2021-08-08 WPF控件专题 Slider控件详解
愚公搬代码 发表于 2021/10/18 23:06:36 2021/10/18
【摘要】 1.Slider 控件介绍 滑块 Maximum Minimum TickFrequency Orientation TickPlacement Value 移动来选择一个范围的值:改其他控件的属...
1.Slider 控件介绍
滑块
Value
移动来选择一个范围的值:改其他控件的属性值 (数值型)
2.具体案例
<Grid>
    <!--滑块  Orientation 方向  TickPlacement 轨道相关的刻度的位置 TickFrequency 刻度之间的间隔 IsSnapToTickEnabled true 值 Int  false 浮点型 IsDirectionReversed true 水平向左  垂直 向下   -->
    <Slider Name="slider1" HorizontalAlignment="Left" Margin="150,10,0,0" VerticalAlignment="Top" Maximum="100" Minimum="0" Value="50" Orientation="Horizontal" TickPlacement="Both" TickFrequency="2" IsSelectionRangeEnabled="True" SelectionStart="20" SelectionEnd="50"  Width="390" Height="35" IsSnapToTickEnabled="True" SmallChange="4" LargeChange="10" IsDirectionReversed="True"/>
    <Label Content="{Binding ElementName=slider1,Path=Value,Mode=OneWay}" HorizontalAlignment="Left" Margin="582,10,0,0" VerticalAlignment="Top" Width="82"/>
    <TextBlock Background="Red"  HorizontalAlignment="Left" Margin="240,105,0,0" TextWrapping="Wrap" Text="Slider" FontSize="{Binding ElementName=slider1,Path=Value,Mode=OneWay}" VerticalAlignment="Top" Opacity="{Binding ElementName=opSlider,Path=Value,Mode=Default}" Width="300" Height="159"/>
    <Slider Name="opSlider" HorizontalAlignment="Left" Margin="150,59,0,0" Minimum="0.2" Maximum="1.0" TickFrequency="0.1"  VerticalAlignment="Top" Width="467"/>
</Grid>
文章来源: codeboy.blog.csdn.net,作者:愚公搬代码,版权归原作者所有,如需转载,请联系作者。
原文链接:codeboy.blog.csdn.net/article/details/119522713
