(精华)2020年6月26日 C#类库 HttpRequest(扩展方法)
愚公搬代码 发表于 2021/10/19 00:50:32 2021/10/19
【摘要】 using Microsoft.AspNetCore.Http; using Microsoft.AspNetCore.Http.Extensions; using System; using Syste...
using System;
using System.Text.RegularExpressions;
namespace Core.Util
    /// <summary>
    /// 拓展类
    /// </summary>
    public static partial class Extention
        /// <summary>
        /// 判断是否为AJAX请求
        /// </summary>
        /// <param name="req"></param>
        /// <returns></returns>
        public static bool IsAjaxRequest(this HttpRequest req)
            bool result = false;
            var xreq = req.Headers.ContainsKey("x-requested-with");
            if (xreq)
                result = req.Headers["x-requested-with"] == "XMLHttpRequest";
            return result;
        /// <summary>
        /// 获取去掉查询参数的Url
        /// </summary>
        /// <param name="req">请求</param>
        public static string GetDisplayUrlNoQuery(this HttpRequest req)
            var queryStr = req.QueryString.ToString();
            var displayUrl = req.GetDisplayUrl();
            return queryStr.IsNullOrEmpty() ? displayUrl : displayUrl.Replace(queryStr, "");
        /// <summary>
        /// 获取Token
        /// </summary>
        public static string GetToken(this HttpRequest req)
            string tokenHeader = req.Headers["Authorization"].ToString();
            if (tokenHeader.IsNullOrEmpty())
                return null;
            string pattern = "^Bearer (.*?)$";
            if (!Regex.IsMatch(tokenHeader, pattern))
                throw new Exception("token格式不对!格式为:Bearer {token}");
            string token = Regex.Match(tokenHeader, pattern).Groups[1]?.ToString();
            if (token.IsNullOrEmpty())
                throw new Exception("token不能为空!");
            return token;
        /// <summary>
        /// 获取Token中的Payload
        /// </summary>
        public static JWTPayload GetJWTPayload(this HttpRequest req)
            string token = req.GetToken();
            var payload = JWTHelper.GetPayload<JWTPayload>(token);
            return payload;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
文章来源: codeboy.blog.csdn.net,作者:愚公搬代码,版权归原作者所有,如需转载,请联系作者。
原文链接:codeboy.blog.csdn.net/article/details/106971993
