(精华)2020年7月8日 Node.js express(跨域处理)
愚公搬代码 发表于 2021/10/18 22:57:48 2021/10/18
【摘要】 var mysql = require('mysql'); const express = require('express'); var bodyParser = require('body-pars...
var bodyParser = require('body-parser');   //body解析
var cors = require('cors');
const app = express();
app.use(bodyParser.json())
.use(bodyParser.urlencoded({ extended: true }))
.use(function (req, res, next) {
     //跨域处理
     res.setHeader('Access-Control-Allow-Origin', '*');  //允许任何源
     res.setHeader('Access-Control-Allow-Methods', 'GET, POST, OPTIONS, PUT, PATCH, DELETE');
     res.setHeader('Access-Control-Allow-Headers', '*');   //允许任何类型
     // res.writeHead(200, {"Content-Type": "text/plain;charset=utf-8"});
    next();  //next 方法就是一个递归调用
app.use(cors());
//jsonp
app.get('/jsonp/callback=:cbk',function(req,res){
    console.log('ooopp heelo');
    var bk = req.params.cbk;
    console.log(bk);
    var vt = {name:'Tim',age:28,id:bk};
    res.send(bk+'('+JSON.stringify(vt)+')');
app.get('/api/info',(req,res) => {
    var data={
                "code": "200",
                "msg": "success",
                "result": [{
                    "id":1,
                    "name": "laney",
                    "content": "test01"
                    "id":2,
                    "name": "ben",
                    "content": "test02"
                    "id":3,
                    "name": "lili",
                    "content": "test03"
    res.json({
        err_code:0,
        data:data.result
app.post('/api/msg',(req,res) => {
    var data={
                "code": "200",
                "msg": "success",
                 "result": {
                    "focus":true,
                    "data":[{
                                    "id":1,
                                    "name": "laney01",
                                    "content": "test01"
                                    "id":2,
                                    "name": "ben",
                                    "content": "test02"
                                    "id":3,
                                    "name": "lili",
                                    "content": "test03"
    res.json({
        err_code:0,
        result:data.result
app.post('/api/hello',(req,res) => {
    var data={
                "code": "200",
                "msg": "success",
                "result": [{
                    "id":10,
                    "name": "laney",
                    "content": "hello world"
     res.json({
        err_code:0,
        result:data.result
app.listen(3000, () => {
    console.log('Server started on port 3000');
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
文章来源: codeboy.blog.csdn.net,作者:愚公搬代码,版权归原作者所有,如需转载,请联系作者。
原文链接:codeboy.blog.csdn.net/article/details/107215602
评论(0
