(精华)2020年6月27日 C#类库 一致性HASH帮助类
愚公搬代码 发表于 2021/10/18 23:13:22 2021/10/18
【摘要】 using System; using System.Collections.Generic; using System.Linq; using System.Text; namespace Core....
using System;
using System.Linq;
using System.Text;
namespace Core.Util
    /// <summary>
    /// 一致性HASH,解决传统HASH的扩容难的问题
    /// 注:常用与分布式缓存与分表
    /// </summary>
    /// <typeparam name="T">泛型</typeparam>
    public class ConsistentHash<T>
        SortedDictionary<int, T> circle { get; set; } = new SortedDictionary<int, T>();//虚拟的圆环,对2的32方取模
        int _replicate = 100;    //虚拟节点数 count
        int[] ayKeys = null;    //缓存节点hash
        /// <summary>
        /// 初始化可迭代的节点数
        /// </summary>
        /// <param name="nodes">节点</param>
        public void Init(IEnumerable<T> nodes)
            Init(nodes, _replicate);
        /// <summary>
        /// 初始化可迭代的节点数,默认不缓存
        /// </summary>
        /// <param name="replicate"></param>
        public void Init(IEnumerable<T> nodes, int replicate)
            _replicate = replicate;
            foreach (T node in nodes)
                this.Add(node, false);
            ayKeys = circle.Keys.ToArray();
        /// <summary>
        /// 添加节点,缓存
        /// </summary>
        /// <param name="node"></param>
        public void Add(T node)
            Add(node, true);
        /// <summary>
        /// 添加虚拟的圆环的节点
        /// </summary>
        /// <param name="node">节点</param>
        /// <param name="updateKeyArray">是否缓存node的hash</param>
        private void Add(T node, bool updateKeyArray)
            for (int i = 0; i < _replicate; i++)
                int hash = BetterHash(node.GetHashCode().ToString() + i);
                circle[hash] = node;
            if (updateKeyArray)
        /// <summary>
        /// 删除真实机器节点,更新缓存
        /// </summary>
        public void Remove(T node)
                if (!circle.Remove(hash))
                    throw new Exception("can not remove a node that not added");
        /// <summary>
        /// 判断是否存在key对应的hash,有则返回没有返回最近一个节点
        /// </summary>
        /// <param name="key"></param>
        /// <returns></returns>
        private T GetNode_slow(String key)
            int hash = BetterHash(key);
            if (circle.ContainsKey(hash))
                return circle[hash];
            // 沿环的顺时针找到一个节点
            int first = circle.Keys.FirstOrDefault(h => h >= hash);
            if (first == new int())
                first = ayKeys[0];
            T node = circle[first];
            return node;
        int First_ge(int[] ay, int val)
            int begin = 0;
            int end = ay.Length - 1;
            if (ay[end] < val || ay[0] > val)
                return 0;
            int mid = begin;
            while (end - begin > 1)
                mid = (end + begin) / 2;
                if (ay[mid] >= val)
                    end = mid;
                else
                    begin = mid;
            if (ay[begin] > val || ay[end] < val)
                throw new Exception("should not happen");
            return end;
        public T GetNode(String key)
            int first = First_ge(ayKeys, hash);
            return circle[ayKeys[first]];
        /// <summary>
        /// MurMurHash2算法,性能高,碰撞率低
        /// </summary>
        /// <param name="key">计算hash的字符串</param>
        /// <returns>hash值</returns>
        public static int BetterHash(String key)
            uint hash = MurmurHash2.Hash(Encoding.ASCII.GetBytes(key));
            return (int)hash;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
MurMurHash2算法
using System;
using System.Runtime.InteropServices;
namespace Core.Util
    public class MurmurHash2
        public static UInt32 Hash(Byte[] data)
            return Hash(data, 0xc58f1a7b);
        const UInt32 m = 0x5bd1e995;
        const Int32 r = 24;
        [StructLayout(LayoutKind.Explicit)]
        struct BytetoUInt32Converter
            [FieldOffset(0)]
            public Byte[] Bytes;
            [FieldOffset(0)]
            public UInt32[] UInts;
        public static UInt32 Hash(Byte[] data, UInt32 seed)
            Int32 length = data.Length;
            if (length == 0)
                return 0;
            UInt32 h = seed ^ (UInt32)length;
            Int32 currentIndex = 0;
            // array will be length of Bytes but contains Uints
            // therefore the currentIndex will jump with +1 while length will jump with +4
            UInt32[] hackArray = new BytetoUInt32Converter { Bytes = data }.UInts;
            while (length >= 4)
                UInt32 k = hackArray[currentIndex++];
                k *= m;
                k ^= k >> r;
                k *= m;
                h *= m;
                h ^= k;
                length -= 4;
            currentIndex *= 4; // fix the length
            switch (length)
                case 3:
                    h ^= (UInt16)(data[currentIndex++] | data[currentIndex++] << 8);
                    h ^= (UInt32)data[currentIndex] << 16;
                    h *= m;
                    break;
                case 2:
                    h ^= (UInt16)(data[currentIndex++] | data[currentIndex] << 8);
                    h *= m;
                    break;
                case 1:
                    h ^= data[currentIndex];
                    h *= m;
                    break;
                default:
                    break;
            // Do a few final mixes of the hash to ensure the last few
            // bytes are well-incorporated.
            h ^= h >> 13;
            h *= m;
            h ^= h >> 15;
            return h;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
文章来源: codeboy.blog.csdn.net,作者:愚公搬代码,版权归原作者所有,如需转载,请联系作者。
原文链接:codeboy.blog.csdn.net/article/details/106982042
