iOS关闭SIP 【Disabling Rootless】 & 修改文件的md5值,进行过appstore 马甲机审
iOS逆向 发表于 2021/10/16 00:36:54 2021/10/16
【摘要】 文章目录 引言 I 、Getting around Rootless II、Disabling Rootless III、修改文件的md5值,进行过appstore 马甲机...
引言
If you currently have Rootless enabled, you’ll be unable to attach to the majority of Apple’s programs.
For example, try attaching LLDB to the Finder application.
Open up a Terminal window and look for the Finder process, like so:
devzkndeMacBook-Pro:~ devzkn$ lldb -n Finder
(lldb) process attach --name "Finder"
error: attach failed: cannot attach to process due to System Integrity Protection
How can you catch a process that is about to be launched, if you don’t know the PID yet?
文章来源: kunnan.blog.csdn.net,作者:iOS逆向,版权归原作者所有,如需转载,请联系作者。
原文链接:kunnan.blog.csdn.net/article/details/78295836
