(精华)2020年9月16日 ASP.NET Core NLog日志框架的使用
愚公搬代码 发表于 2021/10/19 23:59:01 2021/10/19
【摘要】 首先安装两个包 NLog NLog.Web.AspNetCore 12 public class Program { public static void Main(strin...
首先安装两个包
NLog
NLog.Web.AspNetCore
        public static void Main(string[] args)
            CreateHostBuilder(args).Build().Run();
        public static IHostBuilder CreateHostBuilder(string[] args) =>
            Host.CreateDefaultBuilder(args)
                .ConfigureWebHostDefaults(webBuilder =>
                    webBuilder.UseStartup<Startup>();
                .UseNLog();
// This method gets called by the runtime. Use this method to configure the HTTP request pipeline.
        public void Configure(IApplicationBuilder app, IWebHostEnvironment env, ILogger<Startup> logger)
            if (env.IsDevelopment())
                app.UseDeveloperExceptionPage();
            logger.LogError("Hello");
            app.UseRouting();
            app.UseEndpoints(endpoints =>
                endpoints.MapGet("/", async context =>
                    await context.Response.WriteAsync("Hello World!");
public class HomeConroller
        public ILogger<HomeConroller> _Logger;
        public HomeConroller(ILogger<HomeConroller> logger)
            _Logger = logger;
配置文件nlog.config
<?xml version="1.0" encoding="utf-8" ?>
<nlog xmlns="http://www.nlog-project.org/schemas/NLog.xsd"
      xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
      autoReload="true"
      internalLogLevel="Info"
      internalLogFile="c:\temp\internal-nlog.txt">
  <!-- enable asp.net core layout renderers -->
  <extensions>
    <add assembly="NLog.Web.AspNetCore"/>
  </extensions>
  <!-- the targets to write to -->
  <targets>
    <!-- write logs to file  -->
    <target xsi:type="File" name="allfile" fileName="c:\temp\nlog-all-${shortdate}.log"
            layout="${longdate}|${event-properties:item=EventId_Id}|${uppercase:${level}}|${logger}|${message} ${exception:format=tostring}" />
    <!-- another file log, only own logs. Uses some ASP.NET core renderers -->
    <target xsi:type="File" name="ownFile-web" fileName="c:\temp\nlog-own-${shortdate}.log"
            layout="${longdate}|${event-properties:item=EventId_Id}|${uppercase:${level}}|${logger}|${message} ${exception:format=tostring}|url: ${aspnet-request-url}|action: ${aspnet-mvc-action}" />
  </targets>
  <!-- rules to map from logger name to target -->
  <rules>
    <!--All logs, including from Microsoft-->
    <logger name="*" minlevel="Trace" writeTo="allfile" />
    <!--Skip non-critical Microsoft logs and so log only own logs-->
    <logger name="Microsoft.*" maxlevel="Info" final="true" /> <!-- BlackHole without writeTo -->
    <logger name="*" minlevel="Trace" writeTo="ownFile-web" />
  </rules>
</nlog>
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
文章来源: codeboy.blog.csdn.net,作者:愚公搬代码,版权归原作者所有,如需转载,请联系作者。
原文链接:codeboy.blog.csdn.net/article/details/108412743
