:
<a href="distance/xml?origins=Walldorf&destinations=Paris">
Distance from Walldorf to Paris:</a>
测试该应用,点击超链接:
会发现第一步创建的destination已经生效了。
打开SAP云平台上的SAP HANA Web-Based Development Workbench超链接:
遇到错误信息:403 - Forbidden - The server refused to fulfill the request.
solution
打开SAP HANA Cockpit, 选择OK:
添加下列权限:
(1) sap.hana.admin.roles::Administrator
(2) sap.hana.ide.roles::TraceViewer
(3) sap.hana.ide.roles::SecurityAdmin
之后即可打开。
使用HANA Web-based Development Workbench创建最简单的Server Side JavaScript
服务器端的JavaScript, 看下wikipedia的介绍:
https://en.wikipedia.org/wiki/JavaScript#Server-side_JavaScript
Server-side JavaScript
In December 1995, soon after releasing JavaScript for browsers, Netscape introduced an implementation of the language for server-side scripting with Netscape Enterprise Server.
Since 1996, the IIS web-server has supported Microsoft’s implementation of server-side Javascript – JScript – in ASP and .NET pages.
Since the mid-2000s, additional server-side JavaScript implementations have been introduced, such as Node.js in 2009.
再看SAP的Server Side(服务器端) JavaScript解决方案:SAP Extended Application Service
打开SAP HANA Web-Based Development Workbench:
创建一个新的package:
创建一个新的Application:
创建一个新的文件test.xsjs, 内容如下:
var userInput = $.request.parameters.get("userStuff");
$.response.contentType = "text/html";
$.response.setBody(userInput);
这个hello world应用是一个简单的echo应用:将用户通过url传进来的数据直接输出。
测试:
