(精华)2020年6月26日 C#类库 数据库统计帮助类(扩展方法)
愚公搬代码 发表于 2021/10/19 00:18:07 2021/10/19
【摘要】 using System; using System.Collections.Generic; using System.Linq; using System.Linq.Dynamic.Core; usi...
using System;
using System.Linq;
using System.Reflection;
using System.Text;
namespace Core.Util
    /// <summary>
    /// 数据库查询帮助类
    /// </summary>
    public static class DbSearchHelper
        /// <summary>
        /// 获取数据库统计数据
        /// </summary>
        /// <param name="dataSource">数据源</param>
        /// <param name="groupColumn">分组的列</param>
        /// <param name="statisColumn">统计的列</param>
        /// <param name="funcName">统计方法名(Max,Min,Average,Count())</param>
        /// <returns></returns>
        public static List<DbStatisData> GetDbStatisData(this IQueryable dataSource, string groupColumn, string statisColumn, string funcName)
            List<DbStatisData> resData = new List<DbStatisData>();
            var q = dataSource.GroupBy(groupColumn, "it")
            .Select($"new (it.Key as Key,{funcName}(it.{statisColumn}) as Value)")
            .CastToList<dynamic>();
            foreach (dynamic aData in q)
                DbStatisData newData = new DbStatisData();
                resData.Add(newData);
                newData.Key = aData.Key;
                newData.Value = aData.Value;
            return resData;
        /// <summary>
        /// 获取数据库统计数据
        /// </summary>
        /// <param name="searchEntris">查询的配置项</param>
        public static List<DynamicModel> GetDbStatisData(this IQueryable dataSource, string groupColumn, SearchEntry[] searchEntris)
            if (searchEntris.Count() == 0)
                throw new Exception("请输入至少一个查询配置项");
            StringBuilder selectStr = new StringBuilder();
            selectStr.Append("new (it.Key as Key");
            int count = searchEntris.Count();
            searchEntris.ForEach((item, index) => {
                string end = "";
                if (index == count - 1)
                    end = ")";
                selectStr.Append($",{item.FuncName}(it.{item.StatisColoum}) as {item.ResultName}{end}");
            List<DynamicModel> resData = new List<DynamicModel>();
            .Select(selectStr.ToString())
                DynamicModel newData = new DynamicModel();
                object obj = (object)aData;
                Type type = obj.GetType();
                newData.AddProperty("Key", type.GetProperty("Key").GetValue(obj));
                searchEntris.ForEach(item =>
                    newData.AddProperty(item.ResultName, type.GetProperty(item.ResultName).GetValue(obj));
            return resData;
        /// <summary>
        /// 获取IQueryable
        /// </summary>
        /// <param name="obj">包含获取IQueryable方法的对象</param>
        /// <param name="funcName">获取IQueryable的方法名</param>
        /// <param name="entityName">实体名</param>
        /// <param name="nameSpace">命名空间</param>
        public static IQueryable GetIQueryable(object obj, string funcName, string entityName, string nameSpace)
            MethodInfo method = type.GetMethod(funcName);
            var entityType = Assembly.Load(nameSpace).GetTypes().Where(x => x.Name.ToLower().Contains(entityName.ToLower())).FirstOrDefault();
            if (entityType.IsNullOrEmpty())
                throw new Exception("请输入有效的实体名!");
            var iQueryable = (IQueryable)method.MakeGenericMethod(entityType).Invoke(obj, null);
            return iQueryable;
    /// <summary>
    /// 统计数据模型
    /// </summary>
    public class DbStatisData
        /// <summary>
        /// 分组查询的列
        /// </summary>
        public string Key { get; set;}
        /// <summary>
        /// 统计后的数值
        /// </summary>
        public double? Value { get; set; }
    /// <summary>
    /// 统计查询配置项
    /// </summary>
    public struct SearchEntry
        /// <summary>
        /// 统计的列
        /// </summary>
        public string StatisColoum { get; set; }
        /// <summary>
        /// 返回数据列名
        /// </summary>
        public string ResultName { get; set; }
        /// <summary>
        /// 统计方法名(Max,Min,Average,Count()等)
        /// </summary>
        public string FuncName { get; set; }
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
文章来源: codeboy.blog.csdn.net,作者:愚公搬代码,版权归原作者所有,如需转载,请联系作者。
原文链接:codeboy.blog.csdn.net/article/details/106966591
