(精华)2020年6月26日 C#类库 Ip地址帮助类
愚公搬代码 发表于 2021/10/19 01:21:02 2021/10/19
【摘要】 using System.Collections; using System.Net; using System.Net.NetworkInformation; using System.Net.Sock...
using System.Net;
using System.Net.Sockets;
namespace Core.Util
    /// <summary>
    /// Ip地址帮助类
    /// </summary>
    public class IpHelper
        #region 外部接口
        /// <summary>
        /// 获取本地IP地址
        /// </summary>
        /// <returns></returns>
        public static string GetLocalIp()
            UnicastIPAddressInformation mostSuitableIp = null;
            var networkInterfaces = NetworkInterface.GetAllNetworkInterfaces();
            foreach (var network in networkInterfaces)
                if (network.OperationalStatus != OperationalStatus.Up)
                    continue;
                var properties = network.GetIPProperties();
                if (properties.GatewayAddresses.Count == 0)
                    continue;
                foreach (var address in properties.UnicastAddresses)
                    if (address.Address.AddressFamily != AddressFamily.InterNetwork)
                        continue;
                    if (IPAddress.IsLoopback(address.Address))
                        continue;
                    return address.Address.ToString();
            return mostSuitableIp != null
                ? mostSuitableIp.Address.ToString()
        /// <summary>
        /// 获取第一个可用的端口号
        /// </summary>
        public static int GetFirstAvailablePort()
            int BEGIN_PORT = 1024;//从这个端口开始检测
            int MAX_PORT = 65535; //系统tcp/udp端口数最大是65535
            for (int i = BEGIN_PORT; i < MAX_PORT; i++)
                if (PortIsAvailable(i)) return i;
            return -1;
        /// <summary>
        /// 检查指定端口是否已用
        /// </summary>
        /// <param name="port"></param>
        public static bool PortIsAvailable(int port)
            bool isAvailable = true;
            IList portUsed = PortIsUsed();
            foreach (int p in portUsed)
                if (p == port)
                    isAvailable = false; break;
            return isAvailable;
        #endregion
        #region 私有成员
        /// <summary>
        /// 获取操作系统已用的端口号
        /// </summary>
        private static IList PortIsUsed()
            //获取本地计算机的网络连接和通信统计数据的信息
            IPGlobalProperties ipGlobalProperties = IPGlobalProperties.GetIPGlobalProperties();
            //返回本地计算机上的所有Tcp监听程序
            IPEndPoint[] ipsTCP = ipGlobalProperties.GetActiveTcpListeners();
            //返回本地计算机上的所有UDP监听程序
            IPEndPoint[] ipsUDP = ipGlobalProperties.GetActiveUdpListeners();
            //返回本地计算机上的Internet协议版本4(IPV4 传输控制协议(TCP)连接的信息。
            TcpConnectionInformation[] tcpConnInfoArray = ipGlobalProperties.GetActiveTcpConnections();
            IList allPorts = new ArrayList();
            foreach (IPEndPoint ep in ipsTCP) allPorts.Add(ep.Port);
            foreach (IPEndPoint ep in ipsUDP) allPorts.Add(ep.Port);
            foreach (TcpConnectionInformation conn in tcpConnInfoArray) allPorts.Add(conn.LocalEndPoint.Port);
            return allPorts;
        #endregion
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
文章来源: codeboy.blog.csdn.net,作者:愚公搬代码,版权归原作者所有,如需转载,请联系作者。
原文链接:codeboy.blog.csdn.net/article/details/106969541
