使用云平台的 destination 服务消费 Internet 上的 OData service
汪子熙 发表于 2021/10/24 21:46:16 2021/10/24
【摘要】 通过SAP云平台上的destination我们可以消费Internet上的OData service或者其他通过HTTP方式暴露出来的服务。创建一个新的destination:维护如下属性:点击Check Connection确保该destination正常工作:在WebIDE里新建一个Fiori Worklist Application:从Service url选择之前创建好的destin...
创建一个新的destination:
维护如下属性:
从Service url选择之前创建好的destination:
在Object Collection里选择Alphabetical_list_of_products,Object Collection ID选择Product ID:
Fiori 应用创建成功之后,从右键菜单里选择Run->Run As->Web Application:
这样就实现了从SAP云平台消费Internet上的OData service的需求。
ABAP和Java的destination和JNDI
Netweaver里使用事务码SM59创建Destination:
Java
新建一个destination:
[外链图片转存失败,源站可能有防盗链机制,建议将图片保存下来直接上传(img-B3nrP4Tg-1635083096529)(https://upload-images.jianshu.io/upload_images/2085791-0b955d4f581ce6bc.png?imageMogr2/auto-orient/strip|imageView2/2/w/1240)]
测试代码:
try {
            Context ctx = new InitialContext();
            ConnectivityConfiguration configuration = (ConnectivityConfiguration) ctx.lookup("java:comp/env/connectivityConfiguration");
            DestinationConfiguration destConfiguration = configuration.getConfiguration(destinationName);
            if (destConfiguration == null) {
                response.sendError(HttpServletResponse.SC_INTERNAL_SERVER_ERROR,
                        String.format("Destination %s is not found. Hint:"
                                + " Make sure to have the destination configured.", destinationName));
                return;
            // Get the destination URL
            String value = destConfiguration.getProperty("URL");
            URL url = new URL(value + "xml?origins=Walldorf&destinations=Paris");
            String proxyType = destConfiguration.getProperty("ProxyType");
            Proxy proxy = getProxy(proxyType);
            urlConnection = (HttpURLConnection) url.openConnection(proxy);
            injectHeader(urlConnection, proxyType);
            // Copy content from the incoming response to the outgoing response
            InputStream instream = urlConnection.getInputStream();
            OutputStream outstream = response.getOutputStream();
            copyStream(instream, outstream);
        } catch (Exception e) {
            // Connectivity operation failed
            String errorMessage = "Connectivity operation failed with reason: "
                    + e.getMessage()
                    + ". See "
                    + "logs for details. Hint: Make sure to have an HTTP proxy configured in your "
                    + "local environment in case your environment uses "
                    + "an HTTP proxy for the outbound Internet "
                    + "communication.";
            LOGGER.error("Connectivity operation failed", e);
                    errorMessage);
通过JNDI获得destination配置的url:
以Internet Service http://maps.googleapis.com/maps/api/distancematrix/xml?origins=Walldorf&destinations=Berlin为例,
在浏览器里访问这个url,得到输出:从Walldorf到Berlin的距离。
如何让一个部署到SAP云平台的Java应用也能访问到该internet service呢?
首先在SAP云平台里创建一个destination,维护service的end point:
在Java代码里使用SAP云平台里创建的destination:
然后使用JNDI service读取destination里配置的url:
部署到SAP云平台之后,在Eclipse里看到preview结果:
SAP云平台Cockpit显示如下:
浏览器访问如下:
web.xml:
<web-app xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://java.sun.com/xml/ns/javaee"
    xmlns:web="http://java.sun.com/xml/ns/javaee/web-app_2_5.xsd" xsi:schemaLocation="http://java.sun.com/xml/ns/javaee http://java.sun.com/xml/ns/javaee/web-app_2_5.xsd"
    id="WebApp_ID" version="2.5">
    <!-- Main sample servlet mapped to / so that the integration test harness can detect readiness (generic for all samples) -->
    <servlet>
        <servlet-name>ConnectivityServlet</servlet-name>
        <servlet-class>com.sap.cloud.sample.connectivity.ConnectivityServlet</servlet-class>
    </servlet>
    <servlet-mapping>
        <url-pattern>/</url-pattern>
    </servlet-mapping>
    <!-- Declare the JNDI lookup of destination -->
    <resource-ref>
    <res-ref-name>connectivityConfiguration</res-ref-name>
    <res-type>com.sap.core.connectivity.api.configuration.ConnectivityConfiguration</res-type>
    </resource-ref>
</web-app>
package com.sap.cloud.sample.connectivity;
import java.io.IOException;
import java.io.InputStream;
import java.io.OutputStream;
import java.net.HttpURLConnection;
import java.net.InetSocketAddress;
import java.net.Proxy;
import java.net.URL;
import javax.annotation.Resource;
import javax.naming.Context;
import javax.naming.InitialContext;
import javax.servlet.ServletException;
import javax.servlet.http.HttpServlet;
import javax.servlet.http.HttpServletRequest;
import javax.servlet.http.HttpServletResponse;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
import com.sap.cloud.account.TenantContext;
import com.sap.core.connectivity.api.configuration.ConnectivityConfiguration;
import com.sap.core.connectivity.api.configuration.DestinationConfiguration;
public class ConnectivityServlet extends HttpServlet {
    @Resource
    private TenantContext  tenantContext;
    private static final long serialVersionUID = 1L;
    private static final int COPY_CONTENT_BUFFER_SIZE = 1024;
    private static final Logger LOGGER = LoggerFactory.getLogger(ConnectivityServlet.class);
    private static final String ON_PREMISE_PROXY = "OnPremise";
    @Override
    public void doGet(HttpServletRequest request, HttpServletResponse response) throws ServletException, IOException {
        HttpURLConnection urlConnection = null;
        String destinationName = request.getParameter("destname");
        if (destinationName == null) {
            destinationName = "google_map";
        try {
                return;
                    + e.getMessage()
                    + ". See "
                    + "communication.";
                    errorMessage);
    private Proxy getProxy(String proxyType) {
        Proxy proxy = Proxy.NO_PROXY;
        String proxyHost = null;
        String proxyPort = null;
        if (ON_PREMISE_PROXY.equals(proxyType)) {
            // Get proxy for on-premise destinations
            proxyHost = System.getenv("HC_OP_HTTP_PROXY_HOST");
            proxyPort = System.getenv("HC_OP_HTTP_PROXY_PORT");
            // Get proxy for internet destinations
            proxyHost = System.getProperty("https.proxyHost");
            proxyPort = System.getProperty("https.proxyPort");
        if (proxyPort != null && proxyHost != null) {
            int proxyPortNumber = Integer.parseInt(proxyPort);
            proxy = new Proxy(Proxy.Type.HTTP, new InetSocketAddress(proxyHost, proxyPortNumber));
        return proxy;
    private void injectHeader(HttpURLConnection urlConnection, String proxyType) {
            // Insert header for on-premise connectivity with the consumer account name
            urlConnection.setRequestProperty("SAP-Connectivity-ConsumerAccount",
                    tenantContext.getTenant().getAccount().getId());
    private void copyStream(InputStream inStream, OutputStream outStream) throws IOException {
        byte[] buffer = new byte[COPY_CONTENT_BUFFER_SIZE];
        int len;
        while ((len = inStream.read(buffer)) != -1) {
            outStream.write(buffer, 0, len);
