(精华)2020年6月26日 C#类库 ExpandoObject(扩展方法)
愚公搬代码 发表于 2021/10/18 23:28:40 2021/10/18
【摘要】 using System; using System.Collections.Generic; using System.Data; using System.Dynamic; using System....
using System;
using System.Data;
using System.Linq;
namespace Core.Util
    public static partial class Extention
        /// <summary>
        /// 添加属性
        /// </summary>
        /// <param name="expandoObj">动态对象</param>
        /// <param name="propertyName">属性名</param>
        /// <param name="value">属性值</param>
        public static void AddProperty(this ExpandoObject expandoObj,string propertyName,object value)
            var obj = (IDictionary<string, object>)expandoObj;
            if (obj.ContainsKey(propertyName))
                throw new Exception("已存在该属性!");
            else
                obj.Add(propertyName, value);
        /// <summary>
        /// 设置属性
        /// </summary>
        public static void SetProperty(this ExpandoObject expandoObj, string propertyName, object value)
            if (!obj.ContainsKey(propertyName))
            else
                obj[propertyName] = value;
        /// <summary>
        /// 获取属性
        /// </summary>
        /// <returns></returns>
        public static object GetProperty(this ExpandoObject expandoObj, string propertyName)
                throw new Exception("不存在该属性!");
            else
                return obj[propertyName];
        /// <summary>
        /// 获取所有属性
        /// </summary>
        public static List<string> GetProperties(this ExpandoObject expandoObj)
            return obj.Keys.CastToList<string>();
        /// <summary>
        /// 删除属性
        /// </summary>
        public static void RemoveProperty(this ExpandoObject expandoObj, string propertyName)
            else
                obj.Remove(propertyName);
        /// <summary>
        /// 将动态属性对象ExpandoObject列表转为DataTable
        /// </summary>
        /// <param name="dataList">数据源</param>
        public static DataTable ToDataTable(this IEnumerable<ExpandoObject> dataList)
            DataTable dt = new DataTable();
            if (dataList.IsNullOrEmpty())
                return null;
            else if (dataList.Count() == 0)
                return dt;
            else
                var aEntity = dataList.FirstOrDefault();
                var properties = aEntity.GetProperties();
                properties.ForEach(aProperty =>
                    dt.Columns.Add(aProperty);
                dataList.ForEach((aData,index) =>
                    dt.Rows.Add(dt.NewRow());
                        dt.Rows[index][aProperty] = aData.GetProperty(aProperty);
            return dt;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
文章来源: codeboy.blog.csdn.net,作者:愚公搬代码,版权归原作者所有,如需转载,请联系作者。
原文链接:codeboy.blog.csdn.net/article/details/106971827
