(精华)2020年7月22日 C#基础知识点 Flags特性
愚公搬代码 发表于 2021/10/19 01:53:47 2021/10/19
【摘要】 public enum Equipment { 刀, 枪, 箭, 弓 } public sealed class Player { internal Equipm...
    刀,
    枪,
    箭,
    弓
    internal Equipment equipmentState;//用于描述角色可以使用哪些武器
   //......其它成员
namespace UsageOfFlagsAttribute
    [Flags]
        NONE = 0x0000,
        刀 = 0x0001,
        枪 = 0x0002,
        箭 = 0x0004,
        弓 = 0x0008
    class Program
        static void Main(string[] args)
            Player player = new Player();
            player.equipmentState = Equipment.刀 | Equipment.弓;  //可以表示成多种状态的集合
  • 26
  • 27
用Flags标记后也就可以按位计算了,一般枚举有3种按位计算。
按位或(“|”):将指定的符号加入到枚举实例中
按位与(”&“):判断枚举实例中是否有指定的符号
异或(”^“):删除枚举实例中指定的符号
class Program
            //按位或
            player.equipmentState = Equipment.刀;
            player.equipmentState = player.equipmentState | Equipment.弓;
            Console.WriteLine(player.equipmentState.ToString());//打印结果:刀,弓
            //按位与
            player.equipmentState = player.equipmentState & Equipment.刀;
            Console.WriteLine(player.equipmentState.ToString());  //打印结果 : 刀
            //异或
            player.equipmentState = player.equipmentState ^ Equipment.弓;
            Console.ReadKey();
但是每次都要写 player.equipmentState = player.equipmentState ^ Equipment.弓; 这么赋值代码的可读性不好,而且容易浪费时间。因此可以扩展方法来封装这些操作。
public static class EnumExtendMethods
        /// <summary>
        /// 判断位标致的枚举实例中是否有指定符号
        /// </summary>
        /// <param name="eqipment">实例</param>
        /// <param name="checkState">指定的符号</param>
        /// <returns></returns>
        public static bool Contains(this Equipment equipment,Equipment checkState)
            if (checkState == 0)
                throw new ArgumentOutOfRangeException("checkState", "不能为NONE");
            return (equipment & checkState) == checkState;
        /// <summary>
        /// 将指定的符号从枚举实例中移除
        /// </summary>
        /// <param name="equipment"></param>
        /// <param name="removeState">指定要移除的符号</param>
        public static Equipment Remove(this Equipment equipment, Equipment removeState)
            return equipment ^ removeState;
        /// <summary>
        /// 向枚举实例中加入指定的符号
        /// </summary>
        /// <param name="addState"></param>
        public static Equipment Append(this Equipment equipment, Equipment addState)
            return equipment | addState;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
现在可以这样调用了
class Program
            //按位或
            player.equipmentState = player.equipmentState.Append(Equipment.弓);
            //按位与
            if (player.equipmentState.Contains(Equipment.刀))
                Console.WriteLine(player.equipmentState.ToString());  //打印结果 : 刀,弓
            //异或
            player.equipmentState = player.equipmentState.Remove(Equipment.弓);
            Console.ReadKey();
  • 26
文章来源: codeboy.blog.csdn.net,作者:愚公搬代码,版权归原作者所有,如需转载,请联系作者。
原文链接:codeboy.blog.csdn.net/article/details/107511881
