(精华)2020年6月26日 C#类库 Aspose组件的Office文件操作帮助类
愚公搬代码 发表于 2021/10/18 23:25:00 2021/10/18
【摘要】 using Aspose.Cells; using System; using System.Data; using System.IO; using System.Text; namespace Co...
using Aspose.Cells;
using System;
using System.Data;
using System.IO;
using System.Text;
namespace Core.Util
    /// <summary>
    /// 使用Aspose组件的Office文件操作帮助类
    /// </summary>
    public class AsposeOfficeHelper
        static AsposeOfficeHelper()
            //注册EncodingProvider防止乱码
            Encoding.RegisterProvider(CodePagesEncodingProvider.Instance);
        /// <summary>
        /// 将DataTable输出为字节数组
        /// </summary>
        /// <param name="dt">表格数据</param>
        /// <returns>Byte数组</returns>
        public static byte[] DataTableToExcelBytes(DataTable dt)
            Workbook book = new Workbook();
            Worksheet sheet = book.Worksheets[0];
            Cells cells = sheet.Cells;
            int Colnum = dt.Columns.Count;//表格列数
            int Rownum = dt.Rows.Count;//表格行数
            //生成行 列名行
            for (int i = 0; i < Colnum; i++)
                cells[0, i].PutValue(dt.Columns[i].ColumnName);
            //生成数据行
            for (int i = 0; i < Rownum; i++)
                for (int k = 0; k < Colnum; k++)
                    cells[1 + i, k].PutValue(dt.Rows[i][k].ToString());
            //自动行高,列宽
            sheet.AutoFitColumns();
            sheet.AutoFitRows();
            //将DataTable写入内存流
            var ms = new MemoryStream();
            book.Save(ms, SaveFormat.Excel97To2003);
            return ms.ToArray();
        /// <summary>
        /// 通过模板导出Excel
        /// </summary>
        /// <param name="templateFile">模板</param>
        /// <param name="dataSource">数据源</param>
        /// <returns>文件Byte[]</returns>
        public static byte[] ExportExcelByTemplate(string templateFile, params (string SourceName, object Data)[] dataSource)
            if (templateFile.IsNullOrEmpty())
                throw new Exception("模板不能为空");
            if (dataSource.Length == 0)
                throw new Exception("数据源不能为空");
            WorkbookDesigner designer = new WorkbookDesigner
                Workbook = new Workbook(templateFile)
            var workBook = designer.Workbook;
            dataSource.ForEach(aDataSource =>
                designer.SetDataSource(aDataSource.SourceName, aDataSource.Data);
            designer.Process();
            using (MemoryStream stream = new MemoryStream())
                workBook.Save(stream, SaveFormat.Excel97To2003);
                var fileBytes = stream.ToArray();
                return fileBytes;
        /// <summary>
        /// 从excel文件导入数据
        /// 注:默认将第一行当作标题行,即不当作数据
        /// </summary>
        /// <param name="fileNmae">文件名</param>
        /// <returns></returns>
        public static DataTable ReadExcel(string fileNmae)
            Workbook book = new Workbook(fileNmae);
            return cells.ExportDataTableAsString(0, 0, cells.MaxDataRow + 1, cells.MaxDataColumn + 1, true);
        /// <summary>
        /// 从excel文件导入数据
        /// </summary>
        /// <param name="exportColumnName">是否将第一行当作标题行</param>
        public static DataTable ReadExcel(string fileNmae,bool exportColumnName)
            return cells.ExportDataTableAsString(0, 0, cells.MaxDataRow + 1, cells.MaxDataColumn + 1, exportColumnName);
        /// <summary>
        /// 从excel文件字节源导入
        /// </summary>
        /// <param name="fileBytes">文件字节源</param>
        public static DataTable ReadExcel(byte[] fileBytes)
            return ReadExcel(fileBytes, true);
        /// <summary>
        /// 从excel文件字节源导入
        /// </summary>
        public static DataTable ReadExcel(byte[] fileBytes,bool exportColumnName)
            using (MemoryStream ms = new MemoryStream(fileBytes))
                Workbook book = new Workbook(ms);
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
文章来源: codeboy.blog.csdn.net,作者:愚公搬代码,版权归原作者所有,如需转载,请联系作者。
原文链接:codeboy.blog.csdn.net/article/details/106965913
