openGauss2.0.1的安装步骤
wuyicom 发表于 2021/10/24 12:30:15 2021/10/24
【摘要】     openGauss的安装,测试环境:操作系统版本:CentOS7.6 x86_64,硬件配置:2C4G 1台,服务器名称:kafka1.wuyi.com, IP地址: 172.16.32.5。    1 关闭防火墙和关闭SELinuxsystemctl disable firewalldsystemctl stop firewalldsed -i s/SELINUX=.*/SELIN...
    1 关闭防火墙和关闭SELinux
sed -i s/SELINUX=.*/SELINUX=disabled/ /etc/selinux/config
cat /etc/selinux/config
getenforce
setenforce 0
getenforce
    2 设置操作系统字符集编码和设置操作系统时区
echo $LANG
    3 关闭SWAP分区 [对于2G内存的设备,建议待安装完毕后再打开SWAP以间接 “扩容内存容量”]
    4 配置SSH服务,关闭Banner,允许root远程登录
sed -i '/Banner/s/^/#/' /etc/ssh/sshd_config
sed -i '/PermitRootLogin/s/^/#/' /etc/ssh/sshd_config
echo -e "\n" >> /etc/ssh/sshd_config
echo "Banner none " >> /etc/ssh/sshd_config
echo "PermitRootLogin yes" >> /etc/ssh/sshd_config
cat /etc/ssh/sshd_config |grep -v ^#|grep -E 'PermitRoot|Banner'
    5 配置YUM源、安装依赖包、修改默认Python3版本
mkdir /etc/yum.repos.d/bak
mv /etc/yum.repos.d/*.repo /etc/yum.repos.d/bak/
wget -O /etc/yum.repos.d/CentOS-Base.repo https://repo.huaweicloud.cn/repository/conf/CentOS-7-reg.repo
yum clean all
yum install -y bzip2 python3
yum install -y libaio-devel flex bison ncurses-devel glibc-devel patch redhat-lsb-core readline-devel net-tools tar
mv /usr/bin/python /usr/bin/python2_bak
ln -s /usr/bin/python3 /usr/bin/python
python -V
    6 配置 sysctl.conf 和 performance.sh
cat >> /etc/sysctl.conf << EOF
net.ipv4.tcp_retries1 = 5
net.ipv4.tcp_syn_retries = 5
net.sctp.path_max_retrans = 10
net.sctp.max_init_retransmits = 10
EOF
sysctl -p
    7 配置资源限制
echo "* soft stack 3072" >> /etc/security/limits.conf
echo "* hard stack 3072" >> /etc/security/limits.conf
echo "* soft nofile 1000000" >> /etc/security/limits.conf
echo "* hard nofile 1000000" >> /etc/security/limits.conf
echo "* soft nproc unlimited" >> /etc/security/limits.d/90-nproc.conf
tail -n 4 /etc/security/limits.conf
tail -n 1 /etc/security/limits.d/90-nproc.conf
    8 关闭透明大页[Only for CentOS]
cat >>/etc/rc.d/rc.local<<EOF
if test -f /sys/kernel/mm/transparent_hugepage/enabled; then
echo never > /sys/kernel/mm/transparent_hugepage/enabled
fi
if test -f /sys/kernel/mm/transparent_hugepage/defrag; then
echo never > /sys/kernel/mm/transparent_hugepage/defrag
fi
EOF
chmod +x /etc/rc.d/rc.local
/usr/bin/sh /etc/rc.d/rc.local
cat /sys/kernel/mm/transparent_hugepage/enabled
cat /sys/kernel/mm/transparent_hugepage/defrag
    9 下载openGauss软件包
mkdir -p /soft/
cd /soft/
wget https://opengauss.obs.cn-south-1.myhuaweicloud.com/2.0.1/x86/openGauss-2.0.1-CentOS-64bit-all.tar.gz
# /soft/clusterconfig.xml
    10 配置XML文件
cat >> /soft/clusterconfig.xml <<EOF
<ROOT>
<!-- openGauss整体信息 -->
<CLUSTER>
<PARAM name="clusterName" value="dbCluster" />
<PARAM name="nodeNames" value="kafka1.wuyi.com" />
<PARAM name="backIp1s" value="172.16.32.5"/>
<PARAM name="gaussdbAppPath" value="/gaussdb/app" />
<PARAM name="gaussdbLogPath" value="/gaussdb/log" />
<PARAM name="gaussdbToolPath" value="/gaussdb/om" />
<PARAM name="corePath" value="/gaussdb/corefile"/>
<PARAM name="clusterType" value="single-inst"/>
</CLUSTER>
<!-- 每台服务器上的节点部署信息 -->
<DEVICELIST>
<!-- node1上的节点部署信息 -->
<DEVICE sn="1000001">
<PARAM name="name" value="kafka1.wuyi.com"/>
<PARAM name="azName" value="AZ1"/>
<PARAM name="azPriority" value="1"/>
<!-- 如果服务器只有一个网卡可用,将backIP1和sshIP1配置成同一个IP -->
<PARAM name="backIp1" value="172.16.32.5"/>
<PARAM name="sshIp1" value="172.16.32.5"/>
     <!--dbnode-->
     <PARAM name="dataNum" value="1"/>
     <PARAM name="dataPortBase" value="26000"/>
     <PARAM name="dataNode1" value="/gaussdb/data/db1"/>
</DEVICE>
</DEVICELIST>
</ROOT>
EOF
cat /soft/clusterconfig.xml
    11 解压安装包并修改目录权限
cd /soft
tar -zxvf *all.tar.gz
tar -zxvf *om.tar.gz
chmod -R 777 *
    12 执行 gs_preinstall
python script/gs_preinstall -U omm -G dbgrp -X clusterconfig.xml
    13 检查预安装环境
/soft/script/gs_checkos -i A -h kafka1.wuyi.com --detail
    14 执行 gs_install
touch /home/omm/install_db
cat >> /home/omm/install_db <<EOF
source ~/.bashrc
gs_install -X /soft/clusterconfig.xml --gsinit-parameter="--encoding=UTF8" --dn-guc="max_process_memory=3GB" --dn-guc="shared_buffers=128MB" --dn-guc="cstore_buffers=16MB"
EOF
chown -R omm:dbgrp /home/omm/install_db
su - omm -c "sh /home/omm/install_db"
su - omm
gsql -d postgres -p 26000 -r
gs_om -t status --detail
    15 如果不想使用openGauss,要卸载:
gs_uninstall --delete-data
一键式环境清理
在openGauss卸载完成后,如果不需要在环境上重新部署openGauss,可以运行脚本
gs_postuninstall对openGauss服务器上环境信息做清理。openGauss环境清理是对环
境准备脚本gs_preinstall所做设置的清理。
前提条件:
(1)openGauss卸载执行成功。
(2)只能使用root用户执行gs_postuninstall命令。
以root用户登录openGauss服务器。进入解压缩的目录:/soft/script路径下。
./gs_postuninstall -U omm -X /soft /clusterconfig.xml --delete-user --delete-group
转本人openGauss2.0.1的安装步骤:https ://www.modb.pro/db/145006
