Oracle-AWR管理包DBMS_WORKLOAD_REPOSITORY.MODIFY_SNAPSHOT_SETTINGS
小工匠 发表于 2021/09/11 00:52:29 2021/09/11
【摘要】 概述MODIFY_SNAPSHOT_SETTINGS Procedures 概述 官方说明:DBMS_WORKLOAD_REPOSITORY Overview of th...
概述
Overview of the Automatic Workload Repository
AWR机制:通过对系统整体动态采样收集快照信息,存储在SYSAUX表空间,,MMON进程实施,快照分析后写入DBA_HIST_%开头的数据字典。
select table_name from dictionary where table_name like 'DBA_HIST_%';
DBMS_WORKLOAD_REPOSITORY包管理AWR(Automatic Workload Repository),执行诸如管理快照和基线等操作。
这里写图片描述
因包中功能众多,这里我们仅关注MODIFY_SNAPSHOT_SETTINGS
这里写图片描述
默认快照间隔1小时,10g保存7天,11g保存8天
可以通过dbms_workload_repository.MODIFY_SNAPSHOT_SETTINGS存过来调整AWR快照的相关参数
我们来看下Oralce对这段存过标注的注释 ,说明均在注释里,请仔细阅读
  -- modify_snapshot_settings()
  -- Procedure to adjust the settings of the snapshot collection.
  -- Input arguments:
  --   retention                - new retention time (in minutes). The
  --                              specified value must be in the range:
  --                              MIN_RETENTION (1 day) to
  --                              MAX_RETENTION (100 years)
  --                              If ZERO is specified, snapshots will be
  --                              retained forever. A large system-defined
  --                              value will be used as the retention setting.
  --                              If NULL is specified, the old value for
  --                              retention is preserved.
  --                               NOTE: The retention setting must be
  --                                     greater than or equal to the window
  --                                     size of the 'SYSTEM_MOVING_WINDOW'
  --                                     baseline.  If the retention needs
  --                                     to be less than the window size,
  --                                     the 'modify_baseline_window_size'
  --                                     routine can be used to adjust the
  --                                     window size.
  --   interval                 - the interval between each snapshot, in
  --                              units of minutes. The specified value
  --                              must be in the range:
  --                              MIN_INTERVAL (10 minutes) to
  --                              MAX_INTERVAL (100 years)
  --                              If ZERO is specified, automatic and manual
  --                              snapshots will be disabled.  A large
  --                              system-defined value will be used as the
  --                              interval setting.
  --                              current value is preserved.
  --   topnsql (NUMBER)         - Top N SQL size.  The number of Top SQL
  --                              to flush for each SQL criteria
  --                              (Elapsed Time, CPU Time, Parse Calls,
  --                               Shareable Memory, Version Count).
  --                              The value for this setting will be not
  --                              be affected by the statistics/flush level
  --                              and will override the system default
  --                              behavior for the AWR SQL collection.  The
  --                              setting will have a minimum value of 30
  --                              and a maximum value of 50000.
  --                              IF NULL is specified, the
  --   topnsql (VARCHAR2)       - Users are allowed to specify the following
  --                              values: ('DEFAULT', 'MAXIMUM', 'N')
  --                              Specifying 'DEFAULT' will revert the system
  --                              back to the default behavior of Top 30 for
  --                              level TYPICAL and Top 100 for level ALL.
  --                              Specifying 'MAXIMUM' will cause the system
  --                              to capture the complete set of SQL in the
  --                              cursor cache.  Specifying the number 'N' is
  --                              equivalent to setting the Top N SQL with
  --                              the NUMBER type.
  --                              Specifying 'N' will cause the system
  --                              to flush the Top N SQL for each criteria.
  --                              The 'N' string is converted into the number
  --                              for Top N SQL.
  --   dbid                     - database identifier for the database to
  --                              adjust setting. If NULL is specified, the
  --                              local dbid will be used.
  --  For example, the following statement can be used to set the
  --  Retention and Interval to their minimum settings:
  --    dbms_workload_repository.modify_snapshot_settings
  --              (retention => DBMS_WORKLOAD_REPOSITORY.MIN_RETENTION
  --               interval  => DBMS_WORKLOAD_REPOSITORY.MIN_INTERVAL)
  --  The following statement can be used to set the Retention to
  --  8 days and the Interval to 60 minutes and the Top N SQL to
  --  the default setting:
  --              (retention => 11520, interval  => 60, topnsql => 'DEFAULT');
  --  The following statement can be used to set the Top N SQL
  --  setting to 200:
  --              (topnsql => 200);
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
存过定义如下
  PROCEDURE modify_snapshot_settings(retention  IN NUMBER DEFAULT NULL,
                                     interval   IN NUMBER DEFAULT NULL,
                                     topnsql    IN NUMBER DEFAULT NULL,
                                     dbid       IN NUMBER DEFAULT NULL
                                     topnsql    IN VARCHAR2,
如何修改默认的参数值呢?
This example changes the interval setting to one hour and the retention setting to two weeks for the local database:
EXECUTE DBMS_WORKLOAD_REPOSITORY.MODIFY_SNAPSHOT_SETTINGS(
  interval  =>  60,
  retention =>  20160);
重新查询 DBA_HIST_WR_CONTROL 可以发现新的规则已经生效。
AWR参数存放的表 DBA_HIST_WR_CONTROL
snapshot的信息存放在DBA_HIST_SNAPSHOT
文章来源: artisan.blog.csdn.net,作者:小小工匠,版权归原作者所有,如需转载,请联系作者。
原文链接:artisan.blog.csdn.net/article/details/79777340
