(精华)2020年9月20日 ASP.NET Core WebAPI数据协议OData的使用
愚公搬代码 发表于 2021/10/18 23:45:51 2021/10/18
【摘要】 基本使用 首先注册Odata协议 引入 Microsoft.AspNetCore.OData 1 public static class ModelBuilder { pub...
基本使用
首先注册Odata协议
引入
        public static IEdmModel GetEdmModel()
            var odataBuilder = new ODataConventionModelBuilder();
            odataBuilder.EntitySet<Person>("Person");
            return odataBuilder.GetEdmModel();
public class Person
        public int Id { get; set; }
        public string Name { get; set; }
        public int Age { get; set; }
public class Startup
        public Startup(IConfiguration configuration)
            Configuration = configuration;
        public IConfiguration Configuration { get; }
        // This method gets called by the runtime. Use this method to add services to the container.
        public void ConfigureServices(IServiceCollection services)
            services.AddControllers();
            services.AddOData();
        // This method gets called by the runtime. Use this method to configure the HTTP request pipeline.
        public void Configure(IApplicationBuilder app, IWebHostEnvironment env)
            if (env.IsDevelopment())
                app.UseDeveloperExceptionPage();
            app.UseRouting();
            app.UseAuthorization();
            app.UseEndpoints(endpoints =>
                endpoints.MapControllers();
                endpoints.Select().Filter().OrderBy().Count().MaxTop(10);
                endpoints.MapODataRoute("odata", "odata",ModelBuilder.GetEdmModel());
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
使用
[Route("api/[controller]")]
    [ApiController]
    public class PersonController : ODataController
        public static IList<Person> Persons = new List<Person>
            new Person {Id = 1, Name = "张三", Age = 18},
            new Person {Id = 2, Name = "李四", Age = 19},
            new Person {Id = 3, Name = "王五", Age = 20},
            new Person {Id = 4, Name = "赵六", Age = 21},
        [HttpGet, EnableQuery]
        public ActionResult Get()
            return Ok(Persons);
        public IActionResult Get([FromODataUri]int key)
            return Ok(Persons.FirstOrDefault(b => b.Id == key));
        [HttpPost]
        public IActionResult Post(Person person)
            Persons.Add(person);
            return Created(person);
        [HttpPatch]
        public IActionResult Patch([FromODataUri] int key, Delta<Person> person)
            var updatePerson = Persons.FirstOrDefault(p => p.Id == key);
            if (updatePerson == null) return NotFound();
            person.Patch(updatePerson);
            return Updated(updatePerson);
        [HttpDelete]
        public IActionResult Delete([FromODataUri] int key)
            var deletePerson = Persons.FirstOrDefault(p => p.Id == key);
            if (deletePerson == null) return NotFound();
            Persons.Remove(deletePerson);
            return StatusCode(204);
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  1. 运行程序后访问https://localhost:5001/odata/$metadata地址,可以看到所有可用模型的元数据。
//获取所有
GET http://localhost:63372/odata/Person
//获取id查询
GET http://localhost:63372/odata/Person(1)
//select
GET http://localhost:63372/odata/Person/?$select=Name,age
//select混合使用
GET http://localhost:63372/odata/Person/?$select=Name&$count=true&$orderby=age desc&$top=2&$skip=1
//过滤,按属性值
GET http://localhost:63372/odata/Person/?$filter=name eq '李四'
//过滤,按表达式-还可以使用各种函数startswith(name,'李')
GET http://localhost:63372/odata/Person/?$filter=Id add 2 eq 4
OData客户端的使用
首先安装扩展
使用
public static void Run()
    const string serviceRoot = "http://localhost:5000/odata/";
    var context = new Container(new Uri(serviceRoot));
    var persons = context.Person.Execute();
    foreach (var person in persons)
        Console.WriteLine($"{person.Id} {person.Name} {person.Age}");
    Console.Read();
    var serviceCollection = new ServiceCollection();
    serviceCollection.AddODataClient();
    var serviceProvider = serviceCollection.BuildServiceProvider();
    var oDataClientFactory = serviceProvider.GetService<IODataClientFactory>();
    var client = oDataClientFactory.CreateClient<Container>(new Uri("http://localhost:5000/odata/"));
    var persons = client.Person.Execute();
    Console.Read();
    var client = new Container(new Uri(serviceRoot));
    // var query = client.Person.Where(p => p.Age >= 20).OrderByDescending(p=>p.Age);
    // Console.WriteLine($"QueryUri:{query}");
    // var result = query.ToList();
    // foreach (var person in result)
    //     Console.WriteLine($"{person.Id} {person.Name} {person.Age}");
    //     // var person = new Person{Id = 99, Name = "Rick", Age = 99};
    //     // client.AddToPerson(person);
    //     // client.SaveChanges();
    //         .AddQueryOption("$filter", "Age lt 18")
    //         .AddQueryOption("$skip", "2")
    //         .AddQueryOption("$orderby", "Age desc");
    //     foreach (var person in query)
        var query = client.Person.OrderByDescending(p=>p.Age);
        var person = new Person {Id = 1};
        client.AttachTo("Person", person);
        client.DeleteObject(person);
        var person = client.Person.ByKey(3).GetValue();
        person.Name = "Rick";
        client.UpdateObject(person);
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
文章来源: codeboy.blog.csdn.net,作者:愚公搬代码,版权归原作者所有,如需转载,请联系作者。
原文链接:codeboy.blog.csdn.net/article/details/108524572
