(精华)2020年10月18日 高可用高并发 缓存的使用(Redis)
愚公搬代码 发表于 2021/10/19 23:12:04 2021/10/19
【摘要】 首先按装如下包 Microsoft.Extensions.Caching.Redis 配置 public class Startup { public Startup(IC...
首先按装如下包
配置
        public Startup(IConfiguration configuration)
            Configuration = configuration;
        public IConfiguration Configuration { get; }
        public void ConfigureServices(IServiceCollection services)
            services.AddControllers();
            services.AddDistributedRedisCache(options =>
                options.Configuration = "localhost";//地址
                options.InstanceName = "Sample";//实例名称
        public void Configure(IApplicationBuilder app, IWebHostEnvironment env)
            if (env.IsDevelopment())
                app.UseDeveloperExceptionPage();
            app.UseRouting();
            app.UseAuthorization();
            app.UseEndpoints(endpoints =>
                endpoints.MapControllers();
使用
[Route("api/[controller]")]
    [ApiController]
    public class Sample01Controller : ControllerBase
        private readonly IDistributedCache _cache;
        public Sample01Controller(IDistributedCache distributedCache)
            _cache = distributedCache;
        public async Task<IActionResult> Get()
            var cacheTime = await _cache.GetStringAsync("CacheTime");
            if (cacheTime == null)
                cacheTime = DateTime.Now.ToString("yyyy-MM-dd hh:mm:ss");
                await _cache.SetAsync("CacheTime", Encoding.UTF8.GetBytes(cacheTime));
            return Ok(new
                cacheTime,
                currentTime = DateTime.Now.ToString("yyyy-MM-dd hh:mm:ss")
    [ApiController]
    public class Sample02Controller : ControllerBase
        public Sample02Controller(IDistributedCache distributedCache)
                var cacheEntryOptions = new DistributedCacheEntryOptions()
                    .SetSlidingExpiration(TimeSpan.FromSeconds(10))
                    .SetAbsoluteExpiration(TimeSpan.FromSeconds(20));
                await _cache.SetAsync("CacheTime", Encoding.UTF8.GetBytes(cacheTime), cacheEntryOptions);
            return Ok(new
                cacheTime,
文章来源: codeboy.blog.csdn.net,作者:愚公搬代码,版权归原作者所有,如需转载,请联系作者。
原文链接:codeboy.blog.csdn.net/article/details/109150974
