ABAP 和 Excel 进行 office integration 的一些常用场景
汪子熙 发表于 2021/10/16 22:15:31 2021/10/16
【摘要】 使用Excel调用ABAP系统的函数效果:在excel里创建一个按钮,开发一些VB script,可以连接指定的ABAP系统并执行系统里的ABAP function module。在这里例子里执行ABAP系统的函数TH_USER_LIST, 把当前系统登录的用户取回来显示在excel里。该按钮的点击响应函数实现代码:Sub CommandButton1_Click() Set R3 ...
使用Excel调用ABAP系统的函数
该按钮的点击响应函数实现代码:
    Set R3 = CreateObject("SAP.Functions")
    Set myConnction = R3.Connection
    myConnction.ApplicationServer = "ag3"
    myConnction.SystemNumber = 54
    myConnction.Client = "001"
    myConnction.user = "WANGJER"
    myConnction.Password = "your password"
    If myConnction.Logon(0, True) <> True Then
      MsgBox "Logon failed"
      Exit Sub
    End If
    Dim callFunctionModule As Object
    Set callFunctionModule = R3.Add("TH_USER_LIST")
    callFunctionModule.Call
    If callFunctionModule.Exception <> "" Then
        MsgBox callFunctionModule.Exception
    End If
    If callFunctionModule.Call = True Then
        Dim result As Object
        Set result = callFunctionModule.tables("USRLIST")
        Dim aSheet As Worksheet
        Dim sheetCol As New Collection
        sheetCol.Add ActiveWorkbook.Sheets(1)
        For Each aSheet In sheetCol
            Dim i As Integer
            i = 1
            For Each user In result.Rows
                Client = user(2)
                UserName = user(3)
                Terminal = user(5)
                IP = user(16)
                aSheet.Cells(i, 1) = Client
                aSheet.Cells(i, 2) = UserName
                aSheet.Cells(i, 3) = Terminal
                aSheet.Cells(i, 4) = IP
                i = i + 1
            Next
        Next
    Else
        MsgBox " Call Failed! error: "
    End If
'log off
    myConnction.logoff
End Sub
使用Excel消费C4C的OData service
步骤比较简单, 打开Excel的标签Data->From Other Sources->From OData Data Feed:
输入如下url: https://<your tenant>.c4c.saphybriscloud.cn/sap/byd/odata/v1/c4codata/
选择AccountCollection:
这个例子我把C4C系统里所有的account都下载并显示在Excel里:
