(精华)2020年6月26日 C#类库 读取json配置文件帮助类
愚公搬代码 发表于 2021/10/19 01:15:27 2021/10/19
【摘要】 using Microsoft.Extensions.Configuration; using System; namespace Core.Util { /// <summary>...
using System;
namespace Core.Util
    /// <summary>
    /// 配置文件帮助类
    /// </summary>
    public static class ConfigHelper
        private static IConfiguration _config;
        private static object _lock = new object();
        public static IConfiguration Configuration
            get
                if (_config == null)
                    lock (_lock)
                            var builder = new ConfigurationBuilder()
                                .SetBasePath(AppContext.BaseDirectory)
                                .AddJsonFile("appsettings.json");
                            _config = builder.Build();
                return _config;
            set
                _config = value;
        /// <summary>
        /// 从AppSettings获取key的值
        /// </summary>
        /// <param name="key">key</param>
        /// <returns></returns>
        public static string GetValue(string key)
            return Configuration[key];
        /// <summary>
        /// 获取连接字符串
        /// </summary>
        /// <param name="nameOfCon">连接字符串名</param>
        public static string GetConnectionString(string nameOfCon)
            return Configuration.GetConnectionString(nameOfCon);
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
文章来源: codeboy.blog.csdn.net,作者:愚公搬代码,版权归原作者所有,如需转载,请联系作者。
原文链接:codeboy.blog.csdn.net/article/details/106966359
