162_SpringBoot_数据访问_druid_mybatis
alexsully 发表于 2021/09/28 15:10:43 2021/09/28
【摘要】 数据访问_druid_mybatis
导入JDBC场景 (原生 HikariDataSource)
        <dependency>
            <artifactId>spring-boot-starter-data-jdbc</artifactId>
        </dependency>
导入驱动(官方不导入驱动,因为不知道业务使用什么数据库)
默认版本:<mysql.version>8.0.22</mysql.version>
手动导入:
        <dependency>
            <groupId>mysql</groupId>
            <artifactId>mysql-connector-java</artifactId>
<!--            <version>5.1.49</version>-->
        </dependency>
导入 druid
      <dependency>
            <groupId>com.alibaba</groupId>
            <artifactId>druid-spring-boot-starter</artifactId>
            <version>1.1.17</version>
        </dependency>
	@Configuration
@ConditionalOnClass({DruidDataSource.class})
@AutoConfigureBefore({DataSourceAutoConfiguration.class})
@EnableConfigurationProperties({DruidStatProperties.class, DataSourceProperties.class})
@Import({DruidSpringAopConfiguration.class, DruidStatViewServletConfiguration.class, DruidWebStatFilterConfiguration.class, DruidFilterConfiguration.class})
public class DruidDataSourceAutoConfigure {
    private static final Logger LOGGER = LoggerFactory.getLogger(DruidDataSourceAutoConfigure.class);
    public DruidDataSourceAutoConfigure() {
    @Bean(
        initMethod = "init"
    @ConditionalOnMissingBean
    public DataSource dataSource() {
        LOGGER.info("Init DruidDataSource");
        return new DruidDataSourceWrapper();
druid application.yaml 相关配置
#@EnableConfigurationProperties({DruidStatProperties.class, DataSourceProperties.class})
#spring:
#  datasource:
#    url: jdbc:mysql://localhost:3306/db_account
#    username: root
#    password: 123456
#    driver-class-name: com.mysql.jdbc.Driver
# https://github.com/alibaba/druid/tree/master/druid-spring-boot-starter
#jdbc
spring:
  datasource:
    druid:
      url: jdbc:mysql://localhost:3306?characterEncoding=UTF-8&serverTimezone=Asia/Shanghai
      username: root
      password: szc.2020
      initial-size: 50
# 监控配置
      # 配置监控页功能
      stat-view-servlet:
        enabled: true
        login-password: admin
        login-username: admin
        resetEnable: false
#web监控
      web-stat-filter:
        enabled: true
        url-pattern: /*
        exclusions: '*.js,*.gif,*.jpg,*.png,*.css,*.ico,/druid/*'
# 底层开启功能,stat(sql监控),wall(防火墙)
      filter:
        stat: #sql监控
          slow-sql-millis: 10000
          logSlowSql: true
          enabled: true
        wall: #防火墙
          enabled: true
          config:
            drop-table-allow: false
一 配置模式
mapper.Java &  mapper.xml 实现
@Mapper
public interface AccountMapper {
    public Account getAcct(Long id);
<?xml version="1.0" encoding="UTF-8" ?>
<!DOCTYPE mapper
        PUBLIC "-//mybatis.org//DTD Mapper 3.0//EN"
        "http://mybatis.org/dtd/mybatis-3-mapper.dtd">
<mapper namespace="com.alex.springboot_webadmin.mapper.AccountMapper">
    <!--    public Account getAcct(Long id); -->
    <select id="getAcct" resultType="com.alex.springboot_webadmin.bean.Account">
        select * from  account  where  id=#{id}
    </select>
</mapper>
service
@Service
public class  AccountService {
    @Autowired
    AccountMapper accountmapper;
   public  Account getAccbyid(Long id){
      return accountmapper.getAcct(id);
@Slf4j
@Controller
public class IndexController {
    @Autowired
    AccountService accountService;
    @ResponseBody
    @GetMapping("/acc")
    public Account getById(@RequestParam("id") Long id){
        return accountService.getAccbyid(id);
二 注解模式 & 混合模式
mapper注解&配置混合模式  且没有注释 mapper,利用mapperscan自动注入
public interface CityMapper {
    @Select("select * from city where id=#{id}")
    City getById(Long id);
    void saveCity(City city);
<!DOCTYPE mapper
<mapper namespace="com.alex.springboot_webadmin.mapper.CityMapper">
<insert id="insert" useGeneratedKeys="true" keyProperty="id">
    insert into city(`name`,`state`,`country`) values(#{name},#{state},#{country})
</insert>
</mapper>
//@ServletComponentScan(basePackages = "com.alex")
@MapperScan(basePackages = "com.alex.springboot_webadmin.mapper")
@SpringBootApplication
public class SpringbootWebadminApplication {
        SpringApplication.run(SpringbootWebadminApplication.class, args);
service &  controller
@Service
public class CityService {
    @Autowired
    CityMapper cityMapper;
    public City getcityByid(Long id){
        return cityMapper.getById(id);
    public void saveCity(City city){
        cityMapper.saveCity(city);
    @Autowired
    CityService cityService;
    @ResponseBody
    @GetMapping("/getcity")
    public City getcity( @RequestParam("id") Long id  ){
        return cityService.getcityByid(id);
    @GetMapping("/savecity")
    public void saveCity2 (@RequestParam("city") City city){
        cityService.saveCity(city);
