ecs被python连接
柳ioi 发表于 2021/10/09 07:40:59 2021/10/09
【摘要】 def loopMonitor(): while True: zhenxing(vpc_id) time.sleep(5)def ssh_ecs(vpc_id, ecsname, ecsname2): # 路由表id routetable_id = '3a-4a1' # 返回ecs name和私网ip ecs_list = json....
def loopMonitor():
    while True:
        zhenxing(vpc_id)
        time.sleep(5)
    # 路由表id
    # 返回ecs name和私网ip
    ecs_list = json.loads(str(ecs(ecs_client)))
    ecs_ip = {}
    for i in range(len(ecs_list['servers'])):
        for e in range(len(ecs_list['servers'][i]['addresses'][vpc_id])):
            if ecs_list['servers'][i]['addresses'][vpc_id][e]['OS-EXT-IPS:type'] == 'fixed':
                ecs_ip[ecs_list['servers'][i]['name']] = ecs_list['servers'][i]['addresses'][vpc_id][e]['addr']
    # 返回ecs name 和 id
    ecs_id = {}
        ecs_id[ecs_list['servers'][i]['name']] = ecs_list['servers'][i]['id']
    # 设置vpc新的路由规则
    routes = [{}]
    routes[0]['type'] = 'ecs'
    routes[0]['destination'] = '0.0.0.0/0'
    routes[0]['nexthop'] = ecs_id[ecsname]
    vpc(vpc_client, routetable_id, routes)
    print('vpc路由表规则到ecs1')
    # 在新主机上添加 IPtables
    # trans = paramiko.Transport((ecs_ip[ecsname], 22))
    # trans.connect(username='root', password='ecs-01-pass')
    # ssh = paramiko.SSHClient()
    # ssh._transport = trans
    # ssh.set_missing_host_key_policy(paramiko.AutoAddPolicy())
    # ssh.exec_command(
    #     'echo net.ipv4.ip_forward = 1 >> /etc/sysctl.conf && sysctl -p && iptables -t nat -A POSTROUTING -s '
    #     '192.168.1.0/24 -j SNAT --to ' +
    #     ecs_ip[ecsname])
    # trans.close()
    print('创建新iptables')
    # 在原主机 上删除iptables
    # trans = paramiko.Transport((ecs_ip[ecsname2], 22))
    # ssh.exec_command("iptables -t nat -F POSTROUTING && sed -i '$d' /etc/sysctl.conf && sysctl -p ")
    # trans.close()
    print('删除旧iptables')
def zhenxing(vpc_id):
    # 返回json格式的ecs列表
    # 返回绑定eip的ecs的名字
    ecs_eip = '没有ECS绑定EIP'
            if ecs_list['servers'][i]['addresses'][vpc_id][e]['OS-EXT-IPS:type'] == 'floating':
                ecs_eip = ecs_list['servers'][i]['name']
    # 获取eip默认绑定ecs
    global ecs_default
    # 判断eip有没有换绑
    # 无改变
    if ecs_eip == ecs_default:
        print("eip绑定无改变")
    # 换绑到ecs1
    elif ecs_eip == 'ecs-1':
        print('换绑到ecs1')
        ecs_default = ecs_eip
        ecsname = ecs_eip
        ecsname2 = 'ecs-2'
    # 换绑到ecs2
    elif ecs_eip == 'ecs-2':
        print('换绑到ecs2')
        ecsname = ecs_eip
        ecsname2 = 'ecs-1'
    # 没有ecs绑定eip
    else:
        print('没有ECS绑定EIP')
