MRS Flink使用SQL-Client对接Hive
yangxiao_mrs 发表于 2021/09/29 17:38:40 2021/09/29
【摘要】 一、准备环境1.根据产品文档安装Flink客户端;2.将sql-client-defaults.yaml放入/opt/client/Flink/flink/conf中3.将jaas.conf放入/opt/client/Flink/flink/conf中Client {com.sun.security.auth.module.Krb5LoginModule requireduseKeyTab=...
一、准备环境
1.根据产品文档安装Flink客户端;
2.sql-client-defaults.yaml放入/opt/client/Flink/flink/conf
3.jaas.conf放入/opt/client/Flink/flink/conf
Client {
useKeyTab=false
useTicketCache=true
debug=false;
4.添加sql-client.sh中添加在JVM_ARGS参数:
JVM_ARGS="-Djava.security.auth.login.config=/opt/client/Flink/flink/conf/jaas.conf $JVM_ARGS"
二、启动Flink集群
例如:yarn-session.sh -t ssl -d
三、启动SQL-Client
./sql-client.sh embedded -d ./../conf/sql-client-defaults.yaml
四、运行SQL
CREATE TABLE kafkaSourceTable (
  order_id VARCHAR,
  shop_id VARCHAR,
  member_id VARCHAR,
  trade_amt DOUBLE
) WITH (
  'connector.type' = 'kafka',
  'connector.version' = 'universal',
  'connector.topic' = 'order_sql',
  'connector.properties.bootstrap.servers' = '10.162.147.217:21005',
  'connector.properties.zookeeper.connect' = '10.162.147.217:24002',
  'connector.properties.group.id' = 'test-consumer-group',
  'connector.startup-mode' = 'latest-offset',
  'format.type' = 'json'
CREATE TABLE kafkaSinkTable(shop_id VARCHAR, member_id VARCHAR) WITH (
  'update-mode' = 'append',
INSERT INTO
  kafkaSinkTable
SELECT
  shop_id,
  member_id
FROM
  kafkaSourceTable;
SELECT
  shop_id,
  member_id
FROM
  kafkaSourceTable;
五、对接Hive
1)修改sql-client-defaults.yaml
catalogs:
    - name: myhive
     type: hive
    hive-conf-dir: /opt/clienrc5/Hive/config
    hive-version: 3.1.0
2)在/opt/clienrc5/Hive/config/hive-site.xml添加配置
<property>
<name>hive.metastore.sasl.enabled</name>
<value>true</value>
</property>
3)启动sql-client
use catalog myhive;
SET table.sql-dialect=hive;
CREATE TABLE IF NOT EXISTS hive_dialect_tbl (
`id` int ,
`name` string ,
`age` int
ROW FORMAT DELIMITED FIELDS TERMINATED BY ',';
SET table.sql-dialect=default;
CREATE TABLE datagen (
`id` int ,
`name` string ,
`age` int
) WITH (
'connector' = 'datagen',
'rows-per-second'='1'
INSERT INTO hive_dialect_tbl SELECT * FROM datagen;
select * from hive_dialect_tbl;
评论(0
