(精华)2020年7月20日 ASP.NET Core serilog日志框架的使用
愚公搬代码 发表于 2021/10/19 01:17:35 2021/10/19
【摘要】 首先安装如下两个包 Install-Package Serilog.AspNetCore Install-Package Serilog.Sinks.Elasticsearch 封装使用 ...
首先安装如下两个包
封装使用
/// <summary>
/// 配置日志
/// </summary>
/// <param name="hostBuilder">建造者</param>
/// <returns></returns>
public static IHostBuilder UseLog(this IHostBuilder hostBuilder)
    var rootPath = AppDomain.CurrentDomain.BaseDirectory;
    var path = Path.Combine(rootPath, "logs", "log.txt");
    return hostBuilder.UseSerilog((hostingContext, serilogConfig) =>
        var envConfig = hostingContext.Configuration;
        LogConfig logConfig = new LogConfig();
        envConfig.GetSection("log").Bind(logConfig);
        logConfig.overrides.ForEach(aOverride =>
            serilogConfig.MinimumLevel.Override(aOverride.source, aOverride.minlevel.ToEnum<LogEventLevel>());
        serilogConfig.MinimumLevel.Is(logConfig.minlevel.ToEnum<LogEventLevel>());
        if (logConfig.console.enabled)
            serilogConfig.WriteTo.Console();
        if (logConfig.debug.enabled)
            serilogConfig.WriteTo.Debug();
        if (logConfig.file.enabled)
            string template = "{Timestamp:yyyy-MM-dd HH:mm:ss.fff zzz} [{Level:u3} {SourceContext:l}] {Message:lj}{NewLine}{Exception}";
            serilogConfig.WriteTo.File(
                path,
                outputTemplate: template,
                rollingInterval: RollingInterval.Day,
                shared: true,
                fileSizeLimitBytes: 10 * 1024 * 1024,
                rollOnFileSizeLimit: true
        if (logConfig.elasticsearch.enabled)
            var uris = logConfig.elasticsearch.nodes.Select(x => new Uri(x)).ToList();
            serilogConfig.WriteTo.Elasticsearch(new ElasticsearchSinkOptions(uris)
                IndexFormat = logConfig.elasticsearch.indexformat,
                AutoRegisterTemplate = true,
                AutoRegisterTemplateVersion = AutoRegisterTemplateVersion.ESv7
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
public class Program
    public static void Main(string[] args)
        CreateHostBuilder(args).Build().Run();
    public static IHostBuilder CreateHostBuilder(string[] args) =>
        Host.CreateDefaultBuilder(args)
            .UseIdHelper()//分布式自增Id组件
            .UseLog()//使用serilog日志框架
            .ConfigureWebHostDefaults(webBuilder =>
                webBuilder.UseStartup<Startup>();
using System;
using System.Collections.Generic;
using System.Linq;
using System.Threading.Tasks;
using Microsoft.AspNetCore.Mvc;
using Microsoft.Extensions.Logging;
namespace CORE.WEBERP.Controllers
    [ApiController]
    [Route("[controller]")]
    public class WeatherForecastController : ControllerBase
        private static readonly string[] Summaries = new[]
            "Freezing", "Bracing", "Chilly", "Cool", "Mild", "Warm", "Balmy", "Hot", "Sweltering", "Scorching"
        private readonly ILogger<WeatherForecastController> _logger;
        public WeatherForecastController(ILogger<WeatherForecastController> logger)
            _logger = logger;
        [HttpGet]
        public IEnumerable<WeatherForecast> Get()
            _logger.LogInformation("开始");
            int a = 0;
            int b = 2;
            try
                _logger.LogDebug("计算两者相除");
                Console.WriteLine(b / a);
            catch (Exception ex)
                _logger.LogError(ex, "计算出现意外的错误");
            _logger.LogInformation("结束");
            var rng = new Random();
            return Enumerable.Range(1, 5).Select(index => new WeatherForecast
                Date = DateTime.Now.AddDays(index),
                TemperatureC = rng.Next(-20, 55),
                Summary = Summaries[rng.Next(Summaries.Length)]
            .ToArray();
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
备注:其他函数请移到类库中去查看,本人博客里都有。
文章来源: codeboy.blog.csdn.net,作者:愚公搬代码,版权归原作者所有,如需转载,请联系作者。
原文链接:codeboy.blog.csdn.net/article/details/107461937
