(精华)2020年8月19日 C#类库 Excel帮助类
愚公搬代码 发表于 2021/10/18 23:11:21 2021/10/18
【摘要】 public class ExcelHelper { /// <summary> /// 将DataTable数据导入到excel中 ...
        /// <summary>
        /// </summary>
        /// <param name="data">要导入的数据</param>
        /// <param name="fileName">写入的目标Excel的完整名称</param>
        /// <param name="isColumnWritten">DataTable的列名是否要导入</param>
        /// <param name="sheetName">要导入的excel的sheet的名称</param>
        /// <returns>导入数据行数(包含列名那一行)</returns>
        public static int DataTableToExcel(DataTable data, string fileName, string sheetName, bool isColumnWritten)
            int i = 0;
            int j = 0;
            int count = 0;
            ISheet sheet = null;
            IWorkbook workbook = null;
            if (fileName.IndexOf(".xlsx") > 0) // 2007版本
                workbook = new XSSFWorkbook();
            else if (fileName.IndexOf(".xls") > 0) // 2003版本
                workbook = new HSSFWorkbook();
            try
                using (FileStream fs = new FileStream(fileName, FileMode.OpenOrCreate, FileAccess.ReadWrite))
                    if (workbook != null)
                        sheet = workbook.CreateSheet(sheetName);
                    else
                        return -1;
                    if (isColumnWritten == true) //写入DataTable的列名
                        IRow row = sheet.CreateRow(0);
                        for (j = 0; j < data.Columns.Count; ++j)
                            row.CreateCell(j).SetCellValue(data.Columns[j].ColumnName);
                        count = 1;
                    else
                        count = 0;
                    for (i = 0; i < data.Rows.Count; ++i)
                        IRow row = sheet.CreateRow(count);
                            row.CreateCell(j).SetCellValue(data.Rows[i][j].ToString());
                        ++count;
                    workbook.Write(fs); //写入到excel
                    return count;
            catch (Exception ex)
                Console.WriteLine("Exception: " + ex.Message);
                return -1;
        /// <summary>
        /// 将excel中的数据导入到DataTable中
        /// </summary>
        /// <param name="fileName">读取的Excel的完整名称</param>
        /// <param name="sheetName">excel工作薄sheet的名称</param>
        /// <param name="isFirstRowColumn">第一行是否是DataTable的列名</param>
        /// <returns>返回的DataTable</returns>
        public static DataTable ExcelToDataTable(string fileName, string sheetName, bool isFirstRowColumn)
            DataTable data = new DataTable();
            int startRow = 0;
            try
                using (FileStream fs = new FileStream(fileName, FileMode.Open, FileAccess.Read))
                        workbook = new XSSFWorkbook(fs);
                        workbook = new HSSFWorkbook(fs);
                    if (sheetName != null)
                        sheet = workbook.GetSheet(sheetName);
                        if (sheet == null) //如果没有找到指定的sheetName对应的sheet,则尝试获取第一个sheet
                            sheet = workbook.GetSheetAt(0);
                    else
                    if (sheet != null)
                        IRow firstRow = sheet.GetRow(0);
                        int cellCount = firstRow.LastCellNum; //一行最后一个cell的编号 即总的列数
                        if (isFirstRowColumn)
                            for (int i = firstRow.FirstCellNum; i < cellCount; ++i)
                                ICell cell = firstRow.GetCell(i);
                                if (cell != null)
                                    string cellValue = cell.StringCellValue;
                                    if (cellValue != null)
                                        DataColumn column = new DataColumn(cellValue);
                                        data.Columns.Add(column);
                            startRow = sheet.FirstRowNum + 1;
                        else
                            startRow = sheet.FirstRowNum;
                        //最后一列的标号
                        int rowCount = sheet.LastRowNum;
                        for (int i = startRow; i <= rowCount; ++i)
                            IRow row = sheet.GetRow(i);
                            if (row == null) continue; //没有数据的行默认是null
                            DataRow dataRow = data.NewRow();
                            for (int j = row.FirstCellNum; j < cellCount; ++j)
                                if (row.GetCell(j) != null) //同理,没有数据的单元格都默认是null
                                    dataRow[j] = row.GetCell(j).ToString();
                            data.Rows.Add(dataRow);
                    return data;
                return null;
        /// <summary>
        /// 把Excel的stream导入到表
        /// </summary>
        /// <param name="fs"></param>
        /// <param name="fileName"></param>
        /// <param name="sheetName"></param>
        /// <param name="isFirstRowColumn"></param>
        /// <returns></returns>
        public static DataTable ExcelToDataTable(Stream fs, string fileName, string sheetName, bool isFirstRowColumn)
            int startRow = 0;
            try
                else
                if (sheet != null)
                            if (cell != null)
                    else
                    //最后一列的标号
                return data;
                return null;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
  • 224
  • 225
  • 226
  • 227
  • 228
  • 229
  • 230
  • 231
  • 232
  • 233
  • 234
  • 235
  • 236
  • 237
  • 238
  • 239
  • 240
  • 241
  • 242
  • 243
  • 244
  • 245
  • 246
  • 247
文章来源: codeboy.blog.csdn.net,作者:愚公搬代码,版权归原作者所有,如需转载,请联系作者。
原文链接:codeboy.blog.csdn.net/article/details/108099473
