(精华)2020年9月15日 ASP.NET Core 文件系统详解
愚公搬代码 发表于 2021/10/19 23:35:51 2021/10/19
【摘要】 1.文件系统遍历文件目录 public static class Sample01 { public static void Run() { var provider =...
1.文件系统遍历文件目录
        var provider = new ServiceCollection()
            .AddSingleton<IFileProvider>(new PhysicalFileProvider(@"e:\测试文件夹"))
            .AddSingleton<FileManager>()
            .BuildServiceProvider();
        var fileManager = provider.GetService<FileManager>();
        fileManager.Dir();
    public class FileManager
        private readonly IFileProvider _fileProvider;
        public FileManager(IFileProvider fileProvider)
            _fileProvider = fileProvider;
        public void Dir()
            var indent = -1;
            void Get(string subpath)
                indent++;
                foreach (var fileinfo in _fileProvider.GetDirectoryContents(subpath))
                    Console.WriteLine(new string('\t',indent) + fileinfo.Name);
                    if (fileinfo.IsDirectory)
                        Get($@"{subpath}\{fileinfo.Name}");
            Get("");
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
2.程序内嵌文件读取文件信息
public static class Sample02
            .AddSingleton<IFileProvider>(new EmbeddedFileProvider(Assembly.GetExecutingAssembly()))
        var content = fileManager.ReadAsync("Text.txt").Result;
        Console.WriteLine(content);
        public async Task<string> ReadAsync(string path)
            await using var stream = _fileProvider.GetFileInfo(path).CreateReadStream();
            var buffer = new byte[stream.Length];
            await stream.ReadAsync(buffer, 0, buffer.Length);
            return Encoding.Default.GetString(buffer);
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
3.监控文件系统,文件发生改变实时通知程序
public static class Sample03
            .AddSingleton<IFileProvider>(new PhysicalFileProvider(@"e:\其它"))
        fileManager.WatchAsync("Text.txt").Wait();
        Console.Read();
        public async Task WatchAsync(string path)
            Console.WriteLine(await ReadAsync(path));
            ChangeToken.OnChange(() => _fileProvider.Watch(path), async () =>
                Console.Clear();
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
文章来源: codeboy.blog.csdn.net,作者:愚公搬代码,版权归原作者所有,如需转载,请联系作者。
原文链接:codeboy.blog.csdn.net/article/details/108412721
