2021年大数据Flink(十四):流批一体API Connectors JDBC
Lansonli 发表于 2021/09/28 00:40:38 2021/09/28
【摘要】 目录 ​​​​​​​Connectors JDBC 代码演示 Connectors JDBC https://ci.apache.org/projects/flink/flink-docs-release-1.12/dev/connectors/jdbc.html   代码演示 package cn.itc...
目录
​​​​​​​Connectors
JDBC
代码演示
Connectors
JDBC
代码演示
  1. package cn.itcast.connectors;
  2. import lombok.AllArgsConstructor;
  3. import lombok.Data;
  4. import lombok.NoArgsConstructor;
  5. import org.apache.flink.connector.jdbc.JdbcConnectionOptions;
  6. import org.apache.flink.connector.jdbc.JdbcSink;
  7. import org.apache.flink.streaming.api.environment.StreamExecutionEnvironment;
  8. /**
  9.  * Author itcast
  10.  * Desc
  11.  */
  12. public class ConnectorsDemo_JDBC {
  13.     public static void main(String[] args) throws Exception {
  14.         //1.env
  15.         StreamExecutionEnvironment env = StreamExecutionEnvironment.getExecutionEnvironment();
  16.         //2.Source
  17.         env.fromElements(new Student(null, "tonyma", 18))
  18.                 //3.Transformation
  19.                 //4.Sink
  20.                 .addSink(JdbcSink.sink(
  21.                         "INSERT INTO `t_student` (`id`, `name`, `age`) VALUES (null, ?, ?)",
  22.                         (ps, s) -> {
  23.                             ps.setString(1, s.getName());
  24.                             ps.setInt(2, s.getAge());
  25.                         },
  26.                         new JdbcConnectionOptions.JdbcConnectionOptionsBuilder()
  27.                                 .withUrl("jdbc:mysql://localhost:3306/bigdata")
  28.                                 .withUsername("root")
  29.                                 .withPassword("root")
  30.                                 .withDriverName("com.mysql.jdbc.Driver")
  31.                                 .build()));
  32.         //5.execute
  33.         env.execute();
  34.     }
  35.     @Data
  36.     @NoArgsConstructor
  37.     @AllArgsConstructor
  38.     public static class Student {
  39.         private Integer id;
  40.         private String name;
  41.         private Integer age;
  42.     }
  43. }
文章来源: lansonli.blog.csdn.net,作者:Lansonli,版权归原作者所有,如需转载,请联系作者。
原文链接:lansonli.blog.csdn.net/article/details/116245172
