(精华)2020年6月27日 C#类库 DbHelper(Ado.net数据库封装)
愚公搬代码 发表于 2021/10/19 01:47:58 2021/10/19
【摘要】 using EFCore.Sharding; using System; using System.Collections.Generic; using System.Data; using System...
using System;
using System.Data;
using System.Data.Common;
using System.IO;
namespace Core.Util
    /// <summary>
    /// 描述:数据库操作抽象帮助类
    /// </summary>
    public abstract class DbHelper
        #region 构造函数
        /// <summary>
        /// 构造函数
        /// </summary>
        /// <param name="dbType">数据库类型</param>
        /// <param name="conString">完整连接字符串</param>
        public DbHelper(DatabaseType dbType, string conString)
            _dbType = dbType;
            _conString = conString;
        #endregion
        #region 私有成员
        /// <summary>
        /// 数据库类型
        /// </summary>
        protected DatabaseType _dbType;
        /// <summary>
        /// 连接字符串
        /// </summary>
        protected string _conString;
        /// <summary>
        /// 实体需要引用的额外命名空间
        /// </summary>
        protected string _extraUsingNamespace { get; set; } = string.Empty;
        /// <summary>
        /// 类型映射字典
        /// </summary>
        protected abstract Dictionary<string, Type> DbTypeDic { get; }
        #endregion
        #region 外部接口
        /// <summary>
        /// 通过数据库连接字符串和Sql语句查询返回DataTable
        /// </summary>
        /// <param name="sql">Sql语句</param>
        /// <returns></returns>
        public DataTable GetDataTableWithSql(string sql)
            DbProviderFactory dbProviderFactory = DbProviderFactoryHelper.GetDbProviderFactory(_dbType);
            using (DbConnection conn = dbProviderFactory.CreateConnection())
                conn.ConnectionString = _conString;
                if (conn.State != ConnectionState.Open)
                    conn.Open();
                using (DbCommand cmd = conn.CreateCommand())
                    cmd.Connection = conn;
                    cmd.CommandText = sql;
                    DbDataAdapter adapter = dbProviderFactory.CreateDataAdapter();
                    adapter.SelectCommand = cmd;
                    DataSet table = new DataSet();
                    adapter.Fill(table);
                    return table.Tables[0];
        /// <summary>
        /// 通过数据库连接字符串和Sql语句查询返回DataTable,参数化查询
        /// </summary>
        /// <param name="parameters">参数</param>
        public DataTable GetDataTableWithSql(string sql, List<DbParameter> parameters)
                    conn.Open();
                    if (parameters != null && parameters.Count > 0)
                        foreach (var item in parameters)
                            cmd.Parameters.Add(item);
                    cmd.Parameters.Clear();
        /// <summary>
        /// 通过数据库连接字符串和Sql语句查询返回List
        /// </summary>
        /// <typeparam name="T">实体类</typeparam>
        /// <param name="sqlStr">Sql语句</param>
        public List<T> GetListBySql<T>(string sqlStr)
            return GetDataTableWithSql(sqlStr).ToList<T>();
        /// <summary>
        /// 通过数据库连接字符串和Sql语句查询返回List,参数化查询
        /// </summary>
        /// <param name="param">查询参数</param>
        public List<T> GetListBySql<T>(string sqlStr, List<DbParameter> param)
            return GetDataTableWithSql(sqlStr, param).ToList<T>();
        /// <summary>
        /// 执行无返回值的Sql语句
        /// </summary>
        public int ExecuteSql(string sql)
            int count = 0;
                    conn.Open();
                using (DbCommand cmd = dbProviderFactory.CreateCommand())
                    count = cmd.ExecuteNonQuery();
                    return count;
        /// <summary>
        /// 执行无返回值的Sql语句
        /// </summary>
        /// <param name="paramters"></param>
        public int ExecuteSql(string sql, List<DbParameter> paramters)
            int count = 0;
                    conn.Open();
                    if (paramters != null && paramters.Count > 0)
                        foreach (var item in paramters)
                    return count;
        /// <summary>
        /// 获取数据库中的所有表
        /// </summary>
        /// <param name="schemaName">模式(架构)</param>
        public abstract List<DbTableInfo> GetDbAllTables(string schemaName = null);
        /// <summary>
        /// 通过连接字符串和表名获取数据库表的信息
        /// </summary>
        /// <param name="tableName">表名</param>
        public abstract List<TableInfo> GetDbTableInfo(string tableName);
        /// <summary>
        /// 将数据库类型转为对应C#数据类型
        /// </summary>
        /// <param name="dbTypeStr">数据类型</param>
        public virtual Type DbTypeStr_To_CsharpType(string dbTypeStr)
            string _dbTypeStr = dbTypeStr.ToLower();
            Type type = null;
            if (DbTypeDic.ContainsKey(_dbTypeStr))
                type = DbTypeDic[_dbTypeStr];
            else
                type = typeof(string);
            return type;
        /// <summary>
        /// 生成实体文件
        /// </summary>
        /// <param name="infos">表字段信息</param>
        /// <param name="tableDescription">表描述信息</param>
        /// <param name="filePath">文件路径(包含文件名)</param>
        /// <param name="nameSpace">实体命名空间</param>
        /// <param name="schemaName">架构(模式)名</param>
        public virtual void SaveEntityToFile(List<TableInfo> infos, string tableName, string tableDescription, string filePath, string nameSpace, string schemaName = null)
            string properties = "";
            string schema = "";
            if (!schemaName.IsNullOrEmpty())
                schema = $@", Schema = ""{schemaName}""";
            infos.ForEach((item, index) =>
                string isKey = item.IsKey ? $@"
        [Key, Column(Order = {index + 1})]" : "";
                Type type = DbTypeStr_To_CsharpType(item.Type);
                string isNullable = item.IsNullable && type.IsValueType ? "?" : "";
                string description = item.Description.IsNullOrEmpty() ? item.Name : item.Description;
                string newPropertyStr =
        /// <summary>
        /// {description}
        /// </summary>{isKey}
        public {type.Name}{isNullable} {item.Name} {{ get; set; }}
                properties += newPropertyStr;
            string fileStr =
$@"using System;
using System.ComponentModel.DataAnnotations;
using System.ComponentModel.DataAnnotations.Schema;
{_extraUsingNamespace}
namespace {nameSpace}
    /// <summary>
    /// {tableDescription}
    /// </summary>
    [Table(""{tableName}""{schema})]
    public class {tableName}
{properties}
            FileHelper.WriteTxt(fileStr, filePath, FileMode.Create);
        #endregion
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
  • 224
  • 225
  • 226
  • 227
  • 228
  • 229
  • 230
  • 231
  • 232
  • 233
  • 234
  • 235
  • 236
  • 237
  • 238
  • 239
  • 240
  • 241
  • 242
  • 243
  • 244
  • 245
  • 246
  • 247
  • 248
  • 249
  • 250
  • 251
  • 252
  • 253
  • 254
  • 255
  • 256
  • 257
  • 258
  • 259
  • 260
  • 261
  • 262
  • 263
  • 264
  • 265
  • 266
  • 267
  • 268
  • 269
  • 270
  • 271
  • 272
  • 273
  • 274
  • 275
  • 276
  • 277
  • 278
  • 279
  • 280
  • 281
  • 282
  • 283
  • 284
  • 285
  • 286
  • 287
  • 288
  • 289
  • 290
  • 291
  • 292
  • 293
  • 294
  • 295
文章来源: codeboy.blog.csdn.net,作者:愚公搬代码,版权归原作者所有,如需转载,请联系作者。
原文链接:codeboy.blog.csdn.net/article/details/106979924
