Android’s PreferenceActivity for all API versions
小工匠 发表于 2021/09/10 23:59:48 2021/09/10
【摘要】 官方文档 I have spent the last few days learning about how to use the new Android PreferenceFragment whic...
官方文档
I have spent the last few days learning about how to use the new Android PreferenceFragment which requires PreferenceActivity to override a new v11 (Honeycomb) method called onBuildHeaders(). Unfortunately, the documentation is not very clear how one would create a single PreferenceActivity that could play well in all versions, utilizing the newest features if you have it and avoiding an app crash on older Android versions. I encountered several solutions to this issue by creating two different activities for the two different mechanisms requiring two entries in your AndroidManifest.xml file. Having two different PreferenceActivities means if you have library code that extends that class, you now have to duplicate it. Then, if your app descends your library class, now has to be duplicated yet again. The end result is … less than ideal.
Thankfully, after spending a great deal of time on the subject, I have come up with a single class solution that will work in all Android versions. A couple of the newer methods need to be found using reflection and based off of them, in addition to using the newly introduced xml file of , allow for a single class solution.
First, take your old xml layouts and break them up into several files based on how you would like to see them categorized using the new header format. Simply breaking them apart so that each PreferenceCategory has its own file is a good start. For our example here, we shall assume there are 3 such files, all in the res/xml folder: app_prefs_cat1.xml, app_prefs_cat2.xml, and app_prefs_cat3.xml
Now let us create the descendant PrefsActivity class:
import java.lang.reflect.InvocationTargetException;
import java.lang.reflect.Method;
import java.util.List;
import android.app.Activity;
import android.content.Context;
import android.content.SharedPreferences;
import android.os.Bundle;
import android.preference.PreferenceActivity;
import android.preference.PreferenceFragment;
import android.preference.PreferenceManager;
public class PrefsActivity extends PreferenceActivity {
    protected Method mLoadHeaders = null;
    protected Method mHasHeaders = null;
     * Checks to see if using new v11+ way of handling PrefsFragments.
     * @return Returns false pre-v11, else checks to see if using headers.
    public boolean isNewV11Prefs() {
        if (mHasHeaders!=null && mLoadHeaders!=null) {
            try {
                return (Boolean)mHasHeaders.invoke(this);
            } catch (IllegalArgumentException e) {
            } catch (IllegalAccessException e) {
            } catch (InvocationTargetException e) {
        return false;
    @Override
    public void onCreate(Bundle aSavedState) {
        //onBuildHeaders() will be called during super.onCreate()
        try {
            mLoadHeaders = getClass().getMethod("loadHeadersFromResource", int.class, List.class );
            mHasHeaders = getClass().getMethod("hasHeaders");
        } catch (NoSuchMethodException e) {
        super.onCreate(aSavedState);
        if (!isNewV11Prefs()) {
            addPreferencesFromResource(R.xml.app_prefs_cat1);
            addPreferencesFromResource(R.xml.app_prefs_cat2);
            addPreferencesFromResource(R.xml.app_prefs_cat3);
    @Override
    public void onBuildHeaders(List<Header> aTarget) {
        try {
            mLoadHeaders.invoke(this,new Object[]{R.xml.pref_headers,aTarget});
    static public class PrefsFragment extends PreferenceFragment {
        @Override
            Context anAct = getActivity().getApplicationContext();
            int thePrefRes = anAct.getResources().getIdentifier(getArguments().getString("pref-resource"),
                    "xml",anAct.getPackageName());
            addPreferencesFromResource(thePrefRes);
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
On older Android versions, the reflected methods will be null and thus avoids calling the newer methods, using the older mechanism of adding the various preference xml files in onCreate(). In order to use the new Honeycomb (v11+) preference mechanism, we need to create one more xml file – the newer <preference-headers> xml file that ties all the category files together. The res/xml resource file “pref_headers.xml”:
<preference-headers
    xmlns:android="http://schemas.android.com/apk/res/android" >
<header android:fragment="my.domain.app.PrefsActivity$PrefsFragment"
    android:icon="@android:drawable/ic_menu_sort_by_size"
    android:title="Category 1 prefs" >
    <extra android:name="pref-resource" android:value="app_prefs_cat1" />
</header>
    android:icon="@android:drawable/ic_menu_gallery"
    android:title="Category 2 prefs" >
    <extra android:name="pref-resource" android:value="app_prefs_cat2" />
</header>
    android:icon="@android:drawable/ic_menu_edit"
    android:title="Category 3 prefs" >
    <extra android:name="pref-resource" android:value="app_prefs_cat3" />
</header>
<header
    android:icon="@drawable/icon_question"
    android:title="Blackmoon Info Tech Services"
    android:summary="link to BITS blog">
    <intent android:action="android.intent.action.VIEW"
            android:data="http://www.blackmoonit.com/2012/07/all_api_prefsactivity/" />
</header>
</preference-headers>
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
The first three headers list the three standard category xml files we created, but you are also free to add more items as you see fit, just remember that those will only be visible on devices with Android 3.0 or later.
Now that we have our xml file and single preference activity, we can define it in our AndroidManifest.xml as usual. Note: do not use android:launchMode=”singleTop” for your prefs activity or else it will break phones using 4.0+ by never showing more than just the header list.
<activity android:name="PrefsActivity"
        android:label="Settings"
        android:enabled="true" >
        <intent-filter>
            <category android:name="android.intent.category.PREFERENCE" />
        </intent-filter>
    </activity>
We can have a menu call our prefs activity with just one line:
startActivity(new Intent(this, PrefsActivity.class);
Now that you have a descendant class like this one, you can freely use it in all versions of Android and it will automatically use the newer mechanism where appropriate.
查看这里
文章来源: artisan.blog.csdn.net,作者:小小工匠,版权归原作者所有,如需转载,请联系作者。
原文链接:artisan.blog.csdn.net/article/details/50709406
