(精华)2020年8月27日 数据结构与算法解析(线段树)
愚公搬代码 发表于 2021/10/19 01:01:49 2021/10/19
【摘要】 /// <summary> /// 线段树:线段树是二叉树的一种,常常被用于求区间和与区间最大值等操作 /// </summary> public class SegmentTre...
/// <summary>
/// </summary>
public class SegmentTree
    List<int> _orignalData = new List<int>();
    List<int?> _tree = new List<int?>();
    public SegmentTree()
        for (int i = 0; i < 1000; i++)
            _tree.Add(null);
    public void Print()
        for (int i = 0; i < _tree.Count; i++)
            if (_tree[i] == null)
                continue;
            Console.WriteLine($"第{i}:{_tree[i]}");
    public void Fill(List<int> data)
        _orignalData = data;
        Fill(0, 0, _orignalData.Count - 1);
    private void Fill(int node, int start, int end)
        if (start == end)
            _tree[node] = _orignalData[start];
        else
            int mid = (start + end) / 2;
            int leftNode = 2 * node + 1;
            int rightNode = 2 * node + 2;
            Fill(leftNode, start, mid);
            Fill(rightNode, mid + 1, end);
            _tree[node] = _tree[leftNode] + _tree[rightNode];
    public void Set(int index, int val)
        SetValue(0, 0, _orignalData.Count - 1, index, val);
    private void SetValue(int node, int start, int end, int index, int val)
        if (start == end)
            _orignalData[index] = val;
            _tree[node] = val;
        else
            if (index >= start && index <= mid)
                SetValue(leftNode, start, mid, index, val);
            else
                SetValue(rightNode, mid + 1, end, index, val);
    public int? GetSum(int left, int right)
        return Query(0, 0, _orignalData.Count - 1, left, right);
    private int? Query(int node, int start, int end, int left, int right)
        if (right < start || left > end)
            return 0;
        else if (left <= start && end <= right)
            return _tree[node];
        else if (start == end)
            return _tree[node];
        else
            int? sumLeft = Query(leftNode, start, mid, left, right);
            int? sumRight = Query(rightNode, mid + 1, end, left, right);
            return sumLeft + sumRight;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
原理
(注:由于线段树的每个节点代表一个区间,以下叙述中不区分节点和区间,只是根据语境需要,选择合适的词)
线段树本质上是维护下标为1,2,…,n的n个按顺序排列的数的信息,所以,其实是“点树”,是维护n的点的信息,至于每个点的数据的含义可以有很多,
在对线段操作的线段树中,每个点代表一条线段,在用线段树维护数列信息的时候,每个点代表一个数,但本质上都是每个点代表一个数。以下,在讨论线段树的时候,区间[L,R]指的是下标从L到R的这(R-L+1)个数,而不是指一条连续的线段。只是有时候这些数代表实际上一条线段的统计结果而已。
线段树是将每个区间[L,R]分解成[L,M]和[M+1,R] (其中M=(L+R)/2 这里的除法是整数除法,即对结果下取整)直到 L==R 为止。
开始时是区间[1,n] ,通过递归来逐步分解,假设根的高度为1的话,树的最大高度为(n>1)。
线段树对于每个n的分解是唯一的,所以n相同的线段树结构相同,这也是实现可持久化线段树的基础。
下图展示了区间[1,13]的分解过程:
上图中,每个区间都是一个节点,每个节点存自己对应的区间的统计信息。
(1)线段树的点修改:
假设要修改[5]的值,可以发现,每层只有一个节点包含[5],所以修改了[5]之后,只需要每层更新一个节点就可以线段树每个节点的信息都是正确的,所以修改次数的最大值为层数。
复杂度O(log2(n))
(2)线段树的区间查询:
线段树能快速进行区间查询的基础是下面的定理:
定理:n>=3时,一个[1,n]的线段树可以将[1,n]的任意子区间[L,R]分解为不超过个子区间。
这样,在查询[L,R]的统计值的时候,只需要访问不超过个节点,就可以获得[L,R]的统计信息,实现了O(log2(n))的区间查询。
下面给出证明:
(2.1)先给出一个粗略的证明(结合下图):
先考虑树的最下层,将所有在区间[L,R]内的点选中,然后,若相邻的点的直接父节点是同一个,那么就用这个父节点代替这两个节点(父节点在上一层)。这样操作之后,本层最多剩下两个节点。若最左侧被选中的节点是它父节点的右子树,那么这个节点会被剩下。若最右侧被选中的节点是它的父节点的左子树,那么这个节点会被剩下。中间的所有节点都被父节点取代。
对最下层处理完之后,考虑它的上一层,继续进行同样的处理,可以发现,每一层最多留下2个节点,其余的节点升往上一层,这样可以说明分割成的区间(节点)个数是大概是树高的两倍左右。
下图为n=13的线段树,区间[2,12],按照上面的叙述进行操作的过程图:
由图可以看出:在n=13的线段树中,[2,12]=[2] + [3,4] + [5,7] + [8,10] + [11,12] 。
(2.2)然后给出正式一点的证明:
用数学归纳法,证明上面的定理:
首先,n=3,4,5时,用穷举法不难证明定理成立。
假设对于n= 3,4,5,…,k-1上式都成立,下面来证明对于n=k ( k>=6 )成立:
分为4种情况来证明:
情况一:[L,R]包含根节点(L=1且R=n),此时,[L,R]被分解为了一个节点,定理成立。
情况二:[L,R]包含根节点的左子节点,此时[L,R]一定不包含根的右子节点(因为如果包含,就可以合并左右子节点,
用根节点替代,此时就是情况一)。这时,以右子节点为根的这个树的元素个数为。
[L,R]分成的子区间由两部分组成:
一:根的左子结点,区间数为1
二:以根的右子节点为根的树中,进行区间查询,这个可以递归使用本定理。
由归纳假设可得,[L,R]一共被分成了个区间。
情况三:跟情况二对称,不一样的是,以根的左子节点为根的树的元素个数为。
[L,R]一共被分成了个区间。
从公式可以看出,情况二的区间数小于等于情况三的区间数,于是只需要证明情况三的区间数符合条件就行了。
于是,情况二和情况三定理成立。
情况四:[L,R]不包括根节点以及根节点的左右子节点。
于是,剩下的层,每层最多两个节点(参考粗略证明中的内容)。
于是[L,R]最多被分解成了个区间,定理成立。
上面只证明了是上界,但是,其实它是最小上界。
n=3,4时,有很多组区间的分解可以达到最小上界。
当n>4时,当且仅当n=2^t (t>=3),L=2,R=2^t -1 时,区间[L,R]的分解可以达到最小上界。
就不证明了,有兴趣可以自己去证明。
下图是n=16 , L=2 , R=15 时的操作图,此图展示了达到最小上界的树的结构。
(3)线段树的区间修改:
线段树的区间修改也是将区间分成子区间,但是要加一个标记,称作懒惰标记。
标记的含义:
本节点的统计信息已经根据标记更新过了,但是本节点的子节点仍需要进行更新。
即,如果要给一个区间的所有值都加上1,那么,实际上并没有给这个区间的所有值都加上1,而是打个标记,记下来,这个节点所包含的区间需要加1.打上标记后,要根据标记更新本节点的统计信息,比如,如果本节点维护的是区间和,而本节点包含5个数,那么,打上+1的标记之后,要给本节点维护的和+5。这是向下延迟修改,但是向上显示的信息是修改以后的信息,所以查询的时候可以得到正确的结果。有的标记之间会相互影响,所以比较简单的做法是,每递归到一个区间,首先下推标记(若本节点有标记,就下推标记),然后再打上新的标记,这样仍然每个区间操作的复杂度是O(log2(n))。
标记有相对标记和绝对标记之分:
相对标记是将区间的所有数+a之类的操作,标记之间可以共存,跟打标记的顺序无关(跟顺序无关才是重点)。
所以,可以在区间修改的时候不下推标记,留到查询的时候再下推。
注意:如果区间修改时不下推标记,那么PushUp函数中,必须考虑本节点的标记。
而如果所有操作都下推标记,那么PushUp函数可以不考虑本节点的标记,因为本节点的标记一定已经被下推了(也就是对本节点无效了)
绝对标记是将区间的所有数变成a之类的操作,打标记的顺序直接影响结果,
所以这种标记在区间修改的时候必须下推旧标记,不然会出错。
注意,有多个标记的时候,标记下推的顺序也很重要,错误的下推顺序可能会导致错误。
之所以要区分两种标记,是因为非递归线段树只能维护相对标记。
因为非递归线段树是自底向上直接修改分成的每个子区间,所以根本做不到在区间修改的时候下推标记。
非递归线段树一般不下推标记,而是自下而上求答案的过程中,根据标记更新答案。
(4)线段树的存储结构:
线段树是用数组来模拟树形结构,对于每一个节点R ,左子节点为 2R (一般写作R<<1)右子节点为 2R+1(一般写作R<<1|1)
然后以1为根节点,所以,整体的统计信息是存在节点1中的。
这么表示的原因看下图就很明白了,左子树的节点标号都是根节点的两倍,右子树的节点标号都是左子树+1:
线段树需要的数组元素个数是:,一般都开4倍空间,比如: int A[n<<2];
文章来源: codeboy.blog.csdn.net,作者:愚公搬代码,版权归原作者所有,如需转载,请联系作者。
原文链接:codeboy.blog.csdn.net/article/details/108189020
