(精华)2020年7月18日 vue clipboard复制剪切
愚公搬代码 发表于 2021/10/19 01:51:43 2021/10/19
【摘要】 // Inspired by https://github.com/Inndy/vue-clipboard2 const Clipboard = require('clipboard') if (!Cli...
if (!Clipboard) {
  throw new Error('you should npm install `clipboard` --save at first ')
export default {
  bind(el, binding) {
    if (binding.arg === 'success') {
      el._v_clipboard_success = binding.value
    } else if (binding.arg === 'error') {
      el._v_clipboard_error = binding.value
      const clipboard = new Clipboard(el, {
        text() { return binding.value },
        action() { return binding.arg === 'cut' ? 'cut' : 'copy' }
      clipboard.on('success', e => {
        const callback = el._v_clipboard_success
        callback && callback(e) // eslint-disable-line
      clipboard.on('error', e => {
        const callback = el._v_clipboard_error
      el._v_clipboard = clipboard
  update(el, binding) {
      el._v_clipboard.text = function() { return binding.value }
      el._v_clipboard.action = function() { return binding.arg === 'cut' ? 'cut' : 'copy' }
  unbind(el, binding) {
      delete el._v_clipboard_success
      delete el._v_clipboard_error
      el._v_clipboard.destroy()
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
```javascript
import Clipboard from './clipboard'
const install = function(Vue) {
  Vue.directive('Clipboard', Clipboard)
if (window.Vue) {
  window.clipboard = Clipboard
  Vue.use(install); // eslint-disable-line
Clipboard.install = install
export default Clipboard
<template>
  <div class="app-container">
    <el-tabs v-model="activeName">
      <el-tab-pane label="use clipboard  directly" name="directly">
        <el-input v-model="inputData" placeholder="Please input" style="width:400px;max-width:100%;" />
        <el-button type="primary" icon="el-icon-document" @click="handleCopy(inputData,$event)">
          copy
        </el-button>
      </el-tab-pane>
      <el-tab-pane label="use clipboard by v-directive" name="v-directive">
        <el-button v-clipboard:copy="inputData" v-clipboard:success="clipboardSuccess" type="primary" icon="el-icon-document">
          copy
        </el-button>
      </el-tab-pane>
    </el-tabs>
  </div>
</template>
<script>
import clip from '@/utils/clipboard' // use clipboard directly
import clipboard from '@/directive/clipboard/index.js' // use clipboard by v-directive
export default {
  directives: {
    clipboard
  data() {
    return {
      activeName: 'directly',
      inputData: ''
  methods: {
    handleCopy(text, event) {
      clip(text, event)
    clipboardSuccess() {
      this.$message({
        message: 'Copy successfully',
        type: 'success',
        duration: 1500
</script>
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
文章来源: codeboy.blog.csdn.net,作者:愚公搬代码,版权归原作者所有,如需转载,请联系作者。
原文链接:codeboy.blog.csdn.net/article/details/107377586
