(精华)2020年7月17日 vue element-ui实现弹窗拖拽
愚公搬代码 发表于 2021/10/18 23:16:22 2021/10/18
【摘要】 export default { bind(el, binding, vnode) { const dialogHeaderEl = el.querySelector('.el-dialog_...
export default {
    const dialogHeaderEl = el.querySelector('.el-dialog__header')
    const dragDom = el.querySelector('.el-dialog')
    dialogHeaderEl.style.cssText += ';cursor:move;'
    dragDom.style.cssText += ';top:0px;'
    // 获取原有属性 ie dom元素.currentStyle 火狐谷歌 window.getComputedStyle(dom元素, null);
    const getStyle = (function() {
      if (window.document.currentStyle) {
        return (dom, attr) => dom.currentStyle[attr]
        return (dom, attr) => getComputedStyle(dom, false)[attr]
    dialogHeaderEl.onmousedown = (e) => {
      // 鼠标按下,计算当前元素距离可视区的距离
      const disX = e.clientX - dialogHeaderEl.offsetLeft
      const disY = e.clientY - dialogHeaderEl.offsetTop
      const dragDomWidth = dragDom.offsetWidth
      const dragDomHeight = dragDom.offsetHeight
      const screenWidth = document.body.clientWidth
      const screenHeight = document.body.clientHeight
      const minDragDomLeft = dragDom.offsetLeft
      const maxDragDomLeft = screenWidth - dragDom.offsetLeft - dragDomWidth
      const minDragDomTop = dragDom.offsetTop
      const maxDragDomTop = screenHeight - dragDom.offsetTop - dragDomHeight
      // 获取到的值带px 正则匹配替换
      let styL = getStyle(dragDom, 'left')
      let styT = getStyle(dragDom, 'top')
      if (styL.includes('%')) {
        styL = +document.body.clientWidth * (+styL.replace(/\%/g, '') / 100)
        styT = +document.body.clientHeight * (+styT.replace(/\%/g, '') / 100)
        styL = +styL.replace(/\px/g, '')
        styT = +styT.replace(/\px/g, '')
      document.onmousemove = function(e) {
        // 通过事件委托,计算移动的距离
        let left = e.clientX - disX
        let top = e.clientY - disY
        // 边界处理
        if (-(left) > minDragDomLeft) {
          left = -minDragDomLeft
        } else if (left > maxDragDomLeft) {
          left = maxDragDomLeft
        if (-(top) > minDragDomTop) {
          top = -minDragDomTop
        } else if (top > maxDragDomTop) {
          top = maxDragDomTop
        // 移动当前元素
        dragDom.style.cssText += `;left:${left + styL}px;top:${top + styT}px;`
        // emit onDrag event
        vnode.child.$emit('dragDialog')
      document.onmouseup = function(e) {
        document.onmousemove = null
        document.onmouseup = null
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
import drag from './drag'
const install = function(Vue) {
  Vue.directive('el-drag-dialog', drag)
if (window.Vue) {
  window['el-drag-dialog'] = drag
  Vue.use(install); // eslint-disable-line
drag.install = install
export default drag
<template>
  <div class="components-container">
    <el-button type="primary" @click="dialogTableVisible = true">
      open a Drag Dialog
    </el-button>
    <el-dialog v-el-drag-dialog :visible.sync="dialogTableVisible" title="Shipping address" @dragDialog="handleDrag">
      <el-select ref="select" v-model="value" placeholder="请选择">
        <el-option v-for="item in options" :key="item.value" :label="item.label" :value="item.value" />
      </el-select>
      <el-table :data="gridData">
        <el-table-column property="date" label="Date" width="150" />
        <el-table-column property="name" label="Name" width="200" />
        <el-table-column property="address" label="Address" />
      </el-table>
    </el-dialog>
  </div>
</template>
<script>
import elDragDialog from '@/directive/el-drag-dialog' // base on element-ui
export default {
  directives: { elDragDialog },
  data() {
    return {
      dialogTableVisible: false,
      options: [
        { value: '选项1', label: '黄金糕' },
        { value: '选项2', label: '双皮奶' },
        { value: '选项3', label: '蚵仔煎' },
        { value: '选项4', label: '龙须面' }
      value: '',
      gridData: [{
        date: '2016-05-02',
        address: 'No.1518,  Jinshajiang Road, Putuo District'
        date: '2016-05-04',
        date: '2016-05-01',
        date: '2016-05-03',
  methods: {
    // v-el-drag-dialog onDrag callback function
    handleDrag() {
      this.$refs.select.blur()
</script>
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
文章来源: codeboy.blog.csdn.net,作者:愚公搬代码,版权归原作者所有,如需转载,请联系作者。
原文链接:codeboy.blog.csdn.net/article/details/107407743
