(精华)2020年6月26日 C#类库 DataTable(扩展方法)
愚公搬代码 发表于 2021/10/19 01:51:59 2021/10/19
【摘要】 using System; using System.Collections.Generic; using System.Data; using System.Reflection; using Syst...
using System;
using System.Data;
using System.Text;
namespace Core.Util
    public static partial class Extention
        /// <summary>
        /// DataTable转List
        /// </summary>
        /// <typeparam name="T">转换类型</typeparam>
        /// <param name="dt">数据源</param>
        /// <returns></returns>
        public static List<T> ToList<T>(this DataTable dt)
            List<T> list = new List<T>();
            //确认参数有效,若无效则返回Null
            if (dt == null)
                return list;
            else if (dt.Rows.Count == 0)
                return list;
            Dictionary<string, string> dicField = new Dictionary<string, string>();
            Dictionary<string, string> dicProperty = new Dictionary<string, string>();
            Type type = typeof(T);
            //创建字段字典,方便查找字段名
            type.GetFields().ForEach(aFiled =>
                dicField.Add(aFiled.Name.ToLower(), aFiled.Name);
            //创建属性字典,方便查找属性名
            type.GetProperties().ForEach(aProperty =>
                dicProperty.Add(aProperty.Name.ToLower(), aProperty.Name);
            for (int i = 0; i < dt.Rows.Count; i++)
                //创建泛型对象
                T _t = Activator.CreateInstance<T>();
                for (int j = 0; j < dt.Columns.Count; j++)
                    string memberKey = dt.Columns[j].ColumnName.ToLower();
                    //字段赋值
                    if (dicField.ContainsKey(memberKey))
                        FieldInfo theField = type.GetField(dicField[memberKey]);
                        var dbValue = dt.Rows[i][j];
                        if (dbValue.GetType() == typeof(DBNull))
                            dbValue = null;
                        if (dbValue != null)
                            Type memberType = theField.FieldType;
                            dbValue = dbValue.ChangeType_ByConvert(memberType);
                        theField.SetValue(_t, dbValue);
                    //属性赋值
                    if (dicProperty.ContainsKey(memberKey))
                        PropertyInfo theProperty = type.GetProperty(dicProperty[memberKey]);
                            dbValue = null;
                            Type memberType = theProperty.PropertyType;
                        theProperty.SetValue(_t, dbValue);
                list.Add(_t);
            return list;
        /// <summary>
        ///将DataTable转换为标准的CSV字符串
        /// </summary>
        /// <param name="dt">数据表</param>
        /// <returns>返回标准的CSV</returns>
        public static string ToCsvStr(this DataTable dt)
            //以半角逗号(即,)作分隔符,列为空也要表达其存在。
            //列内容如存在半角逗号(即,)则用半角引号(即"")将该字段值包含起来。
            //列内容如存在半角引号(即")则应替换成半角双引号("")转义,并用半角引号(即"")将该字段值包含起来。
            StringBuilder sb = new StringBuilder();
            DataColumn colum;
            foreach (DataRow row in dt.Rows)
                for (int i = 0; i < dt.Columns.Count; i++)
                    colum = dt.Columns[i];
                    if (i != 0) sb.Append(",");
                    if (colum.DataType == typeof(string) && row[colum].ToString().Contains(","))
                        sb.Append("\"" + row[colum].ToString().Replace("\"", "\"\"") + "\"");
                    else sb.Append(row[colum].ToString());
                sb.AppendLine();
            return sb.ToString();
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
文章来源: codeboy.blog.csdn.net,作者:愚公搬代码,版权归原作者所有,如需转载,请联系作者。
原文链接:codeboy.blog.csdn.net/article/details/106971490
