(精华)2020年8月27日 数据结构与算法解析(链表)
愚公搬代码 发表于 2021/10/19 23:15:46 2021/10/19
【摘要】 一:单链表实现原理 //链表类,包含链表定义及基本操作方法 public class MyLinkList<T> { private Node<T> head; //...
一:单链表实现原理
//链表类,包含链表定义及基本操作方法
    private Node<T> head; //单链表的头结点
    //头结点属性
    public Node<T> Head
        get
            return head;
        set
            head = value;
    //构造器
    public MyLinkList()
        head = null;
    //求单链表的长度
    public int GetLength()
        Node<T> p = head;
        int len = 0;
        while (p != null)
            ++len;
            p = p.Next;
        return len;
    //清空单链表
    public void Clear()
        head = null;
    //判断单链表是否为空
    public bool IsEmpty()
        if (head == null)
            return true;
        else
            return false;
    //在单链表的末尾添加新元素
    public void Append(T item)
        Node<T> q = new Node<T>(item);
        Node<T> p = new Node<T>();
        if (head == null)
            head = q;
            return;
        p = head;
        while (p.Next != null)
            p = p.Next;
        p.Next = q;
    //在单链表的第i个结点的位置前插入一个值为item的结点
    public void Insert(T item, int i)
        if (IsEmpty() || i < 1 || i > GetLength())
            Console.WriteLine("LinkList is empty or Position is error!");
            return;
        if (i == 1)
            q.Next = head;
            head = q;
            return;
        Node<T> p = head;
        Node<T> r = new Node<T>();
        int j = 1;
        while (p.Next != null && j < i)
            r = p;
            p = p.Next;
            ++j;
        if (j == i)
            q.Next = p;
            r.Next = q;
    //在单链表的第i个结点的位置后插入一个值为item的结点
    public void InsertPost(T item, int i)
            return;
        if (i == 1)
            q.Next = head.Next;
            head.Next = q;
            return;
        Node<T> p = head;
        int j = 1;
        while (p != null && j < i)
            p = p.Next;
            ++j;
        if (j == i)
            q.Next = p.Next;
            p.Next = q;
    //删除单链表的第i个结点
    public T Delete(int i)
        if (IsEmpty() || i < 0 || i > GetLength())
            return default(T);
        Node<T> q = new Node<T>();
        if (i == 1)
            q = head;
            head = head.Next;
            return q.Data;
        Node<T> p = head;
        int j = 1;
            ++j;
            q = p;
            p = p.Next;
        if (j == i)
            q.Next = p.Next;
            return p.Data;
        else
            Console.WriteLine("The " + i + "th node is not exist!");
            return default(T);
    //获得单链表的第i个数据元素
    public T GetElem(int i)
        if (IsEmpty() || i < 0)
            Console.WriteLine("LinkList is empty or position is error! ");
            return default(T);
        p = head;
        int j = 1;
            ++j;
            p = p.Next;
        if (j == i)
            return p.Data;
        else
            return default(T);
    //在单链表中查找值为value的结点
    public int Locate(T value)
        if (IsEmpty())
            Console.WriteLine("LinkList is Empty!");
            return -1;
        p = head;
        int i = 1;
        while (!p.Data.Equals(value) && p.Next != null)
            p = p.Next;
            ++i;
        return i;
    //显示链表
    public void Display()
        p = this.head;
        while (p != null)
            Console.Write(p.Data + " ");
            p = p.Next;
public class Program
    static void Main(string[] args)
        MyLinkList<string> myLinkList = new MyLinkList<string>(); //实例化一个单链表
        Console.WriteLine(myLinkList.GetLength());   //获取长度
        //添加元素
        myLinkList.Append("good");
        myLinkList.Append("monring");
        myLinkList.Append("lwk");
        myLinkList.Insert("!", 5);  //在i结点前插元素,位置错误测试
        myLinkList.InsertPost("!", 5);  //在i结点后插元素,位置错误测试
        myLinkList.InsertPost("!", 3);  //后插元素
        myLinkList.Insert(",", 3);  //前插元素
        myLinkList.Display();  //显示链表元素
        Console.WriteLine(myLinkList.GetElem(4));//获取结点,并显示
        myLinkList.Delete(1);  //删除结点
        Console.WriteLine(myLinkList.GetLength()); //显示链表长度
        Console.Read();
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
  • 224
  • 225
  • 226
  • 227
  • 228
  • 229
  • 230
  • 231
  • 232
  • 233
  • 234
  • 235
  • 236
  • 237
  • 238
  • 239
  • 240
二:双向链表实现原理
using System;
using System.Text;
namespace 线性表
  public class DbLinkList<T> : IListDS<T>
    private DbNode<T> head;
    public DbNode<T> Head
      get { return head; }
      set { head = value; }
    public DbLinkList()
      head = null;
    /// <summary>
    /// 类索引器
    /// </summary>
    /// <param name="index"></param>
    /// <returns></returns>
    public T this[int index]
      get
        return this.GetItemAt(index);
    /// <summary>
    /// 返回单链表的长度
    /// </summary>
    public int Count()
      DbNode<T> p = head;
      int len = 0;
      while (p != null)
        len++;
        p = p.Next;
      return len;
    /// <summary>
    /// 清空
    /// </summary>
    public void Clear()
      head = null;
    /// <summary>
    /// 是否为空
    /// </summary>
      return head == null;
    /// <summary>
    /// 在最后附加元素
    /// </summary>
    /// <param name="item"></param>
      DbNode<T> d = new DbNode<T>(item);
      DbNode<T> n = new DbNode<T>();
      if (head == null)
        head = d;
        return;
      n = head;
      while (n.Next != null)
        n = n.Next;
      n.Next = d;
      d.Prev = n;
    //前插
    public void InsertBefore(T item, int i)
        Console.WriteLine("List is empty or Position is error!");
        return;
      //在最开头插入
      if (i == 0)
        DbNode<T> q = new DbNode<T>(item);
        q.Next = head;//把"头"改成第二个元素
        head.Prev = q;
        head = q;//把自己设置为"头"
        return;
      DbNode<T> n = head;
      DbNode<T> d = new DbNode<T>();
      int j = 0;
      //找到位置i的前一个元素d
      while (n.Next != null && j < i)
        d = n;
        n = n.Next;
        j++;
      if (n.Next == null) //说明是在最后节点插入(即追加)
        n.Next = q;
        q.Prev = n;
        q.Next = null;
      else
        if (j == i)
          d.Next = q;
          q.Prev = d;
          q.Next = n;
          n.Prev = q;
    /// <summary>
    /// 在位置i后插入元素item
    /// </summary>
    /// <param name="i"></param>
    public void InsertAfter(T item, int i)
        return;
      if (i == 0)
        q.Next = head.Next;
        head.Next.Prev = q;
        head.Next = q;
        q.Prev = head;
        return;
      DbNode<T> p = head;
      int j = 0;
        p = p.Next;
        j++;
      if (j == i)
        q.Next = p.Next;
        if (p.Next != null)
          p.Next.Prev = q;
        p.Next = q;
        q.Prev = p;
      else
        Console.WriteLine("Position is error!");
    /// <summary>
    /// 删除位置i的元素
    /// </summary>
    public T RemoveAt(int i)
        Console.WriteLine("Link is empty or Position is error!");
        return default(T);
      DbNode<T> q = new DbNode<T>();
      if (i == 0)
        q = head;
        head = head.Next;
        head.Prev = null;
        return q.Data;
      DbNode<T> p = head;
      int j = 0;
        j++;
        q = p;
        p = p.Next;
      if (j == i)
        p.Next.Prev = q;
        q.Next = p.Next;
        return p.Data;
      else
        Console.WriteLine("The node is not exist!");
        return default(T);
    /// <summary>
    /// 获取指定位置的元素
    /// </summary>
    public T GetItemAt(int i)
      if (IsEmpty())
        Console.WriteLine("List is empty!");
        return default(T);
      DbNode<T> p = new DbNode<T>();
      p = head;
      if (i == 0)
        return p.Data;
      int j = 0;
        j++;
        p = p.Next;
      if (j == i)
        return p.Data;
      else
        return default(T);
    //按元素值查找索引
    public int IndexOf(T value)
      if (IsEmpty())
        Console.WriteLine("List is Empty!");
        return -1;
      p = head;
      int i = 0;
        p = p.Next;
        i++;
      return i;
    /// <summary>
    /// 元素反转
    /// </summary>
    public void Reverse()
      DbLinkList<T> result = new DbLinkList<T>();
      DbNode<T> t = this.head;
      result.Head = new DbNode<T>(t.Data);
      t = t.Next;
      //(把当前链接的元素从head开始遍历,逐个插入到另一个空链表中,这样得到的新链表正好元素顺序跟原链表是相反的)
      while (t!=null)
        result.InsertBefore(t.Data, 0);
        t = t.Next;
      this.head = result.head;//将原链表直接挂到"反转后的链表"上
      result = null;//显式清空原链表的引用,以便让GC能直接回收
    //得到某个指定的节点(为了下面测试从后向前遍历)
    private DbNode<T> GetNodeAt(int i){
      if (IsEmpty())
        return null;
      p = head;
      if (i == 0)
        return p;
      int j = 0;
        j++;
        p = p.Next;
      if (j == i)
        return p;
      else
        return null;
    /// <summary>
    /// 测试用prev属性从后面开始遍历
    /// </summary>
    public string TestPrevErgodic()
      DbNode<T> tail = GetNodeAt(Count() - 1);
      StringBuilder sb = new StringBuilder();
      sb.Append(tail.Data.ToString() + ",");
      while (tail.Prev != null)
        sb.Append(tail.Prev.Data.ToString() + ",");
        tail = tail.Prev;
      return sb.ToString().TrimEnd(',');
    public override string ToString()
      DbNode<T> n = this.head;
      sb.Append(n.Data.ToString() + ",");
        sb.Append(n.Next.Data.ToString() + ",");
        n = n.Next;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
  • 224
  • 225
  • 226
  • 227
  • 228
  • 229
  • 230
  • 231
  • 232
  • 233
  • 234
  • 235
  • 236
  • 237
  • 238
  • 239
  • 240
  • 241
  • 242
  • 243
  • 244
  • 245
  • 246
  • 247
  • 248
  • 249
  • 250
  • 251
  • 252
  • 253
  • 254
  • 255
  • 256
  • 257
  • 258
  • 259
  • 260
  • 261
  • 262
  • 263
  • 264
  • 265
  • 266
  • 267
  • 268
  • 269
  • 270
  • 271
  • 272
  • 273
  • 274
  • 275
  • 276
  • 277
  • 278
  • 279
  • 280
  • 281
  • 282
  • 283
  • 284
  • 285
  • 286
  • 287
  • 288
  • 289
  • 290
  • 291
  • 292
  • 293
  • 294
  • 295
  • 296
  • 297
  • 298
  • 299
  • 300
  • 301
  • 302
  • 303
  • 304
  • 305
  • 306
  • 307
  • 308
  • 309
  • 310
  • 311
  • 312
  • 313
  • 314
  • 315
  • 316
  • 317
  • 318
  • 319
  • 320
  • 321
  • 322
  • 323
  • 324
  • 325
  • 326
  • 327
  • 328
  • 329
  • 330
  • 331
  • 332
  • 333
  • 334
  • 335
  • 336
  • 337
  • 338
  • 339
  • 340
Console.WriteLine("-------------------------------------");
Console.WriteLine("双链表测试开始...");
DbLinkList<string> dblink = new DbLinkList<string>();
dblink.Head = new DbNode<string>("x");
dblink.InsertBefore("w", 0);
dblink.InsertBefore("v", 0);
dblink.Append("y");
dblink.InsertBefore("z", dblink.Count());
Console.WriteLine(dblink.Count());//5
Console.WriteLine(dblink.ToString());//v,w,x,y,z
Console.WriteLine(dblink[1]);//w
Console.WriteLine(dblink[0]);//v
Console.WriteLine(dblink[4]);//z
Console.WriteLine(dblink.IndexOf("z"));//4
Console.WriteLine(dblink.RemoveAt(2));//x
Console.WriteLine(dblink.ToString());//v,w,y,z
dblink.InsertBefore("x", 2);
Console.WriteLine(dblink.GetItemAt(2));//x
dblink.Reverse();
Console.WriteLine(dblink.ToString());//z,y,x,w,v
dblink.InsertAfter("1", 0);
dblink.InsertAfter("2", 1);
dblink.InsertAfter("6", 5);
dblink.InsertAfter("8", 7);
dblink.InsertAfter("A", 10);//Position is error!
Console.WriteLine(dblink.ToString()); //z,1,2,y,x,w,6,v,8
string _tail = dblink.GetItemAt(dblink.Count()-1);
Console.WriteLine(_tail);
Console.WriteLine(dblink.TestPrevErgodic());//8
Console.ReadKey(); //8,v,6,w,x,y,2,1,z
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
双链表的插入操作要稍微复杂一点,示意图如下:
同样对于删除操作,也要额外处理prev指向
二:循环双向链表实现原理
代码就不贴了
文章来源: codeboy.blog.csdn.net,作者:愚公搬代码,版权归原作者所有,如需转载,请联系作者。
原文链接:codeboy.blog.csdn.net/article/details/108175845
