2021-09-04 WPF上位机通用框架平台实战-全局监控对象
愚公搬代码 发表于 2021/10/18 23:52:38 2021/10/18
【摘要】 在程序启动的时候就实时监控设备 public partial class App : Application { protected override void OnStartup(Startu...
在程序启动的时候就实时监控设备
    protected override void OnStartup(StartupEventArgs e)
        base.OnStartup(e);
        GlobalMonitor.Start();
        if (new LoginWindow().ShowDialog() == true)
            new MainWindow().ShowDialog();
        Application.Current.Shutdown();
    protected override void OnExit(ExitEventArgs e)
        GlobalMonitor.Stop();
        base.OnExit(e);
public class GlobalMonitor
    public static ObservableCollection<DeviceModel> DeviceList { get; set; } = new ObservableCollection<DeviceModel>();
    static bool isRunning = true;
    static Task mainTask = null;
    public static void Start()
        mainTask = Task.Run(async () =>
            // 获取设备信息
            //DeviceList.Add(new DeviceModel { Name = "#1 Master device info" });
            //DeviceList.Add(new DeviceModel { Name = "#2 Master device info" });
            //DeviceList.Add(new DeviceModel { Name = "#3 Master device info" });
            //DeviceList.Add(new DeviceModel { Name = "#4 Master device info" });
            DeviceService deviceService = new DeviceService();
            var list = deviceService.GetDevices();
            if (list != null)
                foreach (var item in list)
                    DeviceList.Add(item);
            //DeviceList = new ObservableCollection<DeviceModel>(list);
            while (isRunning)
                await Task.Delay(100);
                foreach (var item in DeviceList)
                    if (item.CommType == 2 && item.S7 != null)// S7通信
                        Zhaoxi.Communication.Siemens.S7Net s7Net = new Communication.Siemens.S7Net(item.S7.IP, item.S7.Port, (byte)item.S7.Rock, (byte)item.S7.Slot);
                        List<string> addrList = item.MonitorValueList.Select(v => v.Address).ToList();
                        var result = s7Net.Read<ushort>(addrList);
                        if (result.IsSuccessed)
                            for (int i = 0; i < item.MonitorValueList.Count; i++)
                                item.MonitorValueList[i].Value = result.Datas[i];
                        s7Net.Close();
    public static void Stop()
        isRunning = false;
        mainTask.ConfigureAwait(true);
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
文章来源: codeboy.blog.csdn.net,作者:愚公搬代码,版权归原作者所有,如需转载,请联系作者。
原文链接:codeboy.blog.csdn.net/article/details/120093498
