docker部署redis
小源博客 发表于 2021/10/05 17:37:45 2021/10/05
【摘要】 一、安装docker1、把yum源更新[root@localhost ~]# yum update -y2、下载docker一些依赖包[root@localhost ~]# yum install -y yum-utils device-mapper-persistent-data lvm23、把docker官方源下载下来[root@localhost ~]# yum-config-mana...
一、安装docker
1、把yum源更新
2、下载docker一些依赖包
3、把docker官方源下载下来
[root@localhost ~]# yum-config-manager \--add-repo \https://download.docker.com/linux/centos/docker-ce.repo    ##docker官方源
yum-config-manager --add-repo https://mirrors.aliyun.com/docker-ce/linux/centos/docker-ce.repo    ##阿里源
4、安装docker
[root@localhost ~]# yum list docker-ce --showduplicates | sort -r && yum install docker-ce -y
5、重启 docker
[root@localhost ~]# systemctl restart docker
[root@localhost ~]# systemctl enable docker
Created symlink from /etc/systemd/system/multi-user.target.wants/docker.service to /usr/lib/systemd/system/docker.service.
拓展:
docker version |head -n2
docker version |head -n13 |tail -n3
#服务状态
docker status docker |head -n3
二、安装redis
1、查找reddis
[root@localhost ~]# docker search redis
2、安装reddis并修改配置文件重启 redis
[root@localhost ~]# docker pull redis       ##pull redis
Using default tag: latest
latest: Pulling from library/redis
07aded7c29c6: Pull complete
1a5d64c027a4: Pull complete
189d72810950: Pull complete
b85aac102f7d: Pull complete
fe1bca69301e: Pull complete
fd69789c2b06: Pull complete
Digest: sha256:c98f0230b5f1831f4f5dd764c4ea8ef11d3e3a1a3593278eb952373d97c82b27
Status: Downloaded newer image for redis:latest
docker.io/library/redis:latest
[root@localhost ~]# docker images     ##查看镜像列表
mkdir /usr/local/docker
REPOSITORY   TAG       IMAGE ID       CREATED      SIZE
redis        latest    5d89766432d0   6 days ago   105MB
cd /usr/local/docker
[root@localhost ~]#
[root@localhost ~]# mkdir /usr/local/docker
[root@localhost ~]# cd /usr/local/docker
[root@localhost docker]# yum -y install wget
[root@localhost docker]#wget http://download.redis.io/redis-stable/redis.conf       ##下载配置文件
[root@localhost docker]#sed -i 's/bind127.0.0.1/#bind127.0.0.1/g'  /usr/local/docker/redis.conf  &&  sed -i 's/protected-mode yes/protected-mode no/g' /usr/local/docker/redis.conf      ##修改配置文件
sed -i 's/^#requirepass.*/requirepass Huawei@123/g' redis.conf     #密码设置为Huawei@123
[root@localhost docker]#docker run -itd -p 6379:6379 --name redis-test -v /usr/local/docker/redis.conf:/etc/redis/redis.conf -v /usr/local/docker/data:/data redis redis-server /etc/redis/redis.conf      ##配置文件加入到docker里面
[root@localhost docker]# docker start redis-test   ##重启docker
[root@localhost docker]# docker exec -it redis-test bash   ##进入redis
root@326ac72d2228:/data# redis-cli -h 192.168.73.182 -p 6379  -a Huawei@123     ##远程登陆redis
192.168.73.182:6379> ping
PONG
网站利用redis进行缓存服务
修改配置文件
[root@node1 config]# ll
total 32
-rwxrwxrwx 1 root   root   8868 Oct  9 10:21 config_global_default.php
-rw-r--r-- 1 apache apache 4615 Oct  9 12:57 config_global.php
-rwxrwxrwx 1 root   root   1663 Oct  9 10:21 config_ucenter_default.php
-rw-r--r-- 1 apache apache  539 Oct  9 10:23 config_ucenter.php
-rwxrwxrwx 1 root   root      1 Oct  9 10:21 index.htm
[root@node1 config]# pwd
/var/www/html/config
[root@node1 config]# vim config_global.php
18 $_config['memory']['prefix'] = 'oh0Ztl_';
 20 $_config['memory']['redis']['server'] = '192.168.30.56';   ##redis主机ip
 21 $_config['memory']['redis']['port'] = 6379;
 22 $_config['memory']['redis']['pconnect'] = 1;
 23 $_config['memory']['redis']['timeout'] = '0';
 24 $_config['memory']['redis']['requirepass'] = '123456';    ##设置的密码
 25 $_config['memory']['redis']['serializer'] = 1;
 26 $_config['memory']['redis']['db'] = 1;
[root@node1 config]# systemctl restart httpd
[root@node1 config]# yum -y install php-devel
[root@node1 config]#  yum -y install gcc make
[root@node1 config]# wget http://pecl.php.net/get/redis-4.3.0.tgz
[root@node1 config]# mv redis-4.3.0.tgz ..
[root@node1 config]#cd ..
[root@node1 html]# pwd
/var/www/html/
[root@node1 html]# tar -zxvf redis-4.3.0.tgz
[root@node1 html]#  cd redis-4.3.0
[root@node1 html]#  phpize
[root@node1 html]# ./configure --with-php-config=/bin/php-config     ##配置phpredis环境变量
[root@node1 html]# make
[root@node1 html]#make install
[root@node1 html]#vim /etc/php.ini
extension="redis.so"
[root@node1 html]#systemctl restart php-fpm
[root@node1 html]#systemctl restart httpd
参考:https://www.php.cn/php-weizijiaocheng-392756.html
参考:https://github.com/redis/redis/blob/6.0/redis.conf
实用博客参考链接:
https://i4t.com/        ##一个大佬写的好东西
https://www.freesion.com/              ##虚拟化操作社区
https://www.kubernetes.org.cn/    #k8s中文社区
http://huangrukun.xyz/             #大黄的博客
https://www.cnblogs.com/Skybiubiu      ##博客园
https://www.sysit.cn/blog/sysit      ##运维笔记大佬
https://oldqiang.com/page/2         ##老男孩强哥
https://search.gitee.com/?skin=rec&type=repository&q=web%E6%9E%B6%E6%9E%84      ##gitt
https://www.oschina.net/project/tag/406/paas    ##开源中国
https://www.myhomeabc.com/      ##使用浏览器
https://www.php.cn/course/list/3/type/99.html       ##PHP中文网
https://www.liuyixiang.com/     ##小想的博客
https://www.server-world.info/en/note?os=CentOS_7&p=samba&f=1     ##服务器搭建
https://www.cnblogs.com/shenjianping/p/14697278.html    ##nfs测试
https://blog.star-chen.com/        ##docker博客
https://forum.huawei.cn/enterprise/zh/thread-689221.html   ##华为官方论坛
