(精华)2020年6月29日 C#类库 JWT校验
愚公搬代码 发表于 2021/10/18 23:36:12 2021/10/18
【摘要】 using Coldairarrow.Util; using Microsoft.AspNetCore.Mvc.Filters; using System; using System.Threading....
using System;
using System.Threading.Tasks;
namespace Core.Api
    /// <summary>
    /// JWT校验
    /// </summary>
    public class CheckJWTAttribute : BaseActionFilterAsync
        private static readonly int _errorCode = 401;
        public override async Task OnActionExecuting(ActionExecutingContext context)
            if (context.ContainsFilter<NoCheckJWTAttribute>())
                return;
            try
                var req = context.HttpContext.Request;
                string token = req.GetToken();
                if (token.IsNullOrEmpty())
                    context.Result = Error("缺少token", _errorCode);
                    return;
                if (!JWTHelper.CheckToken(token, JWTHelper.JWTSecret))
                    context.Result = Error("token校验失败!", _errorCode);
                    return;
                var payload = JWTHelper.GetPayload<JWTPayload>(token);
                if (payload.Expire < DateTime.Now)
                    context.Result = Error("token过期!", _errorCode);
                    return;
            catch (Exception ex)
                context.Result = Error(ex.Message, _errorCode);
            await Task.CompletedTask;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
namespace Core.Api
    /// <summary>
    /// 忽略JWT校验
    /// </summary>
    public class NoCheckJWTAttribute : BaseActionFilterAsync
文章来源: codeboy.blog.csdn.net,作者:愚公搬代码,版权归原作者所有,如需转载,请联系作者。
原文链接:codeboy.blog.csdn.net/article/details/107014851
