(精华)2020年7月17日 vue 实现element-ui的select可拖拽
愚公搬代码 发表于 2021/10/18 23:55:00 2021/10/18
【摘要】 <template> <el-select ref="dragSelect" v-model="selectVal" v-bind="$attrs" class="drag-sele...
<template>
  <el-select ref="dragSelect" v-model="selectVal" v-bind="$attrs" class="drag-select" multiple v-on="$listeners">
    <slot />
  </el-select>
</template>
<script>
import Sortable from 'sortablejs'
export default {
  props: {
    value: {
      type: Array,
      required: true
  computed: {
    selectVal: {
      get() {
        return [...this.value]
      set(val) {
        this.$emit('input', [...val])
  mounted() {
    this.setSort()
  methods: {
    setSort() {
      const el = this.$refs.dragSelect.$el.querySelectorAll('.el-select__tags > span')[0]
      this.sortable = Sortable.create(el, {
        ghostClass: 'sortable-ghost',
        setData: function(dataTransfer) {
          dataTransfer.setData('Text', '')
        onEnd: evt => {
          const targetRow = this.value.splice(evt.oldIndex, 1)[0]
          this.value.splice(evt.newIndex, 0, targetRow)
</script>
<style lang="scss" scoped>
.drag-select {
  ::v-deep {
    .sortable-ghost {
      opacity: .8;
      color: #fff !important;
      background: #42b983 !important;
    .el-tag {
      cursor: pointer;
</style>
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
<template>
  <div class="components-container">
    <el-drag-select v-model="value" style="width:500px;" multiple placeholder="请选择">
      <el-option v-for="item in options" :key="item.value" :label="item.label" :value="item.value" />
    </el-drag-select>
    <div style="margin-top:30px;">
      <el-tag v-for="item of value" :key="item" style="margin-right:15px;">
        {{ item }}
      </el-tag>
    </div>
  </div>
</template>
<script>
import ElDragSelect from '@/components/DragSelect' // base on element-ui
export default {
  components: { ElDragSelect },
  data() {
    return {
      value: ['Apple', 'Banana', 'Orange'],
      options: [{
        value: 'Apple',
        label: 'Apple'
        value: 'Banana',
        label: 'Banana'
        value: 'Orange',
        label: 'Orange'
        value: 'Pear',
        label: 'Pear'
        value: 'Strawberry',
        label: 'Strawberry'
</script>
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
文章来源: codeboy.blog.csdn.net,作者:愚公搬代码,版权归原作者所有,如需转载,请联系作者。
原文链接:codeboy.blog.csdn.net/article/details/107408375
