(精华)2020年6月26日 C#类库 图片操作帮助类
愚公搬代码 发表于 2021/10/19 00:14:15 2021/10/19
【摘要】 using System; using System.Drawing; using System.Drawing.Imaging; using System.IO; using System.Text.R...
using System;
using System.IO;
using System.Text.RegularExpressions;
namespace Core.Util
    /// <summary>
    /// 图片操作帮助类
    /// </summary>
    public class ImgHelper
        /// <summary>
        /// 从文件获取图片
        /// </summary>
        /// <param name="fileName">文件名</param>
        /// <returns></returns>
        public static Image GetImgFromFile(string fileName)
            return Image.FromFile(fileName);
        /// <summary>
        /// 从base64字符串读入图片
        /// </summary>
        /// <param name="base64">base64字符串</param>
        public static Image GetImgFromBase64(string base64)
            byte[] bytes = Convert.FromBase64String(base64);
            MemoryStream memStream = new MemoryStream(bytes);
            Image img = Image.FromStream(memStream);
            return img;
        /// <summary>
        /// 从URL格式的Base64图片获取真正的图片
        /// 即去掉data:image/jpg;base64,这样的格式
        /// </summary>
        /// <param name="base64Url">图片Base64的URL形式</param>
        public static Image GetImgFromBase64Url(string base64Url)
            string base64 = GetBase64String(base64Url);
            return GetImgFromBase64(base64);
        /// <summary>
        /// 压缩图片
        /// 注:等比压缩
        /// </summary>
        /// <param name="img">原图片</param>
        /// <param name="width">压缩后宽度</param>
        public static Image CompressImg(Image img, int width)
            return CompressImg(img, width, (int)(((double)width) / img.Width * img.Height));
        /// <summary>
        /// 压缩图片
        /// </summary>
        /// <param name="height">压缩后高度</param>
        public static Image CompressImg(Image img, int width, int height)
            Bitmap bitmap = new Bitmap(img, width, height);
            return bitmap;
        /// <summary>
        /// 将图片转为base64字符串
        /// 默认使用jpg格式
        /// </summary>
        /// <param name="img">图片对象</param>
        public static string ToBase64String(Image img)
            return ToBase64String(img, ImageFormat.Jpeg);
        /// <summary>
        /// 将图片转为base64字符串
        /// 使用指定格式
        /// </summary>
        /// <param name="imageFormat">指定格式</param>
        public static string ToBase64String(Image img, ImageFormat imageFormat)
            MemoryStream memStream = new MemoryStream();
            img.Save(memStream, imageFormat);
            byte[] bytes = memStream.ToArray();
            string base64 = Convert.ToBase64String(bytes);
            return base64;
        /// <summary>
        /// 将图片转为base64字符串
        /// 默认使用jpg格式,并添加data:image/jpg;base64,前缀
        /// </summary>
        public static string ToBase64StringUrl(Image img)
            return "data:image/jpg;base64," + ToBase64String(img, ImageFormat.Jpeg);
        /// <summary>
        /// 将图片转为base64字符串
        /// 使用指定格式,并添加data:image/jpg;base64,前缀
        /// </summary>
        public static string ToBase64StringUrl(Image img, ImageFormat imageFormat)
            string base64 = ToBase64String(img, imageFormat);
            return $"data:image/{imageFormat.ToString().ToLower()};base64,{base64}";
        /// <summary>
        /// 获取真正的图片base64数据
        /// </summary>
        /// <param name="base64UrlStr">带前缀的base64图片字符串</param>
        public static string GetBase64String(string base64UrlStr)
            string parttern = "^(data:image/.*?;base64,).*?$";
            var match = Regex.Match(base64UrlStr, parttern);
            if (match.Groups.Count > 1)
                base64UrlStr = base64UrlStr.Replace(match.Groups[1].ToString(), "");
            return base64UrlStr;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
文章来源: codeboy.blog.csdn.net,作者:愚公搬代码,版权归原作者所有,如需转载,请联系作者。
原文链接:codeboy.blog.csdn.net/article/details/106969477
