Golang 编码和解析Json
Linux猿 发表于 2021/10/24 14:11:59 2021/10/24
【摘要】 🎈 作者:Linux猿 🎈 简介:CSDN博客专家🏆,华为云享专家🏆,Linux、C/C++、面试、刷题、算法尽管咨询我,关注我,有问题私聊! 🎈 欢迎小伙伴们点赞👍、收藏⭐、留言💬
🎈 作者:Linux猿
🎈 欢迎小伙伴们点赞👍、收藏⭐、留言💬
在 Golang encoding/json 包中提供了两个函数 Marshal 和 Unmarshal,分别用来编码和解码(解析)Json 格式的数据。
一、编码 :func Marshal
func Marshal(v interface{}) ([]byte, error)
作用:返回 v 编码后的 Json 数据,注意是 []byte,例如:
package main
import (
	"encoding/json"
	"fmt"
type Students struct {
	Name   string `Json:"name"`
	Height int    `Json:"height"`
	Sex    string `Json:"sex"`
type Teachers struct {
type School struct {
	Area    int        `Json:"area"`
	Student []Students `Json:"student"`
	Teacher []Teachers `Json:"teacher"`
//initAssignment 初始化School
func initAssignment() School {
	student := []Students{
		{"张三", 180, "男"},
		{"王丽", 165, "女"},
	teacher := []Teachers{
		{"李四", 180, "女"},
		{"王五", 177, "男"},
	school := School{"中关村大学", 1024, student, teacher}
	return school
func main() {
	school := initAssignment()
	schoolJson, err := json.Marshal(school)
	if err != nil {
		fmt.Println("Umarshal Error:" + err.Error())
		return
	fmt.Println("schoolJson:", string(schoolJson))
在上面的实例中,有三个结构 School、Students 以及 Teacher,其中,School 包含后面两者,实例化一个 School 类型,并将其转化为 Json 类型。
输出:
[root@localhost gotest]# go run main.go
schoolJson: {"Name":"中关村大学","Area":1024,"Student":[{"Name":"张三","Height":180,"Sex":"男"},{"Name":"王丽","Height":165,"Sex":"女"}],"Teacher":[{"Name":"李四","Height":180,"Sex":"女"},{"Name":"王五","Height":177,"Sex":"男"}]}
这样看不是很直观,看下面这种形式:
    "Name": "中关村大学",
    "Area": 1024,
    "Student": [
            "Name": "张三",
            "Height": 180,
            "Sex": "男"
            "Name": "王丽",
            "Height": 165,
            "Sex": "女"
    "Teacher": [
            "Name": "李四",
            "Height": 180,
            "Sex": "女"
            "Name": "王五",
            "Height": 177,
            "Sex": "男"
二、解析:func Unmarshal
func Unmarshal(data []byte, v interface{}) error
作用:Unmarshal 解析 JSON 数据,并将结果存储在 v 中。如果 v 为 nil 或不是指针,则 Unmarshal 返回 InvalidUnmarshalError,例如:
package main
import (
	"encoding/json"
	"fmt"
func main() {
	var school School
	strJson := `{"name":"中关村大学","area":1024,"student":[{"name":"张三","height":180,"sex":"男"},{"name":"王丽","height":165,"sex":"女"}],"teacher":[{"name":"李四","height":180,"sex":"女"},{"name":"王五","height":177,"sex":"男"}]}`
	err := json.Unmarshal([]byte(strJson), &school) //注意:第二个参数需要传递地址
	if err != nil {
		return
	fmt.Printf("%#v\n", school)
	fmt.Println(school.Name, school.Area)
输出:
main.School{Name:"中关村大学", Area:1024, Student:[]main.Students{main.Students{Name:"张三", Height:180, Sex:"男"}, main.Students{Name:"王丽", Height:165, Sex:"女"}}, Teacher:[]main.Teachers{main.Teachers{Name:"李四", Height:180, Sex:"女"}, main.Teachers{Name:"王五", Height:177, Sex:"男"}}}
中关村大学 1024
这里需要注意的是,结构体内的变量名称首字母要大写,这样其它的包才可以访问该结构的变量。可以通过在变量后面加 `Json:“变量名称”` 来解析Json中的对应的变量。
欢迎小伙伴们点赞👍、收藏⭐、留言💬
