(精华)2020年6月26日 C#类库 Quartz任务调度帮助类
愚公搬代码 发表于 2021/10/19 00:54:44 2021/10/19
【摘要】 using Quartz; using Quartz.Impl; using System; using System.Collections.Concurrent; using System.Threa...
using Quartz;
using Quartz.Impl;
using System;
using System.Threading.Tasks;
namespace Core.Util
    /// <summary>
    /// 任务帮助类
    /// </summary>
    public static class JobHelper
        #region 私有成员
        private static IScheduler __scheduler;
        private static object _lock = new object();
        private static IScheduler _scheduler
            get
                if (__scheduler == null)
                    lock (_lock)
                            __scheduler = AsyncHelper.RunSync(() => StdSchedulerFactory.GetDefaultScheduler());
                            AsyncHelper.RunSync(() => __scheduler.Start());
                return __scheduler;
        static ConcurrentDictionary<string, Action> _jobs { get; }
            = new ConcurrentDictionary<string, Action>();
        #endregion
        #region 外部接口
        /// <summary>
        /// 设置一个时间间隔的循环操作
        /// </summary>
        /// <param name="action">执行的操作</param>
        /// <param name="timeSpan">时间间隔</param>
        /// <returns>任务标识Id</returns>
        public static string SetIntervalJob(Action action, TimeSpan timeSpan)
            string key = Guid.NewGuid().ToString();
            _jobs[key] = action;
            IJobDetail job = JobBuilder.Create<Job>()
               .WithIdentity(key)
               .Build();
            ITrigger trigger = TriggerBuilder.Create()
                .WithIdentity(key)
                .StartNow()
                .WithSimpleSchedule(x => x.WithInterval(timeSpan).RepeatForever())
                .Build();
            AsyncHelper.RunSync(() => _scheduler.ScheduleJob(job, trigger));
            return key;
        /// <summary>
        /// 设置每天定时任务
        /// </summary>
        /// <param name="action">执行的任务</param>
        /// <param name="h">时</param>
        /// <param name="m">分</param>
        /// <param name="s">秒</param>
        public static string SetDailyJob(Action action, int h, int m, int s)
               .WithIdentity(key)
               .Build();
                .WithIdentity(key)
                .StartNow()
                .WithCronSchedule($"{s} {m} {h} * * ?")//每天定时
                .Build();
            return key;
        /// <summary>
        /// 设置延时任务,仅执行一次
        /// </summary>
        /// <param name="delay">延时时间</param>
        public static string SetDelayJob(Action action, TimeSpan delay)
            action += () =>
                RemoveJob(key);
               .WithIdentity(key)
               .Build();
                .WithIdentity(key)
                .StartAt(DateTime.Now + delay)
                .WithSimpleSchedule(x => x.WithRepeatCount(0).WithInterval(TimeSpan.FromSeconds(10)))
                .Build();
            return key;
        /// <summary>
        /// 通过表达式创建任务
        /// 表达式规则参考:http://www.jsons.cn/quartzcron/
        /// </summary>
        /// <param name="cronExpression">表达式</param>
        /// <returns></returns>
        public static string SetCronJob(Action action, string cronExpression)
               .WithIdentity(key)
               .Build();
                .WithIdentity(key)
                .StartNow()
                .WithCronSchedule(cronExpression)
                .Build();
            return key;
        /// <summary>
        /// 删除任务
        /// </summary>
        /// <param name="jobId">任务标识Id</param>
        public static void RemoveJob(string jobId)
            AsyncHelper.RunSync(() => _scheduler.DeleteJob(new JobKey(jobId)));
            _jobs.TryRemove(jobId, out _);
        #endregion
        #region 内部类
        private class Job : IJob
            public async Task Execute(IJobExecutionContext context)
                await Task.Run(() =>
                    string jobName = context.JobDetail.Key.Name;
                    if (_jobs.ContainsKey(jobName))
                        _jobs[jobName]?.Invoke();
        #endregion
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
文章来源: codeboy.blog.csdn.net,作者:愚公搬代码,版权归原作者所有,如需转载,请联系作者。
原文链接:codeboy.blog.csdn.net/article/details/106969569
