MATLAB中freqz函数的用法
莫言2021 发表于 2021/10/24 21:23:25 2021/10/24
【摘要】 FREQZ 是计算数字滤波器的频率响应的函数   [H,W] = FREQZ(B,A,N)returns the N-point complex frequency response    vector H and the N-point frequency vector W in radians/sample of    the filter: 函数的输出:a.滤波器的频率响应H(N点) ...
    the filter:
 函数的输出:a.滤波器的频率响应H(N点)  b.频率向量W(N点,且单位为弧度)
其中,滤波器形式如下:
iven numerator and denominator coefficients in vectors B and A. The
    frequency response is evaluated at N points equally spaced around the
    upper half of the unit circle. If N isn't specified, it defaults to    512.
 滤波器的系数:
分子为B,分母为A
  频率向量W,是均匀分布在滤波器的上半区,即:0:pi,这些点上的频率响应都将通过此函数计算出来。
举例:
假设滤波器的系数A=1,B=【1 1/2 1/3 1/4】;通过FREQZ函数便可以得到此滤波器的频率特性
其中,需要考察的是H和W的长度,看是否符合我们设置的N。
[H,W] = FREQZ(B,A,N,'whole') uses N points around the whole unit circle.
    函数给出了滤波器的双边频率特性,是N点的
   H = FREQZ(B,A,W)returns the frequency response at frequencies
    designated in vector W, in radians/sample (normally between 0 and pi).
    函数的输出依然是滤波器的频率响应H,只不过这个H是限定了范围的,不再是全频率(0:pi)上的了,这个范围由W来指定,单位是弧度。
举例:W=【0.5pi----pi】,下图中,红线部分便是此函数的输出,可见,只描述了【0.5pi----pi】之间的频率响应。
   [H,F] = FREQZ(B,A,N,Fs) and [H,F] = FREQZ(B,A,N,'whole',Fs)return
    frequency vector F (in Hz), where Fs is the sampling frequency (in Hz).
注意下图的横坐标与程序中fs的关系
   H = FREQZ(B,A,F,Fs)returns the complex frequency response at the
    frequencies designated in vector F (in Hz), where Fs is the sampling
    frequency (in Hz).
   FREQZ(B,A,...)with no output arguments plots the magnitude and
    unwrapped phase of the filter in the current figure window.
