Oracle 物理 DG 转 ADG 步骤
Lucifer三思而后行 发表于 2021/09/18 23:39:21 2021/09/18
【摘要】 DataGuard 物理备库,正常为 mount 状态,如果想要进行查询,需要转为 ADG,即 read only 状态! 在开启为 read only 之前,需要给备库添加 n+1 组的 standb...
在开启为 read only 之前,需要给备库添加 n+1 组的 standby redo log!
查询主库的 redolog :
set line222
set pagesize1000
col member for a60
select t2.thread#,t1.group#,t1.member,t2.bytes/1024/1024 from v$logfile t1,v$log t2 where t1.group#=t2.group# order by 1,2;
   THREAD#     GROUP# MEMBER							   T2.BYTES/1024/1024
	 1	    1 +DATA/mesdb/onlinelog/group_1.257.1034181431				  200
	 1	    2 +DATA/mesdb/onlinelog/group_2.258.1034181431				  200
	 1	    5 +DATA/mesdb/onlinelog/group_5.268.1034182623				  200
	 1	    7 +DATA/mesdb/onlinelog/group_7.270.1034182623				  200
	 1	    9 +DATA/mesdb/onlinelog/group_9.272.1034182623				  200
	 1	   11 +DATA/mesdb/onlinelog/group_11.274.1034182623				  200
	 1	   13 +DATA/mesdb/onlinelog/group_13.276.1034182625				  200
	 2	    3 +DATA/mesdb/onlinelog/group_3.265.1034182261				  200
	 2	    4 +DATA/mesdb/onlinelog/group_4.266.1034182263				  200
	 2	    6 +DATA/mesdb/onlinelog/group_6.269.1034182623				  200
	 2	    8 +DATA/mesdb/onlinelog/group_8.271.1034182623				  200
	 2	   10 +DATA/mesdb/onlinelog/group_10.273.1034182623				  200
	 2	   12 +DATA/mesdb/onlinelog/group_12.275.1034182623				  200
	 2	   14 +DATA/mesdb/onlinelog/group_14.277.1034182627				  200
14 rows selected.
需要注意:
  • stanby log日志大小至少要和redo log日志一样大小,不能小于
  • stanby log数量: standby logfile=(1+logfile组数)=(1+2)=3组,每个thread需要加3组standby logfile.
  • thread要与redo log保持一致,如果是rac,需要增加多个thread对应的standby log
关闭备库同步进程:
alter database recover managed standby database cancel;
备库添加standby redo log:
ALTER DATABASE ADD STANDBY LOGFILE thread 1
group 21 ('/data/MESSTB/onlinelog/standby_group_21') SIZE 200M,
group 22 ('/data/MESSTB/onlinelog/standby_group_22') SIZE 200M,
group 23 ('/data/MESSTB/onlinelog/standby_group_23') SIZE 200M,
group 24 ('/data/MESSTB/onlinelog/standby_group_24') SIZE 200M,
group 25 ('/data/MESSTB/onlinelog/standby_group_25') SIZE 200M,
group 26 ('/data/MESSTB/onlinelog/standby_group_26') SIZE 200M,
group 27 ('/data/MESSTB/onlinelog/standby_group_27') SIZE 200M,
group 28 ('/data/MESSTB/onlinelog/standby_group_28') SIZE 200M;
ALTER DATABASE ADD STANDBY LOGFILE thread 2
group 31 ('/data/MESSTB/onlinelog/standby_group_31') SIZE 200M,
group 32 ('/data/MESSTB/onlinelog/standby_group_32') SIZE 200M,
group 33 ('/data/MESSTB/onlinelog/standby_group_33') SIZE 200M,
group 34 ('/data/MESSTB/onlinelog/standby_group_34') SIZE 200M,
group 35 ('/data/MESSTB/onlinelog/standby_group_35') SIZE 200M,
group 36 ('/data/MESSTB/onlinelog/standby_group_36') SIZE 200M,
group 37 ('/data/MESSTB/onlinelog/standby_group_37') SIZE 200M,
group 38 ('/data/MESSTB/onlinelog/standby_group_38') SIZE 200M;
重启开启备库同步进程:
alter database open read only;
alter database recover managed standby database using current logfile disconnect from session;
检查日志同步情况:
set line222
set pagesize1000
col member for a60
select t2.thread#,t1.group#,t1.member,t2.STATUS,t2.ARCHIVED,t2.bytes/1024/1024 from v$logfile t1,v$standby_log t2 where t1.group#=t2.group# order by 1,2;
select process,group#,thread#,sequence# from v$managed_standby;
select database_role,open_mode from v$database;
至此,ADG 已经转换完成!
本次分享到此结束啦~
如果觉得文章对你有帮助,点赞、收藏、关注、评论,一键四连支持,你的支持就是我创作最大的动力。
❤️ 技术交流可以 关注公众号:Lucifer三思而后行 ❤️
文章来源: luciferliu.blog.csdn.net,作者:Lucifer三思而后行,版权归原作者所有,如需转载,请联系作者。
原文链接:luciferliu.blog.csdn.net/article/details/120365498
