Spring Cloud【Finchley】-01服务提供者与服务消费者
小工匠 发表于 2021/09/11 01:45:16 2021/09/11
【摘要】 文章目录 Spring Cloud总览概述示例场景描述用户微服务新建Spring Boot服务项目结构用户库表ModelDao层ServiceController 暴露Rest API配置文件ap...
Spring Cloud总览
概述
服务提供者: 服务的被调用发,为其他服务提供服务的服务
服务消费者: 服务的调用方,即依赖其他服务的服务
示例
场景描述
围绕该场景,需要两个微服务
  • 用户微服务,作为服务提供者为电影微服务提供服务
  • 电影微服务,作为消费者调用用户微服务提供的服务
用户微服务
Spring Boot 2.1.1
Spring Data JPA
H2
lombok简化编码
新建Spring Boot服务
项目结构
pom.xml
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
	xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
	<modelVersion>4.0.0</modelVersion>
	<groupId>com.artisan</groupId>
	<artifactId>micorservice-simple-provider-user</artifactId>
	<version>0.0.1-SNAPSHOT</version>
	<packaging>jar</packaging>
	<name>micorservice-simple-provider-user</name>
	<description>Demo project for Spring Cloud</description>
	<parent>
		<artifactId>spring-boot-starter-parent</artifactId>
		<version>2.1.1.RELEASE</version>
		<relativePath/> <!-- lookup parent from repository -->
	</parent>
	<properties>
		<project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
		<project.reporting.outputEncoding>UTF-8</project.reporting.outputEncoding>
		<java.version>1.8</java.version>
	</properties>
	<dependencies>
		<dependency>
			<artifactId>spring-boot-starter-data-jpa</artifactId>
		</dependency>
		<dependency>
			<artifactId>spring-boot-starter-web</artifactId>
		</dependency>
		<dependency>
			<groupId>com.h2database</groupId>
			<artifactId>h2</artifactId>
			<scope>runtime</scope>
		</dependency>
		<dependency>
			<artifactId>spring-boot-starter-test</artifactId>
			<scope>test</scope>
		</dependency>
		<!-- https://mvnrepository.com/artifact/org.projectlombok/lombok -->
		<dependency>
			<groupId>org.projectlombok</groupId>
			<artifactId>lombok</artifactId>
			<version>1.18.4</version>
			<scope>provided</scope>
		</dependency>
	</dependencies>
	<build>
		<plugins>
			<plugin>
				<artifactId>spring-boot-maven-plugin</artifactId>
			</plugin>
		</plugins>
	</build>
</project>
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
用户库表
简单起见,我们使用H2数据库
schema.sql
drop table user if exists;
create table user(
	id bigint generated by default as identity,
	username varchar(40),
	name varchar(20),
	age int(3),
	balance decimal(10,2),
	primary key(id)
data.sql
insert into user(id,username, name, age, balance) values(1,'user1', '张三', 20, 100.00);
insert into user(id,username, name, age, balance) values(2,'user2', '李四', 20, 100.00);
insert into user(id,username, name, age, balance) values(3,'user3', '王五', 20, 100.00);
insert into user(id,username, name, age, balance) values(4,'user4', '马六', 20, 100.00);
Model
为了简化代码,使用了lombok的@Data注解
package com.artisan.microservice.model;
import java.io.Serializable;
import java.math.BigDecimal;
import javax.persistence.Column;
import javax.persistence.Entity;
import javax.persistence.GeneratedValue;
import javax.persistence.GenerationType;
import javax.persistence.Id;
import lombok.Data;
@Entity
@Data
public class User implements Serializable {
	private static final long serialVersionUID = 226695758444267342L;
	@Id
	@GeneratedValue(strategy=GenerationType.AUTO)
	private Long id ;
	@Column
	private String username;
	@Column
	private String name;
	@Column
	private Integer age;
	@Column
	private BigDecimal balance;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
Dao层
使用Spring Data JPA操作数据库
package com.artisan.microservice.repository;
import org.springframework.data.jpa.repository.JpaRepository;
import org.springframework.stereotype.Repository;
import com.artisan.microservice.model.User;
@Repository
public interface UserRepository extends JpaRepository<User,Long>{
Service
按道理都应该有Service层,这里demo比较简单,省略也可以,直接在Controller层调用Dao层
package com.artisan.microservice.controller;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.data.domain.Example;
import org.springframework.web.bind.annotation.PathVariable;
import com.artisan.microservice.repository.UserRepository;
@RestController
public class UserController {
  @Autowired
  private UserRepository userRepository;
  @GetMapping("/user/{id}")
  public User findById(@PathVariable Long id) {
	  User user = new User();
      user.setId(id);
      User user2 = new User();
      user2.setName("no this user");
      // 我们使用的spring boot2.1.1版本中关联使用的spring data jpa不再支持findone(id)方法,改成如下写法
      return userRepository.findOne(Example.of(user)).orElse(user2);
  • 26
  • 27
  • 28
  • 29
配置文件application.yml
server:
  port: 7900
spring:
  jpa:
    generate-ddl: false
    show-sql: true
    hibernate:
      ddl-auto: none
  datasource:
    platform: h2
    schema: classpath:schema.sql
    data: classpath:data.sql
logging:
  level:
    root: INFO
    org.hibernate: INFO
    org.hibernate.type.descriptor.sql.BasicBinder: TRACE
    org.hibernate.type.descriptor.sql.BasicExtractor: TRACE
    com.artisan: DEBUG
测试
package com.artisan.microservice;
import org.springframework.boot.SpringApplication;
import org.springframework.boot.autoconfigure.SpringBootApplication;
@SpringBootApplication
public class MicorserviceSimpleProviderUserApplication {
		SpringApplication.run(MicorserviceSimpleProviderUserApplication.class, args);
右键–Run As --Spring Boot App,启动成功后
访问数据库中存在的用户
http://localhost:7900/user/1
{"id":1,"username":"user1","name":"张三","age":20,"balance":100.00}
http://localhost:7900/user/2
{"id":2,"username":"user2","name":"李四","age":20,"balance":100.00}
http://localhost:7900/user/3
{"id":3,"username":"user3","name":"王五","age":20,"balance":100.00}
http://localhost:7900/user/4
{"id":4,"username":"user4","name":"马六","age":20,"balance":100.00}
访问数据库中不存在的一个用户
http://localhost:7900/user/66
{"id":null,"username":null,"name":"no this user","age":null,"balance":null}
电影微服务
新建Spring Boot服务
如用户微服务,只不过我们这里仅仅作为消费者,仅使用web即可。
项目结构
pom.xml
	<artifactId>micorservice-simple-consumer-movie</artifactId>
	<name>micorservice-simple-consumer-movie</name>
	<parent>
	</parent>
	<properties>
	</properties>
	<dependencies>
		<dependency>
		</dependency>
		<dependency>
			<scope>test</scope>
		</dependency>
		<dependency>
		</dependency>
	</dependencies>
	<build>
		<plugins>
			<plugin>
			</plugin>
		</plugins>
	</build>
</project>
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
Controller通过 RestTemplate 调用用户微服务提供的服务
因为仅仅作为服务消费者,所有只要在Controller层调用对应的rest接口即可
import org.springframework.beans.factory.annotation.Value;
import org.springframework.web.client.RestTemplate;
@RestController
public class MovieController {
  @Autowired
  private RestTemplate restTemplate;
  @Value("${user.userServicePath}")
  private String userServicePath;
  @GetMapping("/movie/{id}")
    return this.restTemplate.getForObject(this.userServicePath + id, User.class);
  • 26
用到了User类,新建个User.java
import lombok.Data;
@Data
	private static final long serialVersionUID = 8912111288470833198L;
	private Long id;
启动类入口处,通过@Bean实例化RestTemplate
import org.springframework.context.annotation.Bean;
public class MicorserviceSimpleConsumerMovieApplication {
	@Bean
	public RestTemplate restTemplate(){
		return new RestTemplate();
		SpringApplication.run(MicorserviceSimpleConsumerMovieApplication.class, args);
配置文件 application.yml
配置端口及用户微服务的地址
server:
  port: 7901
user:
  userServicePath: http://localhost:7900/user/
测试
启动用户微服务,访问7901
访问数据库中存在的用户
http://localhost:7901/movie/1
http://localhost:7901/movie/2
http://localhost:7901/movie/3
http://localhost:7901/movie/4
访问数据库中不存在的一个用户
http://localhost:7901/movie/66
成功调用到了用户微服务对外提供的服务。
示例的缺点
不难发现,虽然我们把用户微服务对外提供的接口地址配置在了配置文件中,然后通过@Value的方式去加载该属性,但是一旦用户微服务修改了地址,电影微服务作为消费者也要修改对应的地址,多了的话,也是很难管理
第二个原因,如果存在多个用户微服务,如何进行负载? nginx固然可以,如果这种服务比较多,依赖nginx, 增加节点还是需要修改nginx配置文件,比较头疼
所以 接下来我们来看下服务发现与服务注册,这里主要说的是Spring Cloud支持比较好的Eureka
文章来源: artisan.blog.csdn.net,作者:小小工匠,版权归原作者所有,如需转载,请联系作者。
原文链接:artisan.blog.csdn.net/article/details/84679248
